Official Crawlbox BS thread!
Discussion in 'Technical Chat' started by HomerTaco, Mar 16, 2016.
  1. Mar 17, 2019 at 5:05 PM
    #741
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    Yes that is correct. Just looking at alternatives to the MC as that seems to be the only built unit available today.
  2. Mar 17, 2019 at 5:14 PM
    #742
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    Why not just just build one yourself with TG plates and a donor box? Honestly building the case is probably one of the easier parts of installing duals
    jubei and ovrlndkull[QUOTED] like this.
  3. Mar 17, 2019 at 5:20 PM
    #743
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    That is kinda my thought. And I would completely get rid of chain drive tcase and go with a gear driven one. Since I can't find an adapter to go back to either the tacoma/fj case after the doubler.
  4. Mar 17, 2019 at 5:31 PM
    #744
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    I didn’t realize TG didn’t make a gear drive to second gen chain drive adapter...bummer. Then your either into a verso or Atlas territory to keep your stock rear case. You could always put a first gen chain drive case in too...they are pretty cheap from yards.
  5. Mar 17, 2019 at 5:37 PM
    #745
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Putting a gear driven case in wouldn't hurt my feelings either. I would like the ability to clock it some.
  6. Mar 17, 2019 at 6:21 PM
    #746
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    x2 I doubt the 2nd gen case is substantially stronger then the 1st gen tacoma chain drive. Just a slightly different bolt mounting pattern. Plus most guys with crawl boxes do away with the electronic 4x4 and go manual anyway which is what the 1st gen t cases mostly are.
    G.T. likes this.
  7. Mar 17, 2019 at 7:01 PM
    #747
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    I'll research more into the 1st gen case situation. But getting an old gear drive case doesn't seem too hard either.
  8. Mar 17, 2019 at 7:10 PM
    #748
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    Older gear drive cases are passenger drop. You need a driver drop case on IFS
  9. Mar 17, 2019 at 7:11 PM
    #749
    HomerTaco
    HomerTaco [OP] also HomerTaco Vendor
    HomerTaco
    HomerTaco
    HomerTaco
    Troof
    ovrlndkull likes this.
  10. Mar 17, 2019 at 7:12 PM
    #750
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Gotcha :thumbsup:. So I need to figure out if the 1st gen case will hold up to the 4.0l then it would be on!!!! Less $$$$ and wait over a MC set up
  11. Mar 17, 2019 at 7:20 PM
    #751
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Just went looking for the Verso apparently it's Kaputz too.
  12. Mar 17, 2019 at 7:55 PM
    #752
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    It’s the same vf2a/b transfer case with a different pattern on the front to mate to the 750f trans
    ovrlndkull[QUOTED] likes this.
  13. Mar 17, 2019 at 8:02 PM
    #753
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Nice!
  14. Mar 18, 2019 at 4:16 AM
    #754
    SGTCap
    SGTCap Well-Known Member
    Cap
    Summerville, SC
    4x4 6-spd,
    37s, 4x4 6-spd, OME 886s, Allpro Expos, SOS sliders and front/rear bumpers,Rack,Skids, 4.56s, Lockers,Recon Winch, TJM RTT, Lots of tools, boxes and gear. Shaggy mutt behind the seat
    Good tip, but damn I hope that isn't it, lol. Although it doesn't sound unlikely. How did you diagnose that this was the problem? What adapter were you using? Mine's an Inchworm and I have it clocked at 15degrees.
  15. Mar 18, 2019 at 8:49 AM
    #755
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    Getting to the top of the tcase would be the best way to figure it out but probably not the easiest if you didn’t cut your floor. Then you can work the shifter base without the linkage and make sure the ball of the shifter is in the shift rail, and see if the rail is moving correctly. Otherwise you can play with the linkage length to see if that fixes it. No easy way otherwise.
  16. Mar 18, 2019 at 10:44 AM
    #756
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    I have an inchworm. And it was a guess that was the problem. The shifter wouldn’t budge at all and that’s the only reason why. Once i loosened the bolts and rotated it slightly I was able to shift it in low
  17. Mar 18, 2019 at 11:20 AM
    #757
    SGTCap
    Cap
    Summerville, SC
    4x4 6-spd,
    I'm definitely thinking about cutting another hole in the floor and just patching it when I'm done adjusting linkage, and getting this thing to work.
  18. Mar 18, 2019 at 8:54 PM
    #758
    6 gearT444E
    Deep South
    Herculiner Hootus
    man with all these crawlbox shortages I'm wondering how much coin I could get for a merlin setup if I part mine out LOL
    hoverlover, HomerTaco[OP] and TacoFMS like this.
  19. Mar 19, 2019 at 7:33 AM
    #759
    ToyRyd04
    Greg
    Perryville, MD
    '04 PreRunner
    Jiveydude likes this.
  20. Mar 24, 2019 at 2:27 PM
    #760
    Jonyd182
    Jonyd182 What do you mean I can't go up there...Watch this!
    Jonathan
    Columbia, SC
    '99 SR5 TRD 3.4
    Armored to the teeth, 35's, Crawlbox, Boxed Frame
    That's what I did. Without a body lift and the triple sticks there is just no room for the linkage. I spoke with RADesign a couple of times through the install and he said a lot of people cut 2 one inch channels into the floor to make room for the linkage back to the stock t-case.
    He mentioned that a couple of people said they were able to create enough clearance by using a Thor hammer from below but he thought that was highly unlikely without a body lift.
    malburg114 likes this.
