Official Crawlbox BS thread!
Discussion in 'Technical Chat' started by HomerTaco, Mar 16, 2016.
  1. Dec 23, 2024 at 8:09 PM
    #3381
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    I knew Threebond did Honda but didn’t know where the Toyota stuff came from. Makes sense though since Honda FIPG also works extremely well.
  2. Dec 25, 2024 at 3:02 AM
    #3382
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
  3. Dec 26, 2024 at 8:37 AM
    #3383
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Now the hard work starts!
    Ricardo13x[QUOTED] likes this.
  4. Dec 26, 2024 at 12:44 PM
    #3384
    Ricardo13x
    Upland, CA.
    9C0D6789-5DB7-4C27-B0F0-C92F3DFEFCA1.jpg It’s already in place. Dropped off the shafts for mod and will be picking them up tomorrow morning. NWF shaft leve complete and working on the J pattern one.
  5. Dec 26, 2024 at 1:43 PM
    #3385
    Ricardo13x
    Upland, CA.
    image.jpg Bout to modify the position of NWF lever and cut and configure the j patter lever.
  6. Dec 26, 2024 at 1:55 PM
    #3386
    Littles
    Littles Stupid is as stupid does.
    Bryan
    Elizabeth, CO
    3 tons of fun
    Love the 3/8 extension in there. :thumbsup:
    Ricardo13x[QUOTED] and TacoVio like this.
  7. Dec 26, 2024 at 2:43 PM
    #3387
    Ricardo13x
    Upland, CA.
    Learned how to make lemonade with apples :fistbump:
    Littles[QUOTED] likes this.
  8. Dec 26, 2024 at 4:03 PM
    #3388
    02hilux
    Planet: EARTH
    :rofl:
  9. Dec 26, 2024 at 9:09 PM
    #3389
    Ricardo13x
    Upland, CA.
    theesotericone likes this.
  10. Dec 26, 2024 at 9:23 PM
    #3390
    02hilux
    Planet: EARTH
    o_O
    what’s next on your list….
    Fernando and Ricardo13x[QUOTED] like this.
  11. Dec 26, 2024 at 9:31 PM
    #3391
    Ricardo13x
    Upland, CA.
    Vehicle wise or this NWF EC install?
  12. Dec 26, 2024 at 9:49 PM
    #3392
    Ricardo13x
    Upland, CA.
    Will be picking up / installing driveshafts tomorrow morning. Test drive and the if all it’s good(knock on wood) will be sealing the tunnel and then covers for the cosmetic touch.image.jpg
    AY_ARONTRD likes this.
  13. Dec 27, 2024 at 2:48 PM
    #3393
    Ricardo13x
    Upland, CA.
    IMG_0314.jpg Shafts installed, test drive went perfect! No vibrations or shit sounds. shout out California Driveline in Rancho Cucamonga! Contact them for any of your driveline mods! Old school Crawler guys!
  14. Dec 27, 2024 at 3:01 PM
    #3394
    AY_ARONTRD
    AY_ARONTRD Well-Known Member
    Aaron
    Murrieta ,CA
    2019 DCLB Cement OR 4x4
    Damn. Nice! Slowly gaining more and more interest, want to throw a crawl box in my 3rd Gen.
    Littles and Ricardo13x[QUOTED] like this.
  15. Dec 27, 2024 at 3:09 PM
    #3395
    Ricardo13x
    Upland, CA.
    Get rid of all the unnecessary stuff laying around and convert it into a NWF EcoCrawler. Definitely a DIY project or a shop familiar with all this BS IMG_0315.jpg
    AY_ARONTRD[QUOTED] and Littles like this.
  16. Dec 29, 2024 at 9:28 PM
    #3396
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Respect to people who are good at sheet metal fab. This shit sucks
    On another note, anyone got any input on these seals? They still seal for now, but I haven't seem one sort of swell like that before.
    Ricardo13x likes this.
  17. Dec 29, 2024 at 10:22 PM
    #3397
    02hilux
    Planet: EARTH
    there’s no part number on the seal?
  18. Dec 29, 2024 at 10:25 PM
    #3398
    02hilux
    Planet: EARTH
    I have 2 extra holes from my triple case. Didn’t have to modify the tunnel at all beside the hammer love. First gen too
    :nuclear:
  19. Dec 29, 2024 at 10:47 PM
    #3399
    betterbuckleup
    Ian
    Concord, CA
    How the fuck were you able to fit 3 cases and not have to do any sheet metal work.
    Part of it must be yours being a double cab? but still....
    All my tranny, motor, tcase mounts are rubber so they move around more than if I had poly. So I also need a bit more clearance so they don't hit under load. That rear hole on your rear case looks wicked tight up against the arms. Is yours hard mounted?
    Just curious on if other have seen seals "swell" like that before.
  20. Dec 30, 2024 at 5:46 AM
    #3400
    02hilux
    Planet: EARTH
    Yea, it’s a DC with a longer tunnel clearance vs xtra and all my mounts are factory too, up until like 4 years ago when I went SA. I got rid of the factory transmission crossmember and relied on the FROR tcase mount for the extended support. I will eventually tie in the front lower frame link mount and rear lower frame link mount and add a skid/support to the mid section of the tcase. There’s minimal clearance but everything clear and nothing hit or bind under load as of now. I had noticed more vibration after removing the factory transmission crossmember but that’s only when the vehicle idles, under load, no new noises.
    I kept everything inside the cab looking factory and original. Went from ADD H/L push button case to the j-pattern case and the 4wd light on the dash still turns on when 4wd is engaged without the push button like original. I tied the push button to a reverse switch and placed it on the factory 4wd rail to activate the push button. Kept both actuator as stand alone units to keep the 4wd light working because I couldn’t find a solution to bypassed the actuator.
    Crawl ratio is wicked stupid: 408:1 not considering the torque converter but love it when the truck drives down a steep AF slab where my butt cheeks are compressed together :rofl:
    TacoEspecial, jubei, ssd_dan and 2 others like this.
