"Official" Firestone RideRite + Lift Thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by littleblue81, May 28, 2013.
  1. Feb 26, 2018 at 7:00 AM
    #441
    baboltin
    baboltin New to the 3rd gen world!
    Brad
    Tehachapi,Ca
    2019 Toyota Tacoma
    Stock with a camper shell for now.
    I will
    Have to look at the wheelers aal as well
  2. Feb 26, 2018 at 10:20 AM
    #442
    poodleracer
    poodleracer Member
    Josh
    Monterey
    White TRD Offroad w/ Locking Diff
    Hey guys I have had ride rite airbags on my truck for about a year now and love them. I would really like to get a compressor and control panel. I’m liking the idea of the wireless setup does anyone have rec’s of brand or kit that is budget friendly?
  3. Feb 26, 2018 at 11:05 AM
    #443
    wanna taco
    wanna taco What's my name?
    alan
    SF Bay Area
    '15 DCSB TRD Sport 4x2 Barcelona Red!
    TRD Sport with a whole Shitload of TwoBitDiddlySquat Running Boards/Roof Rack/Bed Mat; Tint all around; W/Tech Liners; Extant Hard Trifold; P&L; Relentless tailgate mod; Amp Bed Step; TracOne; Rear headrest Delete; rear window lock rod; tailgate EZ hose clamp; Kahtec 3rd lite flasher; Muth Signal Mirrors; 894 (38W) Fog Reverse Bulbs; Seat belt extenders; Seat belt chime silenced; Fumoto Kwik Valve; RideRites/Daystars; Eyebolts; SS D Rings; Viair 70P; Lund hitch Bed Extender; Custom Windshield Rock Chips; ...
  4. Feb 26, 2018 at 11:35 AM
    #444
    Pigpen
    Dan
    Northwest Montana
    I have an ARB compressor under the hood and just run the hose from that, or use the gas station air.
  5. Feb 27, 2018 at 8:43 AM
    #445
    poodleracer
    poodleracer Member
    Josh
    Monterey
    Thanks for your posts, I have since found the OBA super forum and have a lot of reading to do !
  6. Feb 27, 2018 at 11:58 AM
    #446
    Pigpen
    Dan
    Northwest Montana
    FYI
    The Firestone in cab system is worthless for tires. I had it on a work truck and had it plumbed with a connector for an inflation hose. $ wasn't worth the convenience of in cab controls, but still needing a gas station to inflate a tire.
  7. Feb 27, 2018 at 12:07 PM
    #447
    Harry
    Harry Science, Bitches
    Santa Fe NM
    15 TRD Off Road DCSB
    Since I have 120V in the bed I keep a hot dog air compressor ($39 Harbor Freight Special) in back for airbag fills, motorcycle tires etc. It doesn't take much - even a bike pump will fill the airbags in short order.
    Eventually I'll get a real OBA setup but for now, the HF compressor and a CO2 cylinder for bigger jobs works fine.
  8. Mar 3, 2018 at 9:42 PM
    #448
    KingFisher
    KingFisher Member
    NorCal
    2009 Sport DCLB
    Loving this forum. I installed air bags last year to help with the saggy rear when towing small camper. Installing wheelers 3leaf aal this weekend with Bilstein 5100’s and never would have known about the support extension. Luckily I’ve got tons of scrap steel in the shop! Thanks for the knowledge bomb.
    Pigpen likes this.
  9. Mar 8, 2018 at 9:16 AM
    #449
    Taco Nation
    Taco Nation Well-Known Member
    Zack
    Clinton, MS
    94.5 F350, 77 F150, 74 F100, 11 Jeep Grand Cherokee
    Lift, wheels, tires
    I currently have the OME Dakar's and they are great, however the drivers side is sagging roughly an inch lower than the passenger side and it looks terrible. Im thinking about getting the RideRite's with daystar cradles and then removing a few leafs from the Dakar packs to essentially have the leafs position the axle but have the rear riding on air. This would make hooking up to a trailer easier because I could just empty the bags as I back up to drop the ball under the trailer. I'm just thinking out loud here so can anyone chime in on this idea.
  10. Mar 8, 2018 at 10:09 AM
    #450
    Taco Nation
    Zack
    Clinton, MS
    Lift, wheels, tires
    This is actually exactly what I want
  11. Mar 8, 2018 at 11:27 AM
    #451
    Pigpen
    Dan
    Northwest Montana
    Leave the Dakars as they sit and add air bags and cradles. Use a touch more air on the driver side to even out the lean. Use the jack on the trailer to go up over the ball. It's faster and less hassle than using air to go under, and then having to raise the foot of the jack anyway. You're over thinking it a little.
    I love my Dakar + air bag and cradle setup. I have the Dakar HD pack.
  12. Mar 22, 2018 at 1:45 PM
    #452
    Bootleg_Flyer
    Bootleg_Flyer Well-Known Member
    Virginia
    17 DCSB Off-Road
    So I installed mine before reading this thread ... on a stock 2017 OR there is about 1/2" gap between the lower bracket and the axle (extensions ordered). Are there precautions that need to be taken to prevent ruining the air bags or can I cruise around for next few days with the gap between the axle? Thanks
  13. Mar 22, 2018 at 1:56 PM
    #453
    Pigpen
    Dan
    Northwest Montana
    Run the bags at a low pressure, like 5 -10 psi to put as little pressure on the bracket as possible.
    Bootleg_Flyer[QUOTED] likes this.
  14. Mar 22, 2018 at 2:01 PM
    #454
    Bootleg_Flyer
    Virginia
    17 DCSB Off-Road
    Thanks, I'm going to cancel that order and make my own. Etrailer gave me the ol "In Stock" and then "En route to our distribution center, will ship in a week" BS.
  15. Mar 22, 2018 at 2:02 PM
    #455
    Pigpen
    Dan
    Northwest Montana
    Making your own by just welding on a couple pieces of scrap is the best way to go.
    KingFisher likes this.
  16. Mar 22, 2018 at 3:39 PM
    #456
    KingFisher
    KingFisher Member
    NorCal
    2009 Sport DCLB
    Definitely make your own!
  17. Mar 22, 2018 at 5:49 PM
    #457
    RKCRUZA
    RKCRUZA Well-Known Member
    Bob
    Placerville, Ca
    2015 TRD Pro in the Garage!
    I had about a 1/4 in gap on the Taco Pro....cut a strip from an old Bed Mat and put in the gap before tightening it down. Been working fine for going on 4 years now. On mine, one side fit tight and one side had the gap. Firestone was "clueless" back then, said to run it as is...yeah right!
  18. Mar 23, 2018 at 10:44 AM
    #458
    wanna taco
    alan
    SF Bay Area
    Your difference between sides makes no sense at all. What kind of answer did you expect from Firestone?
  19. Mar 26, 2018 at 1:07 PM
    #459
    Zacowacko
    Zacowacko Well-Known Member
    Zack
    SW, OK
    2013 DCSB TE 4x4 6spd
    TRD Pro Susp., Icon AAL, Bags w/cradles, US OR Bumper w/Smitty, 2Lo Mod
    Got my aal, cradles, and bracket fixed up. Finally... I rode around at least a year with the 1/4 gap.
  20. Mar 27, 2018 at 8:39 AM
    #460
    KeystoneGoodie
    KeystoneGoodie Well-Known Member
    Ben
    '09 AxCab with meat shoes and axe handles
    Lots of dollars and no sense...
    Not to get too far off topic. I'm looking to replace my rear shocks when I put on my bags, are 5100's the way to go? I'm looking for middle of the road on price comfort durability.
