Official Tennessee Thread
Discussion in 'Tennessee' started by Gr8WhiteTaco, Sep 11, 2010.
  1. Dec 22, 2016 at 6:35 AM
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    2011 TRD TX 4x4 MGM DCSB
    Lift, 285's, mud, and scratches
    I'll give $2 and some beer
    scottalot likes this.
  2. Dec 22, 2016 at 7:47 AM
    Kerleyfries
    Kerleyfries Idk what the hell I'm doing
    Zack
    Lebanon
    ‘17 F150 and SAS ‘98 4runner
    Tossing around the idea of selling the bedrack, swingout, and rear bumper and going to an hc rear bumper with a tire carrier as well as getting gears and an arb locker. Thoughts?
    Dave41079 and beertimecontinuum like this.
  3. Dec 22, 2016 at 7:54 AM
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    After all the work that Everett put into it? Come on man :facepalm:
    beertimecontinuum likes this.
  4. Dec 22, 2016 at 7:55 AM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    Take all that stuff off, sell the truck. Buy a 2nd gen TRD OR, and reattach all that stuff!
  5. Dec 22, 2016 at 7:55 AM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    HC rear ..... check. Tire carrier ..... check. Gear (not gears) ..... check. ARB locker ..... waste of money.
  6. Dec 22, 2016 at 7:55 AM
    Kerleyfries
    Zack
    Lebanon
    I know! I may keep it and just dump the bedrack. Just an idea, chill
    Dave41079 likes this.
  7. Dec 22, 2016 at 7:56 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Drunken work
  8. Dec 22, 2016 at 7:56 AM
    Kerleyfries
    Zack
    Lebanon
    You gotta understand I parallel park every day and drive for work, I'm just worried about destroying my tires super fast with a mechanical
  9. Dec 22, 2016 at 7:58 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    I don't have to understand. Where does this worry originate from?
  10. Dec 22, 2016 at 8:01 AM
    Kerleyfries
    Zack
    Lebanon
    Isn't that the main disadvantage of mechanical lockers?
  11. Dec 22, 2016 at 8:25 AM
    Mr.Bl0nde
    Mr.Bl0nde Well-Known Member
    Middle TN
    2008 TRD OFF-ROAD / 87 4Runner
    stuff
    I think you should! lol
  12. Dec 22, 2016 at 8:28 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    I've never heard that. This isn't a welded diff we're talking about. Get a mechanical locker made for the street and it's hardly different then running any style clutch type lsd (which comes factory in some cars). The premise behind a clutch type lsd or locking lsd is that under load both wheels will always spin at the same speed no matter how much weight is transfered to either wheel or how much "slip" either wheel sees. Kind of an on/off switch but then will be modulated further by the cars factory traction control, stability management and abs systems. The difference between this style locker and a locker such as the Powertrax is your right foot controls how locked the wheels are under load. Enough torque applied and it locks both axles together, not enough torque applied and it runs open. It also allows for modulation of locking/ unlocking when seeing wheel speed differences from side to side. For instance when turning a corner, the inside wheel will always have less distance to travel meaning less tire rotations. The locker performs a sort of ratcheting sequence of locking/ unlocking rapidly to increase and decrease that inside tires speed but once again, this is modulated by your right foot giving you the opportunity to leave the locker "open" or fully locked.
  13. Dec 22, 2016 at 8:56 AM
    Kerleyfries
    Zack
    Lebanon
    I'll make you a large purchase deal lmao
    I need to do more research.
  14. Dec 22, 2016 at 9:15 AM
    423 TACO
    423 TACO Well-Known Member
    Daniel
    Knox-ish, TN
    13 MGM Sport 6sp AC
    Option C. 4wd swap
  15. Dec 22, 2016 at 9:37 AM
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    It's OK by me of you sell that beautiful tire carrier lol
  16. Dec 22, 2016 at 11:06 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    I agree. Research the difference between a lsd, automatic locker, selectable locker and spool and their advantages and disadvantages. Once you're familiar with that and feel comfortable with what the differences are, diregard everything you just read and buy an automatic mechanic locker for your street beast and enjoy. :D
  17. Dec 22, 2016 at 11:23 AM
    Mr.Bl0nde
    Middle TN
    stuff
  18. Dec 22, 2016 at 11:30 AM
    423 TACO
    Daniel
    Knox-ish, TN
    13 MGM Sport 6sp AC
  19. Dec 22, 2016 at 12:15 PM
    THE CALICO
    THE CALICO Well-Known Member
    Colton
    Nashville
    Black 2014 TRD SPORT ACCESS CAB
    Anyone on here electrical savvy, as far as original wiring goes for these trucks? One of the electrical harnesses for the AC control panel seems to be getting hot and melting on one of the pins in the dash. I've tried google and all I find is blower motor issues on a different harness. I'd post pictures but photobucket is kinda screwed right now after my software update. I've got a picture already in my build thread that might help. These are from when I first noticed it. It's deff still happening.
    https://www.tacomaworld.com/threads/calicos-2014-build-thread.333640/page-21
    I don't want to take this issue to the dealership but I don't know what's left to check. I also haven't messed with this wiring harness before but have others so I don't know if it could be something I've done. It does however look like the same wire to the blower motor which is known to have issues. Any help is much appreciated.
  20. Dec 22, 2016 at 1:54 PM
    Kerleyfries
    Zack
    Lebanon
    Rear bumper, tire carrier, bed rack.
    Mr.Bl0nde[QUOTED] likes this.
