Official CVC Performance Tune by @chanvchau
Discussion in '3rd Gen. Tacomas (2016-2023)' started by chanvchau, Sep 10, 2021.
  1. Oct 28, 2021 at 11:45 PM
    #41
    jkish17
    jkish17 Well-Known Member
    Roseville, CA
    2018 DCLB TRD OR
    -Dobinson’s IMS shocks on C59-354 coils -Dobinson’s rear shocks -Dobinson’s L59-111-R heavy leafs -Wheeler’ off road super bumpstops -Wheeler’s off road U-bolt flip -JBA Upper control arms. -35x12.5r17 Yoko Geo MT’s -17x7.5 4Runner spare steel wheels (Part #42611-35430) -Trailgear 1.5 spacers -C4 fabrication rock sliders -Relentless Fabrication High Clearance Rear Bumper, no swingout. -CBI T3 front plate bumper, no hoop/bullbar. -Ironman 4x4 12,000lb synthetic winch -Victory 4x4 roof rack -China camper from Alibaba -CVC tuned -ExtremeLED lightbars in the roof rack and front bumper. -Baja Squadron's in the rear bumper -MESO customs stuff everywhere -Dobinson’s Zenith air compressor mounted under the hood -Homemade S-pod relay box -Entire sound system replaced and sound deadening added
    I just switched from the OVtune to the CVCtune and I’m only 150 or so miles in but I must say, so far I like it a lot.
    Kronk21 likes this.
  2. Oct 29, 2021 at 5:54 AM
    #42
    island taco
    island taco Well-Known Member
    Vince
    victoria, canada
    White '23 LBDC TRDSport
    Kicker speakers, Key amp, Spiker hood struts, tonnueo cover, Cooper AT3 4s, Method Double Standard Bronze
    Can someone explain what 'tip-in' is. I'm new to tuning and haven't figured out all the terminology yet.
  3. Oct 29, 2021 at 5:55 AM
    #43
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    I assume you mean by this statement that your tune does not alter the OEM ECU ID, making it undetectable to TechStream when a vehicle is plugged in for normal service. With all due respect however, I think stating that this or any tune is "completely undetectable" is a bit misleading. Yes, TechStream won't see it, but if you have a major powertrain issue and Toyota digs deeper into the ECU, they will be able to tell the ECU was flashed and put your warranty claim at risk. Most of us already know this and will make our own decisions, and I grant you that the chances of an issue are pretty slim, but they are not zero as your statement implies. Someone who is unfamiliar or new to the tuning process may rely on this statement and get an unpleasant surprise down the road.
    I think the statement on the Colorado Toyota Tuning website is more accurate:
    Is tuning detectable by the dealer? Will this void my warranty?
    • The tunes do not modify the OEM ECU ID and will retain the factory ECU ID.
    • If the warranty issue in question is caused directly by the tune, you could potentially have your warranty voided on that item. These tunes however are 99.9% undetectable by the dealership. We make no guarantees or promises that tuning will uphold your vehicle's warranty, HOWEVER, many of our customers have had their trucks at their local dealership with no warranty problems or issues. Please use your best discretion when considering tuning your vehicle.
    I'm sure you have a great product and appreciate your work and contribution to the Taco community. I just think your statement about the warranty could be clarified a bit more so potential customers can make a completely informed decision.
    Temutaco and MGMSangTaco like this.
  4. Oct 29, 2021 at 5:57 AM
    #44
    Kronk21
    Kronk21 IG @uniquely_Us_adventures
    Monte1
    2021.DBLCB.LB.GRN
    King 2.5 with reservoirs, CBI sliders, RCI skids, Leer camper shell, Methods, K02, switch-pro
    I was hesitate because of the Warranty but when I reached out the him he explained it in better detail and was really upfront about the ins and outs. My two cents. Cheers
  5. Oct 29, 2021 at 6:09 AM
    #45
    FL_TRD Sport
    Hector
    Port St. Lucie, FL
    I'm glad he was up front when you asked the question, as I was sure he would be, and that you knew enough to ask it. All I was saying was that the FAQ could be tweaked a bit for those who might not know enough to dig a bit deeper and ask those questions.
    Kronk21[QUOTED] likes this.
  6. Oct 29, 2021 at 9:14 AM
    #46
    justrussell
    justrussell Well-Known Member
    Russell
    Sacramento
    Tip in has to do with the throttle sensitivity. It’s not an option on the CVC or OV tune. It’s only an option on the KDMax tune. There’s a thread on it if you search it.
    TacoManOne likes this.
  7. Nov 1, 2021 at 5:09 PM
    #47
    chanvchau
    chanvchau [OP] CVC Tuning LLC
    Chan
    San Jose
    2020 Tacoma TRD OR
    CVC Tuned 315/70/17 Falken Wildpeaks AT3 KING 2.5 w/ Adjustable Deaver Stage II Leafpacks Summit Off Road Dakars Fenders Cut by @milogenfabrications Baja S2 Pro custom fitted into OEM TRD PRO Rigid bezels Baja S2 Sport Ditch Lights Rigid Hitch Swingout Prinsu Roof Rack w/ Uptop Overland AAP Uptop Overland Mid Size Bed Rack Thule Tepui Ruggedized RTT Tepui Matching Awning
    Actually, we can and do modify the "Tip in" on a case by case basis. We found it simpler to offer one option, which 99% of our drivers love, and I have adjusted the tip in to be less sensitive on less than 4 trucks, and more sensitive on 1 truck. If anyone is unhappy with our tip in, just contact their tuner and we'll make adjustments =)
    MOC221_ likes this.
