"Official" Firestone RideRite + Lift Thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by littleblue81, May 28, 2013.
  1. Mar 8, 2025 at 2:25 PM
    #1001
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I did a foolish thing today - I went to pick up flooring and should have made two trips. The salesman said the weight was 2400 lbs, not including the pallet and other supporting materials I picked up. I inflated my airbags to 36 lbs and loaded up. When I got home and added up all the weight, including myself, pallet, etc, the total was 2815 lbs. Yes, I was sweating it the 20-minute drive home. But, my Taco came out of it unfazed. With the weight on, the air pressure in the bags shot up to 56lbs and sunk, maybe, 3 inches - it still sat higher than unladen. Air pressure lost after removing the weight was 2.6lbs (from 36 to 34.4). These bags are about 15 yrs old and cracked - I have put superglue in the deepest cracks! Thus, I am impressed they held up as they did.
    Here some picks with the weight on, off, and air bags empty.
    Pigpen and bagleboy like this.
  2. Mar 8, 2025 at 3:01 PM
    #1002
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Yeah, people need to realize or remember that bags can level weight that’s way in excess of max load for the truck. It may sit & ride ok but the parts(bearings, axles, frame, etc) are over their limits. It’s not that failure is guaranteed but it’s operating in the red and you may or may not get away with it.
    Pigpen likes this.
  3. Mar 8, 2025 at 5:32 PM
    #1003
    GREENBIRD56
    GREENBIRD56 Well-Known Member
    Casper / Tucson
    014 Taco 4Dr 4wd
    When bearings are designed - and their life projected - the reduction of life due to load is linear and life reduction due to speed is exponential. The kindest thing you can do for them in an overload is operate at reduced speed. An example (admittedly poor) is that a linear progression is 1,2,3,4,5 as the divisor as the load goes up - and the exponential divisor is 2,4,16,256 and so on as the speed increases. A little speed reduction goes a long way in the life calculations. It also goes a long way toward saving the bearings when you come home with a ton in the back of your little truck.
    Pigpen, Chuy and bagleboy like this.
  4. Mar 8, 2025 at 8:30 PM
    #1004
    Chuy
    Lakeside, CA
    Silver Taco
    Yep, took the back streets home, in third gear, and never exceeded 45 mph. And, that was just one half mile section. First time she ever carried that much. Should be the last.
    bagleboy likes this.
  5. Mar 12, 2025 at 2:28 PM
    #1005
    bagleboy
    Scott
    Norcal, Santa Rosa
    Best thing you can do when you’re running heavy.
