Official Crawlbox BS thread!
Discussion in 'Technical Chat' started by HomerTaco, Mar 16, 2016.
  1. Nov 5, 2018 at 7:35 PM
    #601
    Sperhart303
    Sperhart303 Member
    Las Vegas, NV
    02 Trd Stepside Sr5
    Hey everyone, thanks for the help, everything's all cherry and together. My RTV job is sealed tight, but marlin crawlers RTV seaps! Does anyone who didn't go triple stick have a particular rubber "sub boot" that they used for moisture and heat on the chain drive case?
  2. Nov 5, 2018 at 7:37 PM
    #602
    6 gearT444E
    Deep South
    Herculiner Hootus
    I used the boot that came with the 6 speed fj cruiser and it fit pretty well.
  3. Nov 15, 2018 at 2:58 PM
    #603
    SGTCap
    SGTCap Well-Known Member
    Cap
    Summerville, SC
    4x4 6-spd,
    37s, 4x4 6-spd, OME 886s, Allpro Expos, SOS sliders and front/rear bumpers,Rack,Skids, 4.56s, Lockers,Recon Winch, TJM RTT, Lots of tools, boxes and gear. Shaggy mutt behind the seat
    Since Inchworm seems to be gone, who would I order replacement parts from? I'm planning to swap my crawlbox from one transmission to another. If I can't get the oil seal and trans extension housing out of the original transmission who could I order one from? Any ideas?
  4. Nov 15, 2018 at 3:13 PM
    #604
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    Probably best to call Low Range and see if they have something that will work for you
  5. Nov 15, 2018 at 3:16 PM
    #605
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
  6. Nov 15, 2018 at 4:18 PM
    #606
    02hilux
    Planet: EARTH
  7. Nov 15, 2018 at 4:24 PM
    #607
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    They all leak, part of having one.
  8. Nov 15, 2018 at 4:27 PM
    #608
    slander
    Hickory, NC
    I blew a trans up because the seal on my extension housing went bad and all the fluid leaked into the crawl box and subesquently out of the truck. Trans ran dry and then kaboom.
    So commingling the fluid is kind of bad.
    malburg114 likes this.
  9. Nov 15, 2018 at 5:34 PM
    #609
    v5ensx
    v5ensx CARB legal is not CALI legal
    How is that possible? The transmission pan sit lower then the crawl box and usually hold about 3+ quarts of fluid. Plus, crawl box can only hold so much oil.
  10. Nov 15, 2018 at 5:38 PM
    #610
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    People with crawl boxes don’t let the truck sit level all the time.
    Fernando likes this.
  11. Nov 15, 2018 at 6:26 PM
    #611
    slander
    Hickory, NC
    Manual trans and it sprayed back there while driveing via the output shaft. It always dripped since I installed it. I think the seal let loose at one point and it kept leaking and I assumed it was a normal drip.
  12. Nov 15, 2018 at 6:26 PM
    #612
    slander
    Hickory, NC
    Happened while driving over time.
  13. Nov 15, 2018 at 6:34 PM
    #613
    v5ensx
    Dang it. That s#ck
  14. Nov 15, 2018 at 6:38 PM
    #614
    slander
    Hickory, NC
    Sucked big time!
  15. Nov 16, 2018 at 9:31 AM
    #615
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    Mine does it as well. And it's an automatic so it essentially pumps it around till the tcase is full then slowly blows out the breather. Crappy design by Toyota and crawl box manufacturers to not put a "real seal" or double seal between the two instead of that crappy small one.
  16. Nov 16, 2018 at 5:59 PM
    #616
    HomerTaco
    HomerTaco [OP] also HomerTaco Vendor
    HomerTaco
    HomerTaco
    HomerTaco
    This is it.
    scottalot likes this.
  17. Nov 16, 2018 at 6:12 PM
    #617
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Idk about “leak proof” but this is the required adapter piece for a manual trans to mate to the gear reduction box.
    The adapters are trans-specific.
    I found out the hard way.
    @6 gearT444E & @loosnut know exactly what I’m talking about. :(
  18. Nov 16, 2018 at 6:26 PM
    #618
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    It did, this was a problem from a couple years ago. ;)
  19. Nov 16, 2018 at 6:37 PM
    #619
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Since the thread was on the topic I pulled this off my shelf. The one currently in my truck I had a local fab shop turn on a lathe for me. This was based on the exact measurements of the part pictured.
    I unfortunately had the wrong one when I went to do my install and it left my truck immobile for weeks without it.
    It took almost 8 weeks to get this one shipped to me at which time I had already had another one milled and installed.
    My crawlbox install went south real fast really quickly.
    In the end it all worked out though and that’s what really matters. :D
    scottalot[QUOTED] likes this.
  20. Nov 16, 2018 at 9:13 PM
    #620
    Spoonman
    Jamie
    Alberta
    Anyone with a trail gear 4.7 have an issue with it popping out of gear while in low?
    Mine is doing it, trail gear sent me another brand new case, and this is doing it as well. I’ve tried everything.
