Official Crawlbox BS thread!
Discussion in 'Technical Chat' started by HomerTaco, Mar 16, 2016.
  1. Sep 15, 2025 at 3:17 PM
    #3521
    rmack
    rmack Well-Known Member
    2022 Tacoma TRD Off-road
    RCLT, 38", T-case swap, crawl box, etc...
    Regarding the driveshaft modifications, will the length difference just be the width of the crawler box?
    I would suggest measuring and not just using the crawlbox as a reference.
    Is an exhaust reroute needed to...
    It was in my case w/ a 3rd gen
    Do you know the part number for the stock mount/insulator...
    I created my own cross member. I used the following part for my crawl box: https://www.4xinnovations.com/Super-Duty-Transfer-Case-Mount-for-82-95-Pickup-4Runner_p_85.html
    I know I asked about shifter covers before...
    You can make your own, or you can buy different ones online, make sure your floor hole isn't to large depending on your application and the boot.
  2. Sep 15, 2025 at 3:24 PM
    #3522
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    1. yeah, the difference for drive shaft would be the length of the crawl box. also, for the rear if you have a 2 piece drive shaft, the front piece is the one that's cut down and it to is the length of the crawl box
    2. i don't think you would need a reroute from for stock exhaust, but if you are doing one, do it after everything is installed and drivable but probably before the modified crossmember? i really don't remember the order i did all mine it. i know the exhaust was after the crawl box install because i needed to know how far back to bring the exhaust around the tcase.
    3. use this one https://www.marlincrawler.com/product/crossmember-mount-oem
    or this one https://www.marlincrawler.com/product/crossmember-mount-hd
    I personally went with the HD mount. also, stock part number is listed in the oem link
    4. i had a custom shift boot made up for the 6spd and crawl box sticks since they are in the same hole. for the tcase, i just have a green crown royal bag
