Official Crawlbox BS thread!
Discussion in 'Technical Chat' started by HomerTaco, Mar 16, 2016.
  1. Oct 5, 2023 at 7:09 AM
    #3301
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    Yeah, I pretty much dont hear any gear whine or howling, but you do get the stethoscope effect with 2 extra rods radiating in the cab, and 2 more holes cut in the floor. I hear my rear diff howl (done it since new, just 3rd gen things) more than the trans/cases.
  2. Oct 23, 2023 at 5:12 AM
    #3302
    Operator8
    Operator8 Well-Known Member
    Woodland Park, CO
    2005 White Tacoma TRD OR
    SAS INW
    Have you gotten to take it out yet?
  3. Oct 23, 2023 at 7:23 AM
    #3303
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    It's still in the shop but it runs and drives now. It went on a 40mi trip this weekend.
    Only issue so far: we swapped the ECU and on the first crank it was idling at 2k rpm (probably due to learning procedures within the ECU), went to put the trans in D and the NWF box kicked into neutral for some reason. We just clicked it back into Hi and it was fine. My installer said his Marlin unit did the same thing occasionally when there was a high idle scenario.
    Edit - PFA :anonymous:
    HIYota and TacoEspecial like this.
  4. Mar 18, 2024 at 8:54 AM
    #3304
    4x4MA
    4x4MA Member
    15 ⛈ TROOPER
    Heavy ‍♂️ Lifted
    I like it! Who made that Y-Pipe?
  5. Mar 18, 2024 at 5:24 PM
    #3305
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Brockett built
    HIYota likes this.
  6. Apr 8, 2024 at 6:30 PM
    #3306
    Operator8
    Woodland Park, CO
    SAS INW
  7. Jul 28, 2024 at 9:18 AM
    #3307
    Operator8
    Woodland Park, CO
    SAS INW
    One lesson I have learned with my completed crawlbox..... Is to shift "softer". 1st time out the NWF TC ended up stuck in low, and required a expensive tow back home. But thankfully it's fixed, and I'm back on the road.
    Ricardo13x likes this.
  8. Aug 1, 2024 at 5:20 PM
    #3308
    Speedo
    Speedo Well-Known Member
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    pics of under trim please. How did you fit the parking brake, and all 3 sticks in front of the auto shifter. I struggled to mak that shit fit with 2 on the side and one up front. I did mine in the first batch and the triplle shifter from NWF was ready yet.
  9. Aug 13, 2024 at 10:33 AM
    #3309
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    BAMF RCLT Deaver Fox 2.5 StopTech Dana 60 37s 475:1
    May need to take my crawlboxes a part.
    Anyone have a recommendation on which full gasket and seal kit should I get?
    OEM from trail gear, my crawlboxes are from trail gear?
    Marlin's paper and felt ones with their ecoseal?
    Yotamasters?
  10. Aug 13, 2024 at 10:43 AM
    #3310
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    silicone
    TacoEspecial[QUOTED] and 02hilux like this.
  11. Aug 13, 2024 at 11:25 AM
    #3311
    02hilux
    Planet: EARTH
    rtv for gear oil, its better than the grey rtv stuff. I don’t have any paper/felt gasket for my assembly but I am running the mc ecoseal
    bhigbee, lit_taco4x4, v5ensx and 2 others like this.
  12. Aug 13, 2024 at 12:36 PM
    #3312
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    Hopes and prayers.
  13. Aug 13, 2024 at 1:33 PM
    #3313
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    aint that the truth.
    i have found that using rtv and letting that shit cure before pouring gear oil in immediately does a lot better.
    Dan8906, bhigbee and TacoEspecial like this.
  14. Aug 23, 2024 at 5:39 PM
    #3314
    Speedo
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    The red gasket maker from Toyota and get the surface super clean. Torque to spec. Worked for
    TacoEspecial[QUOTED] likes this.
  15. Aug 23, 2024 at 5:42 PM
    #3315
    Speedo
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    Although mine leaks out the breather hole. Check to see if it is from the top. Could just be from the shifters or breather hole
    TacoEspecial likes this.
  16. Aug 23, 2024 at 6:19 PM
    #3316
    02hilux
    Planet: EARTH
    if that shit ain’t leaking, you’re not using it as intended. :rofl:
    TacoEspecial and v5ensx like this.
  17. Aug 24, 2024 at 6:59 AM
    #3317
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    I found a good level where not much came out the top.
    But then they started singing.
    First thought was it mustn't be enough and I sure messed them up.
    Found some auto trans fluid in them.
    Some bad bearings.
  18. Aug 24, 2024 at 7:09 AM
    #3318
    02hilux
    Planet: EARTH
    how many miles on the boxes since the install?
  19. Aug 24, 2024 at 7:13 AM
    #3319
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    A bit over 30k miles
    Edit: And 12qts of oil
    Joking :rofl:
  20. Aug 24, 2024 at 7:24 AM
    #3320
    02hilux
    Planet: EARTH
    Which bearing went bad? Oil starvation causing excessive heat?
