Official Crawlbox BS thread!
Discussion in 'Technical Chat' started by HomerTaco, Mar 16, 2016.
  1. Sep 30, 2020 at 8:30 AM
    #1941
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    Solid axle passenger drop case.
    Fernando[QUOTED] and malburg114 like this.
  2. Sep 30, 2020 at 8:32 AM
    #1942
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    It’s passenger drop just pre Tacoma cases. Unless you build a lefty which is stupid expensive and atlas territory money wise I don’t think there’s a way to get 4.7 gears in the rear case.
  3. Sep 30, 2020 at 8:48 AM
    #1943
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Ah. Ok. Thanks guys!
  4. Sep 30, 2020 at 9:03 AM
    #1944
    02hilux
    Planet: EARTH
    You got what many consider a dual case setup also: 4.7x2.57
    It's just preferred (stronger as many will say. Why, IDC) 2.28x4.7
    Many prefer the crawl gear (4.7) to be in behind the factory gear (2.28) but in the tacoma standard, it's not an option.
    Just like anything else, stuff will break if you use the "send it" method
  5. Sep 30, 2020 at 9:59 AM
    #1945
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Ok. So many prefer 4.7x4.7 for lower gearing if i am understanding correctly
  6. Sep 30, 2020 at 10:28 AM
    #1946
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    common config is 2.28 (or 2.57 in yours and my case) paired with 4.7. Nobody really does 4.7's in both cause that's too much low range. Not really usable at that point imo.
    And only way you'd be able to do that is if you have both gear drive cases.
  7. Sep 30, 2020 at 11:05 AM
    #1947
    02hilux
    Planet: EARTH
    not true. What about triple?
    TacoEspecial likes this.
  8. Sep 30, 2020 at 11:06 AM
    #1948
    02hilux
    Planet: EARTH
    4.7x4.7 will be awesome! Maybe one day:fistbump:
    Fernando[QUOTED] likes this.
  9. Sep 30, 2020 at 11:12 AM
    #1949
    betterbuckleup
    Ian
    Concord, CA
    Ah true. yes you could indeed do it that way.
    That would be one long ass unit!
    Fernando likes this.
  10. Sep 30, 2020 at 1:55 PM
    #1950
    Littles
    Littles Stupid is as stupid does.
    Bryan
    Elizabeth, CO
    3 tons of fun
    My two cents is that personally I would not go with double 4.7s. I want options, and while I'm limited with only having the option to use the 2.5 in the chain drive FJ case and elected for the 4.7 gear ratio in the gear driven crawlbox, it still gives me those options. I can go slow, (just the FJ case), really slow (just the crawlbox), or REALLY REALLY slow with both. I just don't see a reason to go double 4.7s. I can already idle up shit in double low with the crawlbox in 4.7 and FJ case in 2.5 without stalling. I like having the option of the 2.5s in the FJ case for fire roads and the option of just 4.7s on slightly more technical shit where the FJ case just isn't slow enough. just 4.7 is just the tits for most stuff on a manual in my opinion, and in 5th gear or 6th gear you can still cruise fire roads.
    But that's just like...my opinion, man.
  11. Sep 30, 2020 at 3:18 PM
    #1951
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Whats the 04 tacoma stock case ratio? Sounds like i shoulda grabbed an fj case
  12. Sep 30, 2020 at 3:25 PM
    #1952
    allenfab
    allenfab I hate everything
    Todd
    Lakeland, FL
    08 5-lug on one tons
    2.56:1. An FJ case will not work in 1st gen Tacomas
  13. Sep 30, 2020 at 4:28 PM
    #1953
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Well i dont know shit. I'll see my way out
  14. Sep 30, 2020 at 4:52 PM
    #1954
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    To each their own, I love the shit out of super slow and use it all the time, smaller than 39s likely has something to do with that too :cheers:
    malburg114[QUOTED] likes this.
  15. Sep 30, 2020 at 7:17 PM
    #1955
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
    just saw this.... Only if i had a $ tree...
  16. Sep 30, 2020 at 7:45 PM
    #1956
    02hilux
    Planet: EARTH
    3 link with 10" coilover??
  17. Sep 30, 2020 at 8:59 PM
    #1957
    ToyotaBurrito
    ToyotaBurrito Well-Known Member
    2013 AC Sport MT
    Thank you @6 gearT444E & @Jojee117 for the answers (and saving me from the bad grinding noises).
    6 gearT444E[QUOTED] and Jojee117 like this.
  18. Oct 1, 2020 at 2:15 AM
    #1958
    allenfab
    Todd
    Lakeland, FL
    Not even that, it’s a radius arm setup. Complete wast of time doing a swap if you’re just going to do radius arms.
  19. Oct 1, 2020 at 10:20 AM
    #1959
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    BAMF RCLT Deaver Fox 2.5 StopTech Dana 60 37s 475:1
    Are you running triple?
  20. Oct 1, 2020 at 8:03 PM
    #1960
    02hilux
    Planet: EARTH
    You want a triple? Not too many triple around here.
