Official Crawlbox BS thread!
Discussion in 'Technical Chat' started by HomerTaco, Mar 16, 2016.
  1. Aug 15, 2020 at 7:42 PM
    #1801
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
  2. Aug 15, 2020 at 7:43 PM
    #1802
    Spoonman
    Jamie
    Alberta
  3. Aug 15, 2020 at 8:33 PM
    #1803
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Elaborate for the noobs homie???
  4. Aug 15, 2020 at 8:52 PM
    #1804
    02hilux
    Planet: EARTH
    Nope, don't waste your money. You can built your own for about the same price with 4.7s
    Fernando[QUOTED] likes this.
  5. Aug 15, 2020 at 9:03 PM
    #1805
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    No shit? Im about to meet with dude tommorow?
  6. Aug 15, 2020 at 9:04 PM
    #1806
    Spoonman
    Jamie
    Alberta
    2.28 gears in the dual case. Only get it if you plan on putting 4.7s in. 2.28 is nothing to phone home about, and not a true crawlbox.
  7. Aug 15, 2020 at 9:25 PM
    #1807
    02hilux
    Planet: EARTH
    MC 4.7xD ~$600
    MC 23/23 couple ~$120
    TG Tacoma adapters ~$800
    Top shift RF1A ~$200
    Forget that 2.28 nonsense.
    Winkle99 likes this.
  8. Aug 16, 2020 at 5:22 AM
    #1808
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Well damn. Thanks guys!
  9. Aug 16, 2020 at 3:09 PM
    #1809
    GDESMOND1976
    GDESMOND1976 Desmo
    Geoff
    TEXAS
    2020 TRD SPORT, WHITE, RWD
    WEATHERTECH FLOOR MATS, DESMO OVERLAND STAINLESS TRD FLOOR MAT LOGOS, 3" READY LIFT, TINTED WINDOWS, BLACK RHINO ARMORY WHEELS 17X9.5/-18 OFFSET, YOKOHAMA GEOLANDER MT 33-12.5/17 TIRES, TRD PRO GRILL W/ 4 AMBER LED LIGHTS, CUSTOM VINYL HOOD STAMP, TEQ GRILLE BADGE, STEERING WHEEL BADGE WHITEOUT COVER, TACOMA TAILGATE LETTERS, DESMO OVERLAND CS CONNECT MOLLE, DESMO OVERLAND HL CONNECT MOLLE, ORCA TACTICAL MOLLE RIP-AWAY EMT MEDICAL FIRST AID POUCH, ORCA TACTICAL MOLLE H20 MULTI-CAMO WATER BOTTLE POUCH, RYMMES GUN MAGNET MOUNTS, IGLOO IMX 72 QT COOLER/BED MOUNTED.
    whats with all of the shifters?
  10. Aug 16, 2020 at 3:13 PM
    #1810
    02hilux
    Planet: EARTH
    Crawl box mod, the best thing a man can get in his toy truck, lol. Middle shifter is for the front case (crawlbox 2.28 or 4.7 ratio), left shifter hi/lo while the right shifter is for 2wd/4wd.
    HomerTaco[OP] likes this.
  11. Aug 16, 2020 at 3:22 PM
    #1811
    HomerTaco
    HomerTaco [OP] also HomerTaco Vendor
    HomerTaco
    HomerTaco
    HomerTaco
    ^^^ what he said ^^^
    Fernando and 02hilux[QUOTED] like this.
  12. Aug 16, 2020 at 6:00 PM
    #1812
    GDESMOND1976
    GDESMOND1976 Desmo
    Geoff
    TEXAS
    cant you get all of that in one transfer case with one shifter?
  13. Aug 16, 2020 at 6:08 PM
    #1813
    StevenP
    StevenP Well-Known Member
    Steven
    Alta, Ca
    2003 Tacoma DCSB TRD
    Build thread in Signature
    Not quite. You need to twin stick to shift 2/4wd and l/n/h independently of each other on the stock tcase, this gives you more “gears” so to speak, like 2wd/lo.
    You can totally do a crawlbox without twin sticking the t case, but it’s sort of one of those mods that fits the bill of “while I’m in there”.
    If you didn’t twin stick then you would just have one additional stick, from the crawl box, for a total of two (stock tcase shifter, crawl box shifter).
  14. Aug 16, 2020 at 6:18 PM
    #1814
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    i had twin sticks and i replaced my tcase cuz it was cracked and leaking (from getting rtv in some of the bolt holes and blowing out the back side, not from anything else. totally my fault) i didnt feel like opening up the new case so i didnt twin stick it. also didnt feel the need since the purpose of twin sticks is to have 2 lo. well if i put the crawl box in lo, i have 2lo. i hardly ever used the lo in the stock tcase even out wheeling
    slander likes this.
  15. Aug 16, 2020 at 6:32 PM
    #1815
    02hilux
    Planet: EARTH
    Each case will required 1 shifter. Generally speaking, you just need 2 shifter for the 2 case. But most perfer triple stick because you don't have to cut the floor board for the second case.
  16. Aug 23, 2020 at 10:45 PM
    #1816
    ToyotaBurrito
    ToyotaBurrito Well-Known Member
    2013 AC Sport MT
    Hello Crawlers:
    I recently acquired a 2nd gen MT with a Tacobox. It leaks oil (about 12-16oz/500mi) and I'm 99% certain it's coming out the top, which after talking to Kyle at MC, leads me to believe the oil sling wasn't installed. I have an oil sling plate from MC and will be going to a DIY type garage with a lift this week to attempt to install. When I called MC to inquire about instructions they were only able to supply the general install instructions.
    Does anyone know if I need to separate the transfer case from the Tacobox or can I disconnect the driveshaft and lower them both as one unit (i'll have a transmission jack available)? Any ideas how long this will take? Any special tools required that I'm forgetting?
    Thanks for reading!
  17. Aug 23, 2020 at 11:45 PM
    #1817
    wrmathis
    Bonaire, GA
    parts and stuff
    U can lower as one unit. Don’t need to separate unless you are bench pressing that shit up and down. Only then would it make sense.
    Also, you should be able to install the oil sling thing if it’s the part that goes between the shift base and crawl box without dropping anything. Assuming they cut a hole big enough in the top.
  18. Aug 24, 2020 at 5:37 AM
    #1818
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    You dont even need to remove the crawlbox/tcase.
    Easiest and fastest way to access this is by taking off the center console and working your way down until you find the shift lever base. Oil sling is directly underneath that. No garage needed, only basic hand tools and some FIPG/RTV . Believe those (4) are 10mm/12mm bolts.
    Actual replacement shouldn't take more then 5mins, plus however long it takes to pull the interior console.
  19. Aug 24, 2020 at 8:15 AM
    #1819
    ToyotaBurrito
    2013 AC Sport MT
  20. Aug 24, 2020 at 7:14 PM
    #1820
    6 gearT444E
    Deep South
    Herculiner Hootus
    thats one spot I like using the paper gasket on
    It’s also not a slinger it’s an oil deflector. 36345-35050 is the part order two of these they’ll go on the top and bottom side of the deflector which is P/N 3610835060. Only reason is that it’s easier cleanup if you need to replace such as in your case without having to try and sneak a razor blade in there to clean the shift lever housing.
