"Official" Firestone RideRite + Lift Thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by littleblue81, May 28, 2013.
  1. Nov 20, 2020 at 2:22 PM
    #761
    Voltron4x4
    Voltron4x4 Well-Known Member
    Denver, Colorado
    2014 Black Trail Limo
    This and that...
    Will have more experience once I pick up my camper this December, 900lbs. Have Dakar medium duty right now in the rear with the daystar cradles. With minimum pressure, 5psi, puts slight pressure on the cradles but no noticeable feel on the road. Looks to be quality. I don't know if it was discussed on this thread already but I switch my T union with one valve back to separate valves once I was told of a wobble caused from air shifting from one bag to another.
  2. Nov 20, 2020 at 5:45 PM
    #762
    corprin
    corprin Well-Known Member
    corprin
    wanna taco likes this.
  3. Nov 20, 2020 at 7:43 PM
    #763
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Thanks for the feedback!
  4. Nov 20, 2020 at 11:20 PM
    #764
    wanna taco
    wanna taco What's my name?
    alan
    SF Bay Area
    '15 DCSB TRD Sport 4x2 Barcelona Red!
    TRD Sport with a whole Shitload of TwoBitDiddlySquat Running Boards/Roof Rack/Bed Mat; Tint all around; W/Tech Liners; Extant Hard Trifold; P&L; Relentless tailgate mod; Amp Bed Step; TracOne; Rear headrest Delete; rear window lock rod; tailgate EZ hose clamp; Kahtec 3rd lite flasher; Muth Signal Mirrors; 894 (38W) Fog Reverse Bulbs; Seat belt extenders; Seat belt chime silenced; Fumoto Kwik Valve; RideRites/Daystars; Eyebolts; SS D Rings; Viair 70P; Lund hitch Bed Extender; Custom Windshield Rock Chips; ...
  5. Dec 2, 2020 at 4:24 PM
    #765
    griffee
    griffee Well-Known Member
    I've looked through this thread and haven't seen my issue addressed, so here goes. I have a '17 TRD Sport. I installed an OME 2" lift in the front and hopefully doing the rear Dakar's tomorrow. I have the Ride-Rite bags already installed when I bought it. I also purchased the Daystar cradle's. It looks to me that the "bolt" holding the leaf pack together in the center is much longer at the top of the leaf pack than stock. I am worried that the bottom air bag bracket is going to contact the bolt on top of the leaf pack. How did you all handle this? Drill a hole in the air bag bottom bracket? Grind down the leaf pack bolt a bit?
    Appreciate any advice, thanks.
  6. Dec 2, 2020 at 5:01 PM
    #766
    corprin
    corprin
    Cut it
    griffee likes this.
  7. Dec 2, 2020 at 5:24 PM
    #767
    ClintS
    ClintS Well-Known Member
    San Diego
    2019 Tacoma TRD Off Road
    U Bolts hold the leaf springs together. So I'm not sure what you are talking about. There should be a bolt that comes up through the lower air bag bracket and screwed into the airbag. That bolt is replaced with the included with the cradle. Then the bottom of the air bag is no longer connected to anything. Here is a video (start at he 1:00 mark) that should clear it up.
  8. Dec 2, 2020 at 7:49 PM
    #768
    corprin
    corprin
    Sounds like he’s referring to the leaf pack centering bolt. If so, it can be cut/ground up to flush with the top of the nut.
  9. Dec 2, 2020 at 7:59 PM
    #769
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    I can say that if you have a ubolt flip, 35gal fuel tank, AND air bumps installed this is not a bolt on deal lol.
    After lots of hours of making shit, i got the air bumps off and new bags installed. truck sits level again with all the shit i have added lol Tows better too.
    griffee likes this.
  10. Dec 3, 2020 at 7:07 AM
    #770
    griffee
    Yes, exactly. Thanks. That would be the easiest for sure and I don't think there's any chance of the nut coming loose. Appreciate it.
  11. Dec 19, 2020 at 3:12 AM
    #771
    TomHGZ
    TomHGZ Well-Known Member
    2014 TRD Frankensport 4x4 AC AT
    Partial list: Vagabond Drifter 3rd Gen OR rear axle 4.30 gears Bilstein 6112s and Tundra 5160s.
    I'm not sure I follow you, or maybe you don't follow me. Did someone say they were using their airbags for increased load capacity? To be clear, I never wrote anything meant to be interpreted as that.
    I think this discussion exists because people want "two trucks in one." For example, I want one truck that doesn't produce a lot of body lean on a winding two-lane mountain road when I'm driving across the country with two weeks of overlanding gear in the bed. I can get that first truck by putting some additional pressure in my Ride Rites.
    But when the pavement ends, I want a second truck with supple, more limber suspension. That's where I let the air out of the bags, and that's also where Firestone's own air bag mounts started giving me problems. There's no single setup that will do both things well without allowing for some adjustment at the trailhead, so it's not just a matter of installing some different springs.
    You are right that I want a "cheap" fix. I bought my truck with the air bags installed, so I decided to find a way to make them work for me.
