Official Crawlbox BS thread!
Discussion in 'Technical Chat' started by HomerTaco, Mar 16, 2016.
  1. Sep 26, 2016 at 7:49 AM
    #321
    HomerTaco
    HomerTaco [OP] also HomerTaco Vendor
    HomerTaco
    HomerTaco
    HomerTaco
    Body lift if you are clocking the t-case. If not you'll be ok.
  2. Sep 26, 2016 at 8:22 AM
    #322
    sasquatch95
    sasquatch95 Well-Known Member
    Hunter
    nanaimo BC
    07 DCLB sport
    I know I have some more reading to do. Of the other threads posted in th OP. But if I plan on just running the inchworm or marlin crawler box with out doing the fj tcase will I need to clock it?
  3. Sep 26, 2016 at 9:12 AM
    #323
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    No. Regardless of which case or crawl box you do not need to clock it.
    hoverlover likes this.
  4. Sep 26, 2016 at 9:28 AM
    #324
    sasquatch95
    Hunter
    nanaimo BC
    07 DCLB sport
    Awesome! Thanks homer for the help!! I'll do more reading on it also :)
  5. Sep 26, 2016 at 9:31 AM
    #325
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    You will find that the only reason to clock the transfer case is to enable you to go full flat belly.
    To do that you need to fabricate a custom crossmember for the transmission. I may do that one day but for now I still have the stock crossmember modified with an extension for the crawl box.
  6. Sep 26, 2016 at 9:33 AM
    #326
    sasquatch95
    Hunter
    nanaimo BC
    07 DCLB sport
    So yours hangs down a little bit? I can see that haven't really had a big impact on your wheeling from the pictures I've seen! Or has it??
  7. Sep 26, 2016 at 9:41 AM
    #327
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    The stock transmission crossmember comes down below the level of the frame on all the Tacomas.
    It is a hangup point but this is a solution for it.
    Personally, it's not that big of a deal for me
  8. Sep 26, 2016 at 9:59 AM
    #328
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    I clocked mine a little differently than alot here have done. I clocked my crawlbox and t-case, using the adaptor to the trans, so actually the t-case "clockable" adaptor is not clocked on mine at all. The rest of the driveline (engine/trans) is all in OEM mounts still, and with a BFH I got that belly flat, but ALOT of massaging was needed and had to give up the e-brake cables too. Barely kept the stock auto trans shifter cable cable exit location...
    HomerTaco[OP] likes this.
  9. Sep 26, 2016 at 10:01 AM
    #329
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Somewhere Ant has a video of me with a sledge... :D
  10. Sep 26, 2016 at 10:04 AM
    #330
    sasquatch95
    Hunter
    nanaimo BC
    07 DCLB sport
    You guys are awesome! Thanks for answering my silly questions.
  11. Sep 26, 2016 at 10:05 AM
    #331
    sasquatch95
    Hunter
    nanaimo BC
    07 DCLB sport
    I'd like to see that video :p
    Pcyc likes this.
  12. Sep 30, 2016 at 2:29 PM
    #332
    Haws
    Haws Well-Known Member
    Shawn
    Washington
    TRD Off Road
    Lot's of stuff (-;
    Box is in, and truck is moving slow
    Where or what vehicle type are you guys getting your finished leather shifter boots from?? Mine is in the tray next to my auto shifter.
  13. Sep 30, 2016 at 2:51 PM
    #333
    Pcyc
    Pcyc Self Proclaimed Leader
    Fritz
    Concord, CA
    09 DCSB TRD OR - Supercharged - Dual Cased - Twin Sticked
    https://www.tacomaworld.com/threads/pcyc-fj40-build.444289/ https://www.tacomaworld.com/threads/pcycs-2nd-gen-build.308160/
    I am working on something for us crawl box guys. Hit me up in a pm
    Ugly Betty likes this.
  14. Sep 30, 2016 at 6:35 PM
    #334
    Haws
    Shawn
    Washington
    TRD Off Road
    Lot's of stuff (-;
    I've got my stock two-piece driveline if anyone is needing a spare
  15. Sep 30, 2016 at 8:40 PM
    #335
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    www.redlinegoods.com
    As close to OEM looking as you'll find. They made mine.
    jubei likes this.
  16. Oct 1, 2016 at 5:03 AM
    #336
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    Or try and upholstery shop. That's what I did for mine and they enjoyed the challenge of it
  17. Oct 4, 2016 at 11:40 AM
    #337
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    SO ramping up my research on this crawlbox deal.
    Scratched the idea of using TG's adapters and building my own, seems to be alot of tech in the machining of these adapters (oil passages, etc.) so i'll go with a better name brand.
    Marlin Crawler's site still says coming soon, heard rumors about an adapter redesign but idk. Same with FROR having rumors of making a crawlbox, but again, idk.
    Looks like Inchworm is the likely choice, however with LowRange being a huge supplier of TG parts & owning Inchworm i'd like to double check some info.
    Can Marlin's 4.7 Total Spline gears fit into the Inchworm reduction box (i.e. buy inchworm box, replace with Marlin gears) without issue? Primarily concerned with the spline engagement. Remember reading about having to use TG 4.7s because a spline coupler fitment issue, maybe?
  18. Oct 4, 2016 at 11:49 AM
    #338
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    If time is money then i'm way less into an atlas than you will be into what ever you end up doing
    Basikbiker and SMKYTXN like this.
  19. Oct 4, 2016 at 12:00 PM
    #339
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    Marlin will take longer and some have waited more than 12 months to receive theirs after making payment.
    Inchworm can have you a case is a week. You can upgrade to Marlin gears inside the case, but the same wait applies if Inchworm doesn't have them in stock.
    FROR does have a functioning crawl box that's designed around planetary gears. I wheeled with Brian earlier this year and he had the prototype in his runner. I do not know when he plans on releasing it though. The low gearing options won't be there unless you go tripple cases as his reduction is limited to 2.4:1, or something like that.
    Inchworm, Marlin, FROR, Atlas... Lots of options, so read up before taking the plunge.
  20. Oct 4, 2016 at 2:12 PM
    #340
    Haws
    Shawn
    Washington
    TRD Off Road
    Lot's of stuff (-;
    Got mine installed last week. I did wait for well over a year, but I'm totally happy with the end result. I purchased mine through Wyatt at RST. I believe they are now cranking theses out. My wait had to do with the redesign. My be worth the call to Marlin or Wyatt.
    ToyRyd04 and Pcyc like this.
