Official Crawlbox BS thread!
Discussion in 'Technical Chat' started by HomerTaco, Mar 16, 2016.
  1. Dec 19, 2016 at 8:36 PM
    #381
    Ugly Betty
    Ugly Betty Well-Known Member
    mark
    TX
    85 extra cab on propane
    1985 ex cab, 92 toyota pickup, 95 4runner
    I had no idea. Thank u for that tidbit:thumbsup:
  2. Dec 19, 2016 at 8:45 PM
    #382
    sasquatch95
    sasquatch95 Well-Known Member
    Hunter
    nanaimo BC
    07 DCLB sport
    Ahh that makes more sense then! I'm not even sure if I will ever add a crawlbox or not I just mainly like to learn but it does sound like a very useful mod and something I should learn more about :)
    James at Lowrange likes this.
  3. Dec 20, 2016 at 5:07 AM
    #383
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    If you buy an atlas then none of those rules apply. you just stuff the fucker in any gear range/ drive option you want (minuse FWD high range) and go to driving/wheeling.
  4. Dec 20, 2016 at 6:40 AM
    #384
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    i always drive around wheeling with 4.7. hardly ever go into compound low or even low with the fj case. after almost 5 years, still works and the world hasnt ended. also, i wish i hadnt done twin sticks since i would have 2 low with the crawl box.
    James at Lowrange and ToyRyd04 like this.
  5. Dec 20, 2016 at 6:59 AM
    #385
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    Craig, this only applies to you 2nd Gen guys and your goofy non-manual stock transfer cases, right? (I'm kidding about the goofy part!) I'm wondering if the issue that @James at Lowrange described is applicable to 1st Gen J-shift cases as well, because I fully intend to keep my J-shift in the mix.
  6. Dec 20, 2016 at 10:23 AM
    #386
    HomerTaco
    HomerTaco [OP] also HomerTaco Vendor
    HomerTaco
    HomerTaco
    HomerTaco
    Yes
  7. Dec 20, 2016 at 10:34 AM
    #387
    James at Lowrange
    James at Lowrange Well-Known Member
    200 miles from Moab
    What i'm talking about applies to anything. Even with 2.28s in the crawl box running crawl box in low and rear case in high is really hard on the input shaft of rear case.. Mild wheeling is no issue.. Some guys get away with it .. Other guys break stuff .
    This is mine.. 2.28 crawl box in low.. Gear rear case in high.. Now this is a old style ( known to fail) tg 21 spline .. but my buggy is only 3000 lbs . I did deserve to break this I was hitting a rock wall/bowl / waterfall at about 20 mph in the snow :)
    Smart driving and you can keep it together no problem. I just tend to make bad choices.
    http://www.lowrangeoffroad.com/toyo...hwormgear/built-tacoma-double-case-setup.html
    In the details section we talk about the 4.7s in the crawl box
    One of the biggest things that takes out t cases is big tires with out re-gearing the axles .
  8. Dec 20, 2016 at 11:04 AM
    #388
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    This is what I'm trying to avoid by going with the Marlin gears, they don't "neck down," 23 spl options, and have the option to upgrade to chromo.
    I do plan on cruising with the 4.7s as the primary gear reduction, taking advantage of the deeper gearing and engine braking for downhill with an auto.
    Diffs are geared accordingly, so i'm hoping that will help out as well.
    But totally agree the additional stress put on the tcases without the diff regear will be only a matter of time before failure.
    jubei likes this.
  9. Dec 20, 2016 at 11:19 AM
    #389
    jubei
    NoCo
    Stuff. Also things.
    Thanks, fellas!
    For reference, I'm running 315s with 5.29s and IFS for the time being. Not a hardcore crawler by any means; mostly looking to have a slower speed available rather than skinny pedal up everything. Because my truck is more expo oriented, the crawl box is there more for its availability in case shit gets hectic out in the sticks.
  10. Dec 20, 2016 at 11:38 AM
    #390
    James at Lowrange
    200 miles from Moab
    It sounds like neither of you should have any issues.. I've been thinking about ditching my dual gear drivens w/ 4.7 rear and doing a 4.7 crawl box in front of a fj case. And swapping my Hybrid 9.5 fj80 front axle for a Ford high pinion dana 60 someday.
    malburg114 and jubei[QUOTED] like this.
  11. Dec 20, 2016 at 11:46 AM
    #391
    ToyRyd04
    Greg
    Perryville, MD
    '04 PreRunner
    That front axle combo :thumbsup:
  12. Dec 20, 2016 at 11:55 AM
    #392
    James at Lowrange
    200 miles from Moab
    Ruffstuff Housing 9.5 3rd fj80 outers.. RCV full 30 spline kit, Hellfire knuckles , Trail Gear 8 inch ram.
    Haven't had any issues lately was breaking the inner RCVs
    Sorry for the hijack back to dual case BS :)
    malburg114, Mothman and jubei like this.
  13. Dec 20, 2016 at 12:17 PM
    #393
    Ugly Betty
    mark
    TX
    I'll take that front axle off ur hands when u decide to sell it :)
  14. Dec 20, 2016 at 12:22 PM
    #394
    James at Lowrange
    200 miles from Moab
    @MYT4CO I will keep you in mind!
    Ugly Betty likes this.
  15. Dec 20, 2016 at 3:14 PM
    #395
    sasquatch95
    Hunter
    nanaimo BC
    07 DCLB sport
    Atlas would be sick but 3500$ for the 4 speed is a lot. Especially when I gotta convert that in to Canadian :eek:
  16. Dec 20, 2016 at 4:33 PM
    #396
    rctoy
    konstantenos
    Pocatello Idaho
    i have one and it's so worth it. trust me.
  17. Dec 20, 2016 at 4:47 PM
    #397
    sasquatch95
    Hunter
    nanaimo BC
    07 DCLB sport
    What about the atlas 2 speed? Isn't it like 2800... but I mean what's another 700$ to get the 4 speed..... I still have to re gear to :oops:
  18. Dec 20, 2016 at 4:52 PM
    #398
    rctoy
    konstantenos
    Pocatello Idaho
    It's not cheap any way you do it but remember cheap ain't bad ass and bad ass ain't cheap.
    I'm glad i spend the money on on atlas 4 speed because when it came time to break it wasn't and expensive tcase that would leave me stranded in 4 foot of snow where i would have to leave my truck still spring.
  19. Dec 20, 2016 at 6:01 PM
    #399
    sasquatch95
    Hunter
    nanaimo BC
    07 DCLB sport
    That's some deep ass snow. I think the 4 speed would be overkill for me but I would know I'd never break it that's for sure
  20. Dec 21, 2016 at 4:38 AM
    #400
    jubei
    NoCo
    Stuff. Also things.
    My 4.7 TacoBox is in my possession! Marlin took awhile, but he got it here eventually.
    Probably won't attack all of this until the fall of next year, as the funds I had set aside for my drive lines, crossmember, etc. got siphoned off to other things while I was waiting for this. That's fine though. I have a million other things to wrap up over the winter to have my rig ready to rock for spring and summer trips.
