Official Crawlbox BS thread!
Discussion in 'Technical Chat' started by HomerTaco, Mar 16, 2016.
  1. Mar 30, 2019 at 12:21 AM
    #781
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Gotcha. Guess that will limit my shifter placement options as well.
  2. Mar 30, 2019 at 7:12 AM
    #782
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    The old crawlboxtacobox models from Marlin and Inchworm were clock able "360*". But with issues sealing, that has gone away to just a normal 0* mounting for the chain drive tcase.
    Spend some time looking in the Crawlbox thread on here. Lots of good tech information. Also look into RADesigns triple stick setup. I used this setup and then modified it to get the placement of my shifters. Aka getting the shifters to come through a single couple holder, clearance, etc.
  3. Mar 30, 2019 at 7:43 AM
    #783
    HomerTaco
    HomerTaco [OP] also HomerTaco Vendor
    HomerTaco
    HomerTaco
    HomerTaco
    I had a nearly identical experience.
    ovrlndkull and ToyRyd04 like this.
  4. Mar 30, 2019 at 7:48 AM
    #784
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    No more clickable cases, they were leaky and tricky to install.
    Shifters land where they land unless you want to go to a linkage setup like Radesigns. I kept mine single stick, straight through the floor so that I always knew it was going to work and I wouldn’t be laying under my truck messing with a linkage on the trail. Pic below...excuse my groceries lol.
    Theoretically you shouldn’t have to mess with your belly pan. Depends on how much of an angle the stock engine and tcase sit. The crawler doesn’t lower it at all by design, just pushes it straight back
  5. Mar 30, 2019 at 9:19 AM
    #785
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I'll have to figure out how to make it only take up a single cup holder since I don't have the console with the side cup holders like yours. I think I can make it work though! We'll see. Good point about the reliability
  6. Mar 30, 2019 at 10:26 AM
    #786
    02hilux
    Planet: EARTH
    After an hour or so, you'll be cursing by the time you bend the shifter to fit so it won't bind :thumbsup:
    ThunderOne likes this.
  7. Mar 30, 2019 at 7:48 PM
    #787
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    So I was looking through this thread: And saw triple stick setup all stuffed into the stock location. 5 speed with j shift. Wondering how to accomplish this with a non triple stick setup?
    hoverlover likes this.
  8. Mar 30, 2019 at 7:53 PM
    #788
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    There’s some custom linkage hiding under that floor...
  9. Mar 30, 2019 at 7:55 PM
    #789
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Yeah I know, I think the place he ordered from is out of business because the website 404s.
    Saw this:
    https://www.davezoffroadperformance.com/store/triple-shifter.html
    Would I need to get the "forward shift crawl box" option? Or is dual stick not an option and I have to use triple sticks to get everything in the shifter area?
  10. Mar 30, 2019 at 8:04 PM
    #790
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    jubei likes this.
  11. Mar 30, 2019 at 8:11 PM
    #791
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
  12. Mar 30, 2019 at 8:12 PM
    #792
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    So does triple stick basically "convert" a j shift pattern from the stock tcase to two front/back shifting sticks (one for 2/4wd and one for hi/lo)?
    That's the only way to get all the shifters in the factory location?
    Also I guess I just used a bad link bc their website is still up
    http://www.radesignsproducts.com/triple---twin-sticks.html
  13. Mar 30, 2019 at 8:49 PM
    #793
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Now I'm reading you cant convert a j shift to twin sticks. Hmm.
  14. Mar 30, 2019 at 9:22 PM
    #794
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    Keep researching.
    You can convert a j-shift case to twin stick by removing the interlock pin and filing down the shift rails to allow them to clear each other. It needs to be done for triples as well. I went with a single crawl box shifter and twins coming up through a cup holder. I also have an auto which is way harder to make triples work with or I might have gone that route. I had Radesigns make my twin stick set-up and it's a quality piece of hardware. If you want to have the Radesigns Triples call or email Rory and ask him for a copy of the install directions.
    Whatever set-up you end of going with for shifters you might also want to pick up a spare j-shift case. I did for a few reasons. One is that my rig is also my DD. Two is that it allowed me to build the duals on my bench and test everything before install. Three is that I now have a spare stock case and driveshafts. If my duals ever fail all I have to do is pull them and put my stock case and shafts back in to get it on the road again.
  15. Mar 30, 2019 at 9:34 PM
    #795
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Thanks and good point on having a spare tcase. If going triple sticks is the only way to get everything in the factory location then I'll likely go that route. I'll def email him and get a copy of the installation manual so I can see what all is involved.
  16. Apr 1, 2019 at 6:42 AM
    #796
    ToyRyd04
    Greg
    Perryville, MD
    '04 PreRunner
    Can definitley convert a chain drive tcase. - https://frontrangeoffroadfab.com/twin-stick/
    Triple sticks really allows you to have all the shifters (crawlbox shifter in the center, factory tcase L-H on the left, factory 2-4wd on the right) all in a neat packaged area without having shifters everywhere. Your crawlbox will always need to be a top shift tcase, when you receive your tacobox from marlin, this will already be setup.
    @ThunderOne You will need todo 2 different steps, first being modify your tcase to allow for the shift rods to fully move independent of each other (aka grinding the numb down and removing the shift lock deten pin (pill)) After that you will need to grind the shift rail flush on top to remove the top numb that is in most of the shift rail castings. (see RADesigns install below) . Then you will use the triple sticks bracket bolted to the crawlbox shifter housing and will relocate your factory tcase shifters using threaded rods and rod ends.
    This pic from RAD designs shows the triple stick mounting based attached to the crawlbox housing. Then center shifter is strictly (L-N-H) for the crawlbox only, either engaged in low or disengaged in 1:1 high. The threaded rods and rod ends relocate where the shifters normally would be on the factory chain tcase and relocate them to the shifter base on the crawlbox.
    Install info from RADesigns http://nebula.wsimg.com/ee317827726...BA896CE942FEBA752&disposition=0&alloworigin=1
  17. Apr 1, 2019 at 7:50 AM
    #797
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    hey thanks! Do I need to order a triple stick kit if I already get a shifter that comes with Marlin's tacobox or do I just need to order the "twin stick" kit to convert my tcase only? (like what you linked first)
    EDIT nevermind, I see that a triple stick kit is required because the twin stick doesn't have a spot in the middle for the crawlbox shifter
  18. Apr 1, 2019 at 8:32 AM
    #798
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    2019 Raptard 2001 TJ
    Dirt
    So hopefully someone here has ran into this and has a solution
    I have this sitting and home ready to install
    but then I pulled my transfer case to find this It appears to be a j shift but with a forward shifter
    (not my picture, but mine looks the same)
    I guess the question is can I just cut the front rails and (try to) drill a hole to move the shift fork into the rear opening or what else can I do?
  19. Apr 1, 2019 at 9:01 AM
    #799
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    @ToyRyd04 do you know if there are any other write ups on 1st gen triple stick install? Mostly wanting to see better pics of this part:
    also did you need to beat back the tranny tunnel any or did you already have a BL?
    also also.. in the pic you posted I'm seeing a breather going from the tcase to the tranny? Is that what a lot of people do?
  20. Apr 1, 2019 at 9:25 AM
    #800
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    01 2.7 manual. Trying to order a doubler.
    Marlin is telling me the I4 case is 26 spline and I’ll need to swap to a 23 spline transfer case from a V6 truck. Is this accurate?