  8. Nov 1, 2021 at 8:46 PM
    #48
    Terry's Tacos
    Terry's Tacos New Member
    Nor Cal
    2020 SR5 DCLB
    Bilstein 6112 (4/3) Falken Wildpeak LT265/75R16 --- 1998 SR5 4Runner
    I'm a few thousand miles in on the CVC Tune and, overall, I love it. The only problem I've noticed is that while cruising very slowly (i.e. 5-10 mph) the throttle seems to "jump" up and down a lot. For example, if I'm running the truck at an idling speed it seems to get very jumpy (RPM: high-low-high-low-high-low in very rapid succession, about 1/4 second each) which makes the truck jump forward, then cruise, then jump forward, etc. I imagine this wouldn't be a problem for most people, but I run my truck at a slow speed on dusty roads very often and it drives me crazy. Hopefully I just need to reach out to @chanvchau and get an adjusted tune.
    That being said, the tune has been awesome otherwise and I would never go back to stock.
    jkish17 and shotgunbilly420 like this.
  9. Nov 12, 2021 at 9:10 AM
    #49
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    How's the tune coming any updates with tune
  10. Nov 12, 2021 at 5:16 PM
    #50
    shotgunbilly420
    How many tanks of fuel have you used since tune?
  11. Nov 12, 2021 at 5:18 PM
    #51
    Phil4200
    Phil4200 Well-Known Member
    2018 Tacoma SR5 DC 4x4
    3.5 RC Vertex coil overs, SPC uppers, rear blocks\RC V2 monotubes CVC tune 3.0 mbrp exhaust
    Probably 6-8
  12. Nov 12, 2021 at 5:21 PM
    #52
    shotgunbilly420
    Yeah that's plenty hmmm everyone has different driving habits also.
  13. Nov 12, 2021 at 5:21 PM
    #53
    shotgunbilly420
    I like to haul ass but not all the time
  14. Nov 12, 2021 at 5:24 PM
    #54
    Phil4200
    I drive like an old lady honestly, I baby the truck
  15. Nov 16, 2021 at 10:06 PM
    #55
    CamC
    CamC New Member
    Cam
    2020 Silver Tacoma TRD OR
    CVC Tune, TRD Air intake
    Big shoutout to Chan for installing the CVC tune on my truck! I had it for about a month now and it definitely makes the truck more enjoyable to drive. It was a quick 10-15min install.
    I didn't realize how bad the lag was with the stock tune till I got the CVC tune. The CVC tune made the drive quality more smooth and efficient with the improved shift points.
    I haven't noticed too much of a difference in fuel economy, but it seems more stable and realistic (driving in LA traffic).
    Chan is very professional, knowledgeable and provides a great service. He can customize the tune further depending on your setup and needs. There is pretty much zero draw backs (I only wished I installed it sooner).
    Kronk21 and 71tattooguy like this.
  16. Nov 18, 2021 at 2:10 PM
    #56
    Irregardless
    Irregardless New Member
    Omaha, NE
    2017 TRD Sport DCSB
    Is it normal for the CVC tune to drop 3-4mpg from stock? I'm about 4 tanks of gas in and noticing a significant decrease (from 19-20 to now 16) Also, 3.5k rpm when you touch the throttle makes those parking space navigations kinda inconvenient.
  17. Nov 27, 2021 at 5:34 PM
    #57
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    I have tested both the kdmax and CVC tune extensively over the past few months. The kdmax made the throttle more sensitive but that seemed to be the extent of it.
    Just got back from a lengthy trip to Oregon from the Bay Area. Installed the CVC tune prior to the trip. This tune is leaps and bounds better than kdmax tune.
    Throttle input is much better
    Truck feels more powerful throughout the powerband
    Holds gears much better
    Fuel economy is a touch better (18.2 mpg) with 285/75/16, lift, and armor
    No looking back now. This truck is an absolute joy to drive now. Don’t hesitate if you’re on the fence about whether or not to tune yours.
    @chanvchau
  18. Nov 27, 2021 at 7:25 PM
    #58
    Phil4200
    I too just took mine to the mountains this weekend, the truck drives soooo much better. It holds gears way better and is no longer a pain to drive. Consistent power
  19. Nov 28, 2021 at 12:21 AM
    #59
    4x4spiegel
    4x4spiegel Well-Known Member
    So how much are the CVC tuners charging ? Just as much as the OV or KDM I presume .
  20. Nov 28, 2021 at 3:24 AM
    #60
    Fatback17
    Fatback17 Masshole
    Billy
    South of Boston, Massachusetts
    2020 TRD Pro MGM
    Both my daughters 16 and my 20 are CVC tuned and we are very happy with the result!
    Highly recommended!
