Official Crawlbox BS thread!
Discussion in 'Technical Chat' started by HomerTaco, Mar 16, 2016.
  1. Aug 27, 2018 at 4:46 AM
    #561
    Een
    Een Well-Known Member
    Ian
    Castle rock, co
    2004 DBL Cab Tacoma trd
    Super charged, urd 2.1 pulley, 7th injector, sway away coilovers w/ all pro uca's in front, all pro leaf and shackles in rear with fox 2.0 Relentless Offroad DIY aluminum front bumper, all pro sliders 315's on 16" method wheels
    I will be calling them today... those pins are not coming out, i would have to drill out the hole in the adapter but that goes for some of the bolt holes as well.
  2. Aug 27, 2018 at 5:00 AM
    #562
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    This may seem like an odd question but, in that picture posted, any chance that you have a few of the bolts tightened down?
  3. Aug 27, 2018 at 7:31 AM
    #563
    Een
    Ian
    Castle rock, co
    Nope... i tried it every which way under the vehicle and finally pulled the tail housing for a second time to dry fit it (dry fit the whole assembly except that piece of course)
    If i start bolts they are crossed and it wont line up, not a good feeling with aluminum threads and either way the dowel wont line up.
    Everything on the passenger side aligns, as the bolt and dowel holes work to the driver they progressively get worse.
  4. Aug 29, 2018 at 12:37 PM
    #564
    Een
    Ian
    Castle rock, co
    Sent pictures to trail gear on monday, they emailed back the following day saying they pulled the parts and test fit it at their shop... doesnt really help me! He did have a suggestion to check but i really think the machining just went awry on my particular adapter.
    I am going to pull it from the case and pull all the bolts and send them more pictures, perhaps even pull some meassurements from hole to hole for them to verify but i need to cut the chase and get a new adapter coming in the mail.
    HomerTaco[OP] likes this.
  5. Aug 29, 2018 at 6:03 PM
    #565
    HomerTaco
    HomerTaco [OP] also HomerTaco Vendor
    HomerTaco
    HomerTaco
    HomerTaco
    Keep us posted Ian. Looks like an unfortunate machining mixup. I hope you get it straightened out.
  6. Aug 29, 2018 at 7:45 PM
    #566
    Een
    Ian
    Castle rock, co
    Alright... i have to own up.
    I just pulled the adapter from the crawl box and dry fit it with the bolts that hold it to the crawlbox and the same problem persisted. I looked at the input seal, looked straight, flipped it over looked and felt seated all the way. Figured i would pull ot either way and... sure enough that was it. I set it in with a dead blow and block for even distribution and let the silicone set up, that was enough to throw it all off
    My tail is between my legs, but i would rather fess up on my bad then have an actual problem!
    For the record, TG responded within 24 hrs and suggested that a bolt was holding it up... they did right in my book.
  7. Aug 29, 2018 at 7:56 PM
    #567
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Shit happens. Glad you got it figured out !
  8. Aug 30, 2018 at 4:41 AM
    #568
    ToyRyd04
    Greg
    Perryville, MD
    '04 PreRunner
    Defintley not the worst thing, especially since these things come with little to no instructions. Glad you got it squared away.
    malburg114 likes this.
  9. Aug 30, 2018 at 1:33 PM
    #569
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    atlas is expensive and big and heavy but damn it's tough and bad ass. my black box showed up so when i get time and more money in the spring i will turn my 4 speed atlas into a 6 speed.
    malburg114 and HomerTaco[OP] like this.
  10. Aug 30, 2018 at 4:34 PM
    #570
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    I priced it out my friends 4spd atlas is not that much more than I have into my dual/lefty combo. Yea the atlas is a pain to fit, but I have a welder, a grinder and stupidity on my side to get it under there!!
    hoverlover, Een, malburg114 and 2 others like this.
  11. Sep 6, 2018 at 11:54 AM
    #571
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    :spy:
    I’d like to find the fawker who stabbed my seat before I owned the truck. Party foul it is in good condition otherwise.
  12. Sep 17, 2018 at 4:41 AM
    #572
    ToyRyd04
    Greg
    Perryville, MD
    '04 PreRunner
  13. Oct 8, 2018 at 4:57 PM
    #573
    Sperhart303
    Sperhart303 Member
    Las Vegas, NV
    02 Trd Stepside Sr5
    Hey everyone, long time lurker here. I read through all the posts here (great resources, but looking for clarification) I have the Marlin 4.7 crawlbox, 3.4L Manual transmission. I bolted everything together and it leaked like a sieve between the trans and the crawlbox. I have the cases dropped out currently. I have a couple questions.
    1: Does the area between the transmission and the crawl box hold fluid (on purpose)
    2: How loose or tight should that adapter fit in the transmission tail housing and will it need to be RTV'd?
    Any help is appricated!
  14. Oct 8, 2018 at 5:12 PM
    #574
    Spoonman
    Jamie
    Alberta
    Did atf or gear oil leak out?
  15. Oct 8, 2018 at 5:13 PM
    #575
    Sperhart303
    Sperhart303 Member
    Las Vegas, NV
    02 Trd Stepside Sr5
    Manual trans, it was Gear oil from the case. the fitment from the crawl box side of the seal extension seems loose.
  16. Oct 8, 2018 at 5:14 PM
    #576
    ToyRyd04
    Greg
    Perryville, MD
    '04 PreRunner
    Just finished up mine about 2 weeks ago, nice and sealed after about 350miles on it.
    1. Early year marlin adapters did not utilize the area between the trans and adapter. The new versions do by design.
    2. Adapters should be scuffed, and some flavor of gasket/rtv should be used. Do not over tighten as we are talking about aluminum/cast aluminum.
    Check out this build thread, go through it where it talks about sealing the crawelbox. Follow it exactly, really helps point out all the sealing points and prepping to seal each section. **that seal extension should be red loctite'd on the aluminum to aluminum side. Then RTV before the seal it tapped in and also around the seal ends.
    twotwentyswift and HomerTaco[OP] like this.
  17. Oct 8, 2018 at 5:20 PM
    #577
    Spoonman
    Jamie
    Alberta
    That seal adapter and seal should fit very snug over the input to the tcase.
  18. Oct 8, 2018 at 6:04 PM
    #578
    v5ensx
    v5ensx CARB legal is not CALI legal
    1. Area between crawl box to transmission should remain dry. Should not contain any fluid in between there, just like original.
    2. It should be fairly tight. Even though both side/lip are flush, rtv is highly recommended.
    Did you hammer the coupler in enough on the input gear and transmission?
    You got the original designed tacobox or later one (Anadioze red)?
  19. Oct 8, 2018 at 6:24 PM
    #579
    Sperhart303
    Sperhart303 Member
    Las Vegas, NV
    02 Trd Stepside Sr5
    Yep, spline adapter is all the way on. I have the new red style.
  20. Oct 8, 2018 at 6:35 PM
    #580
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Um... oil seal housing on the crawlbox input shaft... ?