    I discovered other things the air bags are good for too. For example, if you have camped in your truck in the high desert, or on the beach, or between two mountains that channel the wind – or just in a Walmart parking lot on I-40 in Oklahoma – you have probably been kept awake at night by the wind rocking the truck – especially if you are lifted or have a topper on the bed. And especially if you have something on the roof rack. If I put 40 lbs. of pressure in my bags, the rocking stops, and we get a good night's rest, and I didn't have to bring any extra hardware to stabilize the bed.
    Or if we stop on a slanted side grade of a forest service road for the night, I can let the air out of one bag and put more air in the other, and my wife and I can sleep more level, without gravity slowly sliding one of us off the side of the mattress, where things get cold fast.
    But I still want soft springs on the trail. Nothing can give me the best of both worlds if it is not adjustable at the trailhead. And the Firestone air bags need to be able to let the axle droop freely.
    I suppose I might have been able to solve at least some of these issues in other ways (although I can't think of any right now). But I also enjoyed the technical challenge of making what I already have work for me, and I have always preferred to solve a problem by producing a solution instead of buying one.
  12. Dec 19, 2020 at 6:21 AM
    #772
    corprin
    corprin
    So you installed bags on your F250 to increase the load capacity of your rear suspension during times when the load is higher then normal.
    Check.
  13. Jan 4, 2021 at 11:48 AM
    #773
    kp2architects
    kp2architects New Member
    2018 Tacoma TRD Offroad longbed silver
    black softopper
    With a GoFast Camper (approx. 300lbs) and a load of camping gear in the back of my 2018 TRD Offroad Tacoma LB I'm getting some bottoming out on bumps. The Firestone Riderite airbags with Daystar cradles sound like they could be the solution. Two questions: 1) Back in 2014 Firestone put out a warning that Riderite airbags should not be used with Daystar Cradles. Has this situation changed? 2) Can anyone recommend a good shop in Salt Lake City who could install a pair of these for me? Thanks!
  14. Jan 4, 2021 at 11:49 PM
    #774
    wanna taco
    alan
    SF Bay Area
    Warning shmarning, go for it. Without the daystars, you can't safely jack up the truck without hanging the axle from the bags, which can't be good for them. As for installation, nothing could be easier, do it yourself.
    griffee likes this.
  15. Jan 5, 2021 at 6:20 AM
    #775
    Ibocnet
    Ibocnet Well-Known Member
    Rich
    2010 TRD Sport DCLB
    Toytec 3" front lift, OME 3" rear lift, ARE MX Cap, Budbuilt Armor
    I spoke with both Firestone and Daystar about this. Firestone engineers got into trouble for not inventing the cradle. Because of the patent Firestone was pissed and added that disclaimer. My Daystar cradles have been on of over a year no problem. Depending on the load you are adding Airbags may not be the best or only solution. I ran a 6 week trip and they worked flawlessly at 25 to 30 PSI. The ride was harsher than I wanted so I installed ICON RXT springs at the highest setting. The airbags are down to 5 to 10 PSI to level. More when the ground is sloped when sleeping and more weight is in the back or when I tow or carry extra weight. I am very happy with this combination.
  16. Jan 16, 2021 at 10:42 AM
    #776
    ElDuderinoTaco
    ElDuderinoTaco Member
    Paul
    2012 SR5 Double Cab 4x4
    Bilstein 5100 Adjustables, K&N Cold Air Intake
    I've been combing through these threads and the web trying to find the answer to my question, so please forgive me if I've missed it. This is a long thread...
    I have Bilstein 5100s set at 2.5" in the front, and with a 1" block in the rear to level the truck. I just got Ride Rites and the lower bracket doesn't contact the axle. I saw something about fabricating plate to provide the support on that side, but wanted to confirm that that was the solution - that no one makes a different bracket or purpose-built part for this situation. Fabricating something isn't a big deal but before investing the time and modifying the bracket (which would presumably void the warranty), I wanted to ask.
    Thank you all for everything you know and share - I consult this forum frequently and have had many many questions answered by the collective experience and knowledge of this community.
  17. Jan 16, 2021 at 7:39 PM
    #777
    Ibocnet
    Rich
    2010 TRD Sport DCLB
    Firestone makes brackets in multiple sizes for bolt on but you have to drill the lower backet or weld them. If you are welding don't buy them.
  18. Jan 17, 2021 at 4:13 PM
    #778
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    I am running blocks on my rear as well. I made an extension for the lower plate:
    I have pictures of the entire install in my build thread thread, post 224.
    MY50cal likes this.
  19. Jan 18, 2021 at 9:27 AM
    #779
    ElDuderinoTaco
    Paul
    Thanks for the info. I did more research and consulted my mechanic buddy (the garage where I'm doing the work, or I should probably say: the guy I'm helping to install these on my truck) and we agreed the best bet was for me to purchase the (expensive) extensions sold for this purpose. So those should arrive today.
    Next, hopefully final, question: I use my truck to go far into the Sierra backcountry, sometimes on rough and rocky roads (not crawling per se, but I've been on trails where rock crawlers go). Do I need the Daystar cradles? Do the bags seriously restrict travel that much, and is there risk of damaging the bags if I end up in a situation where my suspension is maxed out?
  20. Jan 18, 2021 at 10:31 AM
    #780
    wanna taco
    alan
    SF Bay Area
    Yes and yes and yes.
    Scott B. likes this.
