Official Crawlbox BS thread!
Discussion in 'Technical Chat' started by HomerTaco, Mar 16, 2016.
  1. Jul 27, 2020 at 4:51 PM
    #1741
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Low gears are the best mod ever. It's amazing what an IFS (1st gen) tacoma on 33s with a rear locker and crawl box can do!
  2. Jul 27, 2020 at 4:52 PM
    #1742
    slander
    Hickory, NC
  3. Jul 27, 2020 at 5:19 PM
    #1743
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    It was a bitch to fit and took forever, but worth it in the end.
    jubei and slander[QUOTED] like this.
  4. Jul 27, 2020 at 6:07 PM
    #1744
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    Once my wife goes back to work the LV3/6L90/Atlas fund kicks into full gear right after...
    We buy new furniture
    and a new dually
    and the shop gets finished
    and a 2-post lift....
    Fuck, that’s is going to be a long time... :(
  5. Jul 27, 2020 at 7:10 PM
    #1745
    slander
    Hickory, NC
    Yea it will LOL!!!
  6. Jul 27, 2020 at 9:22 PM
    #1746
    rctoy
    rctoy It's about to get real!!!
    konstantenos
    Pocatello Idaho
    First gen 4door monster in progress
    TRD super charger, URD fuel mods and 2.1 super grip pully, Headers, 2.5" glass pack, Dana 60 front 4 linked, 14bolt rears on chev 63's, 5.38 gears, ARB locker in the front, PSC full hydraulic steering, 18" SAW 2.5" triple rate coils overs, FOA 2.5 air bumps, B&M launch controls, B&M trans cooler, 4 alpine 6X8 type R's amped, Red led rock lights, CBI front and rear bumpers (my design) CBI sliders, 4 riggid dualys front 2 in the rear, custom track bar, ARB snorkle, warn VR8000 winch, Viair 480c twin compressers..
    I did mine with out welding the floor pan but now that I'm adding in the back box and a longer transmission it's a must.
  7. Jul 29, 2020 at 5:32 AM
    #1747
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    Most of your planned info looks good. One word of advise, when building the internals (4.7s, spline coupler, etc.) stick to the same manufacture All TG or ALL Marlin as they are not interchangeable. Okay to mix and match tcase/trans adapters but the gear's splined input themselves are cut different. Also skip Davez...nothing but bad service. You can read info online about it, speaking from personally having to deal with it too. RAD is they way to go with their setup. Its nice and you can customize it to your liking.
  8. Jul 29, 2020 at 9:11 AM
    #1748
    HomerTaco
    HomerTaco [OP] also HomerTaco Vendor
    HomerTaco
    HomerTaco
    HomerTaco
    x2 on this
    hoverlover and Bigal90 like this.
  9. Aug 2, 2020 at 5:28 PM
    #1749
    papabeach
    papabeach Member
    Getting ready for install...just waiting on a couple pinion seals. I found I had this leftover rectangular pin in my parts bag from Marlin Crawler...this was one of the Marlin units that shipped with Inchworm adapters. Any idea where this goes?
  10. Aug 2, 2020 at 5:34 PM
    #1750
    6 gearT444E
    Deep South
    Herculiner Hootus
    thats the key stock that gets welded to the crawl box shift fork.
  11. Aug 2, 2020 at 5:34 PM
    #1751
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    Looks like it might be a syncro key. There's 3 of them in the stock case. Hard to tell for sure at that angle though.
    papabeach[QUOTED] likes this.
  12. Aug 2, 2020 at 5:40 PM
    #1752
    ToyRyd04
    Greg
    Perryville, MD
    '04 PreRunner
    Definitley key stock for the crawlbox shifter that gets welded to the shift fork rail to create a closed hole for the end of the shifter. Remember welding this when I did mine.
    The synchros have a step down taper that this does not have.
    papabeach and theesotericone like this.
  13. Aug 2, 2020 at 5:41 PM
    #1753
    papabeach
    papabeach Member
    Hmm...this is what it looks like. I am guessing MC modified it prior to shipping and because it came with Inchworm adapters they just sent a "standard" parts bag. ???
  14. Aug 2, 2020 at 5:47 PM
    #1754
    02hilux
    Planet: EARTH
    If you bought a fully assembled tacobox from marlin, that piece should be welded to the shift rail by marlin.
    hoverlover and jubei like this.
  15. Aug 2, 2020 at 5:49 PM
    #1755
    02hilux
    Planet: EARTH
    Correct, mc probably grab a general tacobox parts package and shipped it to you along with the crawl box.
  16. Aug 2, 2020 at 5:57 PM
    #1756
    tetten
    tetten Cynical Twat Waffle
    Andy
    Socal
    As was already stated that is likely the key stock for the shift fork. I had the same "extra part" last year when I installed mine, I called Marlin to figure out what it was, they said basically if your box is shifting fine its already welded installed.....it freaked me out since I had already installed everything before calling about it.
  17. Aug 2, 2020 at 6:08 PM
    #1757
    6 gearT444E
    Deep South
    Herculiner Hootus
    Looks like extra parts, I hate it when that happens. You should be good to go since it’s already welded in there.
  18. Aug 2, 2020 at 6:08 PM
    #1758
    papabeach
    papabeach Member
    Much appreciate it...not the time I want to find out I forgot something! Cheers brotha!
  19. Aug 2, 2020 at 6:12 PM
    #1759
    theesotericone
    Bishop CA
    Don't forget to anti-seize or RTV the trans output to the coupler then the crawlbox input to the coupler.
  20. Aug 3, 2020 at 5:12 AM
    #1760
    ToyRyd04
    Greg
    Perryville, MD
    '04 PreRunner
    6 gearT444E likes this.
