Official Crawlbox BS thread!
Discussion in 'Technical Chat' started by HomerTaco, Mar 16, 2016.
  1. Mar 13, 2018 at 10:24 AM
    #501
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    the atlas currently 2.73-1 and 3.0-1. i will be installing a 2.28-1 in front of it for the reasons listed below so that's a total of 18.7-1 with an auto in front of it. Gonna need some 42" red label BFG crawlers. :devil::devil:
    yes but i need to move my Tcase further back so i can achieve better drive line angles. This will help my front dive line last longer. also i haven't done anything to my truck in like 3 years I need projects.
    Pcyc, snotaco, Holloman and 3 others like this.
  2. Mar 13, 2018 at 10:32 AM
    #502
    HomerTaco
    HomerTaco [OP] also HomerTaco Vendor
    HomerTaco
    HomerTaco
    HomerTaco
    Very cool.
  3. Mar 13, 2018 at 10:38 AM
    #503
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
  4. Mar 13, 2018 at 11:41 AM
    #504
    rctoy
    konstantenos
    Pocatello Idaho
  5. Mar 13, 2018 at 12:42 PM
    #505
    BenMara
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    Very true, but then again was all going behind a LQ9 and NV4500
  6. Mar 13, 2018 at 1:22 PM
    #506
    rctoy
    konstantenos
    Pocatello Idaho
    I don't know for sure but it's been said that the hero case wont even fit between the first gen frame rails.. also it's nice having all these gearing options.
  7. Mar 13, 2018 at 3:08 PM
    #507
    BenMara
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    It is a large chunk of metal...:notsure:
  8. Jun 5, 2018 at 12:35 PM
    #508
    Een
    Een Well-Known Member
    Ian
    Castle rock, co
    2004 DBL Cab Tacoma trd
    Super charged, urd 2.1 pulley, 7th injector, sway away coilovers w/ all pro uca's in front, all pro leaf and shackles in rear with fox 2.0 Relentless Offroad DIY aluminum front bumper, all pro sliders 315's on 16" method wheels
    Just a quick note, may be in previous threads but hope this helps someone.
    Building my crawlbox i decided to spend a few extra bucks and put new bearings in there while i was at it rather than use the originals from 198? (Probably 85-89 for mine)
    Bought an input bearing, counter shaft bearing, pocket needle bearing and the coupler needle bearing but wanted new c clips too as they are really stiff and my whimpy snap ring pliers needed the aid of a small screw driver. Even if you dont put new bearings in you will have re use these.
    These proved hard to find but Davez offroad supply had both the inner c clips for the input and counter shaft on their site for $7.50 a pop.
    Nice peace of mind as i would hate for a clip to pop off inside the crawl box!
    G.T. and malburg114 like this.
  9. Jun 20, 2018 at 5:19 AM
    #509
    Pcyc
    Pcyc Self Proclaimed Leader
    Fritz
    Concord, CA
    09 DCSB TRD OR - Supercharged - Dual Cased - Twin Sticked
    https://www.tacomaworld.com/threads/pcyc-fj40-build.444289/ https://www.tacomaworld.com/threads/pcycs-2nd-gen-build.308160/
    New proper mount. Fabricated by Shaffer’s Offroad in alameda ca
  10. Jun 20, 2018 at 5:44 AM
    #510
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    i dig that red mount... those poly bushings?
  11. Jun 20, 2018 at 8:18 AM
    #511
    Pcyc
    Fritz
    Concord, CA
    Yes sir. It’s marlins heavy duty mount.
  12. Jun 20, 2018 at 12:19 PM
    #512
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Very clean install! :cool:
    Think I got mine from 4xinnovations... it came bare metal though - not as pretty. :oops:
    Pcyc[QUOTED] likes this.
  13. Jun 26, 2018 at 8:10 AM
    #513
    Een
    Ian
    Castle rock, co
    Alright, whats the general consenus for:
    1.) Sealing up the crawl box and adapters. I have gaskets, permatex grey, and the right stuff. I was thinking of massaging the right stuff on both sides of the gaskets and using them. I know leaks are common so trying to hedge my bets.
    2.) Grease on the coupler. Assembly lube? Heavy axle grease? Lighter synthetic grease? Blend of assembly and grease? Ive read both are the 'right' way.
  14. Jun 26, 2018 at 8:12 AM
    #514
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    You’re good on number one. For number two I just used synthetic grease.
  15. Jun 26, 2018 at 8:22 AM
    #515
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    You're going to get leaks no matter how well you seal it up. Do what you can and just live with them. I just resealed my tcase to crawlbox mating surface and still have a slight weap.
    I used never sieze on my couplers. It was still in there when I pulled the tcase a couple of weeks ago.
    G.T. and HomerTaco[OP] like this.
  16. Jun 26, 2018 at 8:46 AM
    #516
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    1. This seems to be the best method, factory gaskets + right stuff coating. If your box/adapter has dowel pins, be sure to use them.
    2. It seems that anti seize was a common use without issue, some newer crawlbox adapters couplers sit in fluid. Ref post #444 in this thread.
    I ended up going with https://www.amazon.com/Honda-HN-08798-9010-MOLY-PASTE/dp/B0083BWUYW
    "- Primary Use – Part assembly; running in; as a press-fitting lubricant where high temperature is a factor. - Special Characteristics – Wider and higher operating temperature range than organic oil based pastes; extreme loads; low speeds.
    - Physical Form – Black, soap thickened, silicone fluid based paste containing more than 60% MoS2.
    - Applications – Lubricating during running-in of gears, splines, journal bearings, cams; reducing torque in tightening threads and bolts; lubricating bearing shafts, O-rings, packings and seals, brake assemblies; press-fitting.
    - Temperature Range – Solids from –50 to 750 degrees Fahrenheit (-45 to 399 degrees Celsius); base oil from –40 to 450 degrees Fahrenheit (-40 to 232 degrees Celsius)."
    M77 replaced M60. From site: http://goldwingdocs.com/forum/viewtopic.php?t=27648
  17. Jun 26, 2018 at 2:42 PM
    #517
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    i found the best way to seal everything up is basically do it in stages. do adapters to the crawlbox one day, then put the crawl box to the transmission and then the next day put the tcase to the crawl box. this allows the ultra grey to set/cure with out having to do with too much weight. then put gear oil in it a day later. last time i took everything apart i did this and have almost no leaks. infact, i think most my leaks are coming from the shifters.
    hoverlover, SMKYTXN, G.T. and 2 others like this.
  18. Jun 26, 2018 at 10:43 PM
    #518
    Pcyc
    Fritz
    Concord, CA
    What do you guys do for the noise and heat from the tunnel? I am thinking about dynamat and some thermal insulation. All my boots are tight and tunnel is sealed well.
  19. Jun 27, 2018 at 4:54 AM
    #519
    Een
    Ian
    Castle rock, co
    Thanks for the input gents, all good info
  20. Jun 27, 2018 at 6:37 AM
    #520
    rctoy
    konstantenos
    Pocatello Idaho
    been waiting for this black box to show up but it hasn't yet.
    I applied to go compete in truck nights in America and there's a 90% chance ill be going so even if it shows up this or next month it won't be going in till well after i get back. winter project i guess.
