Official Crawlbox BS thread!
Discussion in 'Technical Chat' started by HomerTaco, Mar 16, 2016.
  1. Apr 21, 2020 at 9:17 AM
    #1581
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    ^^^ Yikes.
    Case in and crossmember and mounts complete, just need to get the interior back together.
    jubei, Littles, hoverlover and 2 others like this.
  2. Apr 21, 2020 at 6:41 PM
    #1582
    Mothman
    Mothman Well-Known Member
    Advance
    single cab
    Low and slow.. chopped up on 35s
    Dude.. what's the overall length from tranny with adapter to rear output?
  3. Apr 21, 2020 at 9:22 PM
    #1583
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    16.25” from tranny face to flange.
  4. Apr 22, 2020 at 8:36 AM
    #1584
    Mothman
    Advance
    single cab
    Thanks! That will let me know if I can clear my rear link cross member
  5. Apr 28, 2020 at 7:16 AM
    #1585
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    So finally took the runner out for a spin and everything seems to work! However, the VSC and TRAC lights are on with the CPU disconnected. Below is a pic of mine, any ideas on what wiring weds to be done to get the dash lights off? I haven’t cut the harnesses that went to the tcase or the ADD yet, so if reconnecting the module and jumping wires at the ADD or tcase end would be easiest, that would be simple instead of working under the dash.
  6. Apr 28, 2020 at 8:53 AM
    #1586
    hoverlover
    hoverlover Never pet a burning dog.
    C-137, Laniakea, Virgo, Milky Way, Earth, USA, TX
    Things. Stuff. Lots of bad decisions.
    Mostly Zip-Ties
    Have you tried to reset the VSC computer?
    Mine will come on sometimes after a trail run.
  7. Apr 28, 2020 at 9:11 AM
    #1587
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Yeah, I have disconnected the battery a few times. If I leave the CPU plugged in (tcase and ADD not attached) 4lo/hi blink rapidly. Im thinking I just need to connect a few wires on the tcase and add to trick it to think they are still connected.
    I found this post: https://www.tacomaworld.com/threads/tacoma-add-delete-wiring-figured-out.464595/
    with this diagram and pin out:
    The ADD has 6 wires that control the action as well as engagement/disengagement confirmations. Your wires may differ in color but this is what i had on my 2008. This is how my wires came in the ADD connector.
    1 - Red - Power for ADD motor
    2 - Black/white stripe - Ground for ADD motor
    3 - Green/black stripe - ADD engagement confirmation
    4 - White/black stripe - ground for confirmation wires
    5 - Pink/blue stripe - (I believe this is power cut for ADD motor)
    6 - Green - ADD disengaged confirmation
    In 2wd, 4 connecting to 6.
    So, I think on the ADD end connecting 4 and 6 should take care of the ADD, just need to figure out the tcase end.
  8. Apr 28, 2020 at 9:29 AM
    #1588
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Here is the diagram for my 4R, if anyone has any input it would be appreciated, I am pretty good at wiring, just not reading/comprehending wiring diagrams lol.
  9. Apr 28, 2020 at 11:53 AM
    #1589
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    @6 gearT444E got banned
  10. Apr 28, 2020 at 12:01 PM
    #1590
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Again! Jeeze.
    I plugged the ADD back in and seemed to make no difference so must be on the Tcase side of things.
  11. Apr 28, 2020 at 12:45 PM
    #1591
    wrmathis
    Bonaire, GA
    parts and stuff
    passed along the info
    0A3443F5-EB50-4677-B9A9-1CB60C941CB3.jpg F17896E1-0E5D-4118-AA2C-779EF05FC7CD.jpg
  12. Apr 28, 2020 at 1:24 PM
    #1592
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Thanks, I don.t want to mess with limit switches though lol. Surely there is a way to hot wire this thing!
  13. Apr 28, 2020 at 1:35 PM
    #1593
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    So reread, I do have everything disconnected and still get the VSC TRAC lights, IDK, maybe has to do with the center diff?
  14. Apr 28, 2020 at 1:45 PM
    #1594
    wrmathis
    Bonaire, GA
    parts and stuff
    Could. U got techstream at all? Could pull the codes with it and figure out what it’s in relation too
  15. Apr 28, 2020 at 1:52 PM
    #1595
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    I have an ODB, but it just does engine codes I think, I don't seem to remember it picking up ABS/VSC codes. I'll check.
  16. Apr 28, 2020 at 2:27 PM
    #1596
    wrmathis
    Bonaire, GA
    parts and stuff
    Techstream does all the codes and it’s nice to figure things out. Abs/vsc/trac is real useful with techstream
  17. Apr 28, 2020 at 4:04 PM
    #1597
    v5ensx
    v5ensx CARB legal is not CALI legal
    Toyota with their leaks... Atlas with their electrical issue... Every unit have their own unique problem...
  18. Apr 28, 2020 at 5:43 PM
    #1598
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Electrical? If your referring to my issue, that’s a Toyota problem in my book. I just want all that crap to stop working.
    Littles likes this.
  19. Apr 28, 2020 at 6:01 PM
    #1599
    02hilux
    Planet: EARTH
    who cares if the lights are on. You know it's working already. That's just me.
    Getting these mod (crawlbox, atlas, solid axle, etc) done will have one problem or another.
    slander likes this.
  20. Apr 28, 2020 at 6:14 PM
    #1600
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    For sure, just trying to take care of the small stuff along the way if it can be done reasonably.
