"Official" Firestone RideRite + Lift Thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by littleblue81, May 28, 2013.
  1. Apr 2, 2016 at 8:12 PM
    #241
    moe2o4
    moe2o4 Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
    So debating on going all out and ordering the bags from auto anything with that 20% off coupon and the cradles from Amazon and the axle brackets from etrailer....
  2. Apr 2, 2016 at 8:15 PM
    #242
    wanna taco
    wanna taco What's my name?
    alan
    SF Bay Area
    '15 DCSB TRD Sport 4x2 Barcelona Red!
    TRD Sport with a whole Shitload of TwoBitDiddlySquat Running Boards/Roof Rack/Bed Mat; Tint all around; W/Tech Liners; Extant Hard Trifold; P&L; Relentless tailgate mod; Amp Bed Step; TracOne; Rear headrest Delete; rear window lock rod; tailgate EZ hose clamp; Kahtec 3rd lite flasher; Muth Signal Mirrors; 894 (38W) Fog Reverse Bulbs; Seat belt extenders; Seat belt chime silenced; Fumoto Kwik Valve; RideRites/Daystars; Eyebolts; SS D Rings; Viair 70P; Lund hitch Bed Extender; Custom Windshield Rock Chips; ...
    Moe, What exactly is your truck? Mine is a '15 TRD Sport. I needed the extensions.
  3. Apr 2, 2016 at 8:17 PM
    #243
    wanna taco
    alan
    SF Bay Area
    Ok, I see what you have. I'd just get the bags and do the dry fit before ordering the legs.
  4. Apr 2, 2016 at 8:17 PM
    #244
    moe2o4
    Corey
    Pittsburgh PA
    I got a 2016 SR 5 Speed 4x4, its got a 3 leaf and overload leaf pack. I had a 2013 SR 5 speed 4x4 with a 2 pack leaf and overload leaf pack with the air bags and it fit perfect without the extensions but im guessing they wont work with the 3 leaf packs......
  5. Apr 2, 2016 at 8:18 PM
    #245
    wanna taco
    alan
    SF Bay Area
    It only takes a few minutes to do a test fit.
    moe2o4 likes this.
  6. Apr 2, 2016 at 8:21 PM
    #246
    moe2o4
    Corey
    Pittsburgh PA
    True, sounds like a plan. Probably just going to remove the bump stops completely so I don't have to cut them. Is that ok to do that with the u bolts?
    wanna taco[QUOTED] likes this.
  7. Apr 2, 2016 at 8:21 PM
    #247
    wanna taco
    alan
    SF Bay Area
    It only takes a few minutes to do a test fit, and you can make your cardboard template right then.
    moe2o4[QUOTED] likes this.
  8. Apr 2, 2016 at 8:22 PM
    #248
    wanna taco
    alan
    SF Bay Area
    Absolutely. Don't cut them. Loosen the U bolts and take the bumps out completely.
  9. Apr 2, 2016 at 8:23 PM
    #249
    moe2o4
    Corey
    Pittsburgh PA
    So there is no need to have those little half circle shapes on the bump stops to hold the ubolts in place? Kinda pointless.
  10. Apr 2, 2016 at 8:24 PM
    #250
    wanna taco
    alan
    SF Bay Area
    Those are to keep the bumps in place. Not needed for the U bolts.
  11. Apr 2, 2016 at 8:25 PM
    #251
    moe2o4
    Corey
    Pittsburgh PA
    All ya got to make sure is that the u bolts are square before ya tighten them down correct?
  12. Apr 2, 2016 at 8:26 PM
    #252
    wanna taco
    alan
    SF Bay Area
    Moe, you read thru the whole thread, I suppose? There is more than one way to cut the extensions, you saw both ways?
  13. Apr 2, 2016 at 8:27 PM
    #253
    moe2o4
    Corey
    Pittsburgh PA
    Ya I saw both, I'd probably just cut all 4 holes off and make my own 3 in it!
  14. Apr 2, 2016 at 8:29 PM
    #254
    wanna taco
    alan
    SF Bay Area
    This is true, They will stay where you put them if they are squared up. If not squared up, they may slip a little, which is not bad except they would no longer be torqued down.
  15. Apr 2, 2016 at 8:31 PM
    #255
    moe2o4
    Corey
    Pittsburgh PA
    I'll just make sure the square them up and torque them down to like 100 lbs i believe is the torque on them?
  16. Apr 2, 2016 at 8:31 PM
    #256
    wanna taco
    alan
    SF Bay Area
    I think you would cut off two, not four. Make a cardboard template when you test fit.
  17. Apr 2, 2016 at 8:31 PM
    #257
    Tacoma12
    Tacoma12 Well-Known Member
    Clint
    Mid Michigan
    2012 Tacoma 4x4 dbl cab LB
    stock
    You want to drill holes for the extension plates before you install the bag kit.
    Be for warned it's a bitch to drill in the truck when the kit is already installed.
    moe2o4 and wanna taco like this.
  18. Apr 2, 2016 at 8:34 PM
    #258
    wanna taco
    alan
    SF Bay Area
    I said torque, but meant tight. You get a feel for the difference between tight and loose after you've been with a few gals. :thumbsup:
  19. Apr 2, 2016 at 8:35 PM
    #259
    wanna taco
    alan
    SF Bay Area
    OMG! I hope you didn't find that out the hard way!
    moe2o4 likes this.
  20. Apr 2, 2016 at 8:35 PM
    #260
    moe2o4
    Corey
    Pittsburgh PA
    Ya it would be done before I install the kit for sure!
    :rofl:
