Official Crawlbox BS thread!
Discussion in 'Technical Chat' started by HomerTaco, Mar 16, 2016.
  1. Jan 22, 2019 at 7:01 PM
    #661
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    Drive my truck next time the TN crowd is together. There’s no going back once you’ve used a crawlbox
  2. Jan 22, 2019 at 7:03 PM
    #662
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I need it with the 5 speed too. Not really very easy to "take it slow" at the moment without frying the clutch in the process
    hoverlover likes this.
  3. Jan 22, 2019 at 7:04 PM
    #663
    02hilux
    Planet: EARTH
    or stack another crawl box for more awesomeness:amen: you'll have more stick to play with, lol
    ThunderOne likes this.
  4. Jan 22, 2019 at 7:17 PM
    #664
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    Better than a solid axle swap I’d say...I hated wheeling my 5-speed after coming from an auto
    slander and malburg114 like this.
  5. Jan 22, 2019 at 7:27 PM
    #665
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    That's what @slander said too. Crawl box was a better mod
    slander likes this.
  6. Jan 22, 2019 at 7:47 PM
    #666
    02hilux
    Planet: EARTH
    Do both. Best of the two world
  7. Jan 22, 2019 at 7:48 PM
    #667
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Haha, one small step at a time
  8. Jan 22, 2019 at 7:50 PM
    #668
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    A crawlbox isn't a small step. It's a giant leap. Until you wheel a truck that has one you can't even begin to understand the amount of control they give you.
  9. Jan 22, 2019 at 8:02 PM
    #669
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Oh I know. It just seems like... less work than SAS lol.
  10. Jan 22, 2019 at 8:04 PM
    #670
    HomerTaco
    HomerTaco [OP] also HomerTaco Vendor
    HomerTaco
    HomerTaco
    HomerTaco
    Agreed. After I drove @6 gearT444E truck up a 45° angle with my thumb on the wheel in compound low I knew I’d have to do the mod. Took several years but I did it. :D
    hoverlover, G.T., jubei and 1 other person like this.
  11. Jan 22, 2019 at 8:04 PM
    #671
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    It is.
  12. Jan 22, 2019 at 8:13 PM
    #672
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    Significantly less lol. TG makes it easy with complete boxes or both adapters in a package. Plus a dual case crossmember that’s ready to weld in. Basically the only thing to sort out is where you want your shifter hole and where you will get your driveshafts done
    hoverlover and ToyRyd04 like this.
  13. Jan 22, 2019 at 8:17 PM
    #673
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Yeah. Absolutely no idea who around Nashville does that type of thing (driveshafts)
  14. Jan 22, 2019 at 9:57 PM
    #674
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Marlin crawlboxes are available again!!
  15. Jan 22, 2019 at 11:24 PM
    #675
    Jiveydude
    Jiveydude Well-Known Member
    Micah
    OH
    04Taco
    Stuff and things that make it better.
    Atomatics only...:pout:
  16. Jan 23, 2019 at 4:12 AM
    #676
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    The only difference is the input shaft oil seal housing IIR.
  17. Jan 23, 2019 at 9:13 AM
    #677
    Spoonman
    Jamie
    Alberta
    For the 3.4 it fits both auto and manual! Yay!
    Prayn4surf likes this.
  18. Jan 23, 2019 at 9:40 AM
    #678
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    The motor to gear drive case adapters are back in stock on everything but the gear case doubler adapter is out of stock again
  19. Jan 23, 2019 at 11:17 AM
    #679
    SGTCap
    SGTCap Well-Known Member
    Cap
    Summerville, SC
    4x4 6-spd,
    37s, 4x4 6-spd, OME 886s, Allpro Expos, SOS sliders and front/rear bumpers,Rack,Skids, 4.56s, Lockers,Recon Winch, TJM RTT, Lots of tools, boxes and gear. Shaggy mutt behind the seat
    If their supply could meet demand they would have a monopoly on this market.
  20. Jan 30, 2019 at 11:29 AM
    #680
    Nate87
    Nate87 Well-Known Member
    Nate
    CONUS
    2013 AC TRD OR
    Dave’s Drive shop is in Nashville. He’s about $125 to extend front and you’d have to figure what to do with the rear. You can try and shorten the factory two piece rear or go for a new one piece. He'll use as much of the factory stuff as he can.
    I’m in SoCal and went with a one piece and things are great. No vibration issues. Not sure how much varriance there’d be with all the different boxes and adaptors, but whichever you choose I’m sure one of us here with the same setup could measure ours out for you to have an idea of length.
    ThunderOne[QUOTED] likes this.
