"Official" Firestone RideRite + Lift Thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by littleblue81, May 28, 2013.
  1. Jun 4, 2016 at 11:27 PM
    #281
    Up2NoGood
    Up2NoGood Well-Known Member
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    I saw that there were longer bracket options available. Figured I would have to be lucky to get exactly the right length though, more likely I'd need to either trim it down or weld an extension on. What are you running right now?
    I just sent my guy an email for an update on everything. Haven't heard from him for about a week and I'm hoping no snags. I'll have my people get in touch with your people once more is known :spy:
  2. Jun 5, 2016 at 6:47 AM
    #282
    Pigpen
    Dan
    Northwest Montana
    I ordered the 5 inch extension with the intent of cutting it down. I'm thinking I'll probably use the lower part with the radius already trimmed into it and just make my own holes or weld the extension on. That will probably leave me enough material left over to give another member a good deal on the remaining portion of the bracket - unless there's not enough left.
  3. Jun 5, 2016 at 11:00 AM
    #283
    wanna taco
    wanna taco What's my name?
    alan
    SF Bay Area
    '15 DCSB TRD Sport 4x2 Barcelona Red!
    TRD Sport with a whole Shitload of TwoBitDiddlySquat Running Boards/Roof Rack/Bed Mat; Tint all around; W/Tech Liners; Extant Hard Trifold; P&L; Relentless tailgate mod; Amp Bed Step; TracOne; Rear headrest Delete; rear window lock rod; tailgate EZ hose clamp; Kahtec 3rd lite flasher; Muth Signal Mirrors; 894 (38W) Fog Reverse Bulbs; Seat belt extenders; Seat belt chime silenced; Fumoto Kwik Valve; RideRites/Daystars; Eyebolts; SS D Rings; Viair 70P; Lund hitch Bed Extender; Custom Windshield Rock Chips; ...
    You have an extension coming in the mail and you need it more and more. This is a family rated forum.
    Pigpen[QUOTED] likes this.
  4. Jun 5, 2016 at 2:44 PM
    #284
    Pigpen
    Dan
    Northwest Montana
    The extension is in the mail. The other thing is not currently open for discussion, but will be taking TW by storm before long. 007 R&D is in full effect.
    wanna taco[QUOTED] likes this.
  5. Jun 5, 2016 at 4:17 PM
    #285
    wanna taco
    alan
    SF Bay Area
    OMG. Another fucking inventor.
  6. Jun 5, 2016 at 7:58 PM
    #286
    Burnout
    Burnout 200mph club
    Denver CO
    Blk DCSB TRD Sport 4x4
    I bought U-Bolts online for $35. Estimate the length by measuring from the bottom of your axle housing to the top of your Dakars and by longer. I think I got Pro Comps. Test fit the U-bolts and and the TC plate with your springs installed and then mark the correct length on the U-bolt threads with a sharpie and then cut them to size.
    moe2o4[QUOTED] likes this.
  7. Jul 14, 2016 at 2:38 PM
    #287
    kjkroll83
    kjkroll83 Well-Known Member
    so even though firestone is saying not to use the daystar cradles with the #2407 bags it seem to be the way everyones going huh? you would probably need longer brake lines with bags and rear 3 leaf aal im assuming...
    moe2o4 likes this.
  8. Jul 14, 2016 at 2:42 PM
    #288
    Pigpen
    Dan
    Northwest Montana
    Love mine. I have some 5" Ride Rite extensions I'm not using. 2 people could get extensions out of them (my original plan). If anyone wants them, I'll sell for the price I paid and won't charge shipping. I enjoy trades too! I'll check on what I paid if there's interest.
    moe2o4 likes this.
  9. Jul 14, 2016 at 2:45 PM
    #289
    moe2o4
    moe2o4 Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
    3" ome lift with dakars and air bags with daystar cradles! Also 2" extended stainless steel brake lines!
    Lumberjackcoma likes this.
  10. Jul 14, 2016 at 3:47 PM
    #290
    kjkroll83
    So with the daystar cradles your airbag is not connected to your axle/ leafsprings at all times as firestone intended, making for a less stiff ride. Is that correct? So when the bag is not in use (contacting cradle) it almost looks like it would act as a bumpstop?
    Easy_rider and moe2o4 like this.
  11. Jul 14, 2016 at 3:48 PM
    #291
    moe2o4
    Corey
    Pittsburgh PA
    Correct!
  12. Jul 14, 2016 at 3:48 PM
    #292
    Pigpen
    Dan
    Northwest Montana
    The air bag - as Firestone intended - limits articulation. The cradle frees you from restriction. You can haul and/ or off road.
    moe2o4 likes this.
  13. Jul 14, 2016 at 3:51 PM
    #293
    Up2NoGood
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    That was my understanding too. I run them unloaded around 5psi and they are in contact with the cradles at all times unless the rear suspension is being flexed out a little.
    moe2o4 likes this.
  14. Jul 14, 2016 at 3:52 PM
    #294
    kjkroll83
    @moe2o4 damn you guys are awesome! My head was hurting reading conflicting comments on the thread
    moe2o4 likes this.
  15. Jul 14, 2016 at 3:56 PM
    #295
    moe2o4
    Corey
    Pittsburgh PA
    Your welcome man anytime! Here to help out whenever I can!
  16. Jul 14, 2016 at 3:57 PM
    #296
    kjkroll83
    Thanks @Up2NoGood so with the cradles no need to bug my brother to fab a new bracket when i lift the rear end. Stoked! i think i see the light At the end of the tunnel
  17. Jul 14, 2016 at 4:00 PM
    #297
    Up2NoGood
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    An entirely new bracket no, but you will need to either weld or bolt on a couple of extensions so the bracket gets support from your axle.
    moe2o4 likes this.
  18. Jul 14, 2016 at 4:05 PM
    #298
    wanna taco
    alan
    SF Bay Area
    Not correct. The bags are not shock absorbers, they are overload springs. The bags are compressed against the cradles at all times except when you foolishly go airborne, or, importantly, when you jack up your frame to do maintenance, leaving the unsprung hanging. If the bags were installed as Firestone designed them, they would be required to support the entire weight of the axle. Think hanging a six pack of beer from your nut sack.
    Up2NoGood likes this.
  19. Jul 14, 2016 at 4:05 PM
    #299
    moe2o4
    Corey
    Pittsburgh PA
    Well I fabed up a bracket and bolted it to the lower bracket that sits on the leafs and the bracket extends it to hit the lower axle to support the weight of the bag so you don't bend the lower bracket like this when you have a load on the truck!
  20. Jul 14, 2016 at 4:13 PM
    #300
    kjkroll83
    Ok cool shouldn't be a problem thanks again @Up2NoGood. How high should cradle be located off of axle or springs? or what should the gap be between cradle
    ok ya i got it. Just did a bad job of translating. thanks @wanna taco ifyou were crawling though your axle would have more articulation down though it seems
