Official Crawlbox BS thread!
Discussion in 'Technical Chat' started by HomerTaco, Mar 16, 2016.
  1. Mar 4, 2020 at 5:46 PM
    #1481
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    how long after sealing the cases did you fill with oil?
  2. Mar 4, 2020 at 5:58 PM
    #1482
    6 gearT444E
    Deep South
    Herculiner Hootus
    that is where everyone’s leaks, that’s how you check there’s still oil in the crawl box. If it stops leaking that’s when you know you’re in trouble and have to add oil
    digitalferg, G.T., slander and 4 others like this.
  3. Mar 4, 2020 at 6:01 PM
    #1483
    HomerTaco
    HomerTaco [OP] also HomerTaco Vendor
    HomerTaco
    HomerTaco
    HomerTaco
    Welcome to the club! :D
  4. Mar 4, 2020 at 6:02 PM
    #1484
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    :laughing:
    slander likes this.
  5. Mar 4, 2020 at 6:02 PM
    #1485
    wrmathis
    Bonaire, GA
    parts and stuff
    meh. mines pretty much leak free. every time i seal and fill i let the ultra gray cure and sit for a few hours before adding any oil to the box. thing this helps a lot IMO
    Bigdaddy4760 and theesotericone like this.
  6. Mar 4, 2020 at 6:06 PM
    #1486
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    Not my TG set-up. lol
  7. Mar 4, 2020 at 6:10 PM
    #1487
    6 gearT444E
    Deep South
    Herculiner Hootus
    mines actually to the point that the dirt and extra rtv keeps mine sealed. Speaking of which, I should check to see my oil level again after draining and adding new oil.
    they have a differently designed adapter plate. The Merlin one which farms it out to minchworm, which combined with low range, now sells all the same design. Back in the day before a crawl box was hip, the adapters weren’t as nice.
    TacoFMS likes this.
  8. Mar 4, 2020 at 6:14 PM
    #1488
    theesotericone
    Bishop CA
    Yeah, I know the history. I also find it funny that a lot of people have no problem shitting all over TG about being inferior. Yet, they don't leak and I had my adapters in 2 weeks. 3 years of wheeling later I've yet to have a single issue with mine. lol
  9. Mar 4, 2020 at 6:19 PM
    #1489
    6 gearT444E
    Deep South
    Herculiner Hootus
    trail gear is like the harbor freight of truck parts, nobody likes to admit they use them but they get great reviews and they are always in stock, and in a lot of cases just as good or better than other names for the price.
  10. Mar 4, 2020 at 6:22 PM
    #1490
    wrmathis
    Bonaire, GA
    parts and stuff
    the only issues i have had with my inchworm is that the double row bearing pooped out a ball bearing. replaced with the MRC bearing and its been great. when i seal mine, i put one adapter on at a time and let it cure before putting the next piece on and make sure that there isn't any stress on the mating surface and then finally adding oil way later. once i started doing that, i haven't had any issues with leaks
    TacoEspecial likes this.
  11. Mar 4, 2020 at 6:54 PM
    #1491
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    Same story here. Zero leaks or problems in 5 years. I don’t even let the RTV setup before I fill with oil anymore and it still doesn’t care.
  12. Mar 4, 2020 at 7:21 PM
    #1492
    hoverlover
    hoverlover Never pet a burning dog.
    C-137, Laniakea, Virgo, Milky Way, Earth, USA, TX
    Things. Stuff. Lots of bad decisions.
    Mostly Zip-Ties
    A day but to be fair, I did not seal up that area from the outside. It's draining, I'll clean it all up and reseal it in the morning I guess.
    Haaa! Like a dirt bike I guess
    :fistbump:
    I'm concerned about that bolt though. I've not seen anyone elses leak from that bolt. Since that bolt is more or less worthless, I think I'll just clean it out really good and seal it up. Think some JB weld is a bad idea?
  13. Mar 4, 2020 at 7:24 PM
    #1493
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I'd stick with permatex but that's me.
  14. Mar 4, 2020 at 7:30 PM
    #1494
    hoverlover
    Mostly Zip-Ties
    I'm thinking I'll just fill the whole thing up. That bolt grabs like 2 threads anyway.
  15. Mar 4, 2020 at 7:45 PM
    #1495
    theesotericone
    Bishop CA
    hoverlover[QUOTED] likes this.
  16. Mar 4, 2020 at 8:19 PM
    #1496
    hoverlover
    Mostly Zip-Ties
    Does anyone else have a leaking bolt though?
  17. Mar 4, 2020 at 8:24 PM
    #1497
    Littles
    Littles Stupid is as stupid does.
    Bryan
    Elizabeth, CO
    3 tons of fun
    Several people have convinced me that the bottom bolts aren't required. One of mine is missing because I didnt realize you had to drill out the threads on the bellhousing and thread it through the opposite way, and the other is bottomed out in the marlin adapter with 1/4" of the bolt showing.
    Seal it up real nice and try not to think about it.
  18. Mar 4, 2020 at 8:32 PM
    #1498
    theesotericone
    Bishop CA
    What the hell man? At least stack some washers on that bolt so it gets some bite. If you're gonna half ass shit at least half ass it right. lol
    hoverlover likes this.
  19. Mar 4, 2020 at 8:33 PM
    #1499
    hoverlover
    Mostly Zip-Ties
    I put in the driver's side bolt and it felt like it was about the strip with a stubby wrench so I stopped. I've seen a few guys skip the bottom bolts so I decided not to drill out the passenger side and threaded a bolt in anyway for torque-shear tension. That one seems good.
    I guess I'm a bit concerned that I went in too deep with the driver's side and that's why it's leaking. I was pretty annoyed that a $2k gearbox leaks like a stuck pig but I got a taste of that sweet, sweet low-low action earlier and my concerns just whisped away. RTV the shit out of everything and crawl on!
  20. Mar 4, 2020 at 8:34 PM
    #1500
    hoverlover
    Mostly Zip-Ties
    lol note the extra washers in my pic :laughing:
