Official Tennessee Thread
Discussion in 'Tennessee' started by Gr8WhiteTaco, Sep 11, 2010.
  1. Jul 8, 2013 at 4:16 PM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    Well ..... I'm gay ....... So I'm waiting to read this ........ Where's it at?
  2. Jul 8, 2013 at 4:44 PM
    sk8rjess
    sk8rjess IG: @whoishack
    Cody
    Nashville, TN
    02 4x4 sr5
    some duct tape and zip ties
  3. Jul 8, 2013 at 5:27 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    :D
  4. Jul 8, 2013 at 6:32 PM
    lowinhz
    lowinhz Well-Known Member
    Papa Kurt
    Dandridge Tn
    11 DC SB 4x4 v6
    Billies@ 2.5, 2inch blocks, front hitch, xrc 8k winch on portable mount, 10 sub behind seat, Memphis amp, pioneer touch radio, cobra cb, 235/85/r16 duratracs with black rims, high lift jack, tint, remote start alarm, hella 500 lights, 59" curve led bar, snorkel, expo trailer with rat, car seat
    I used my truck today to pull my stalled tractor out of the ditch line. No pics FTW.
  5. Jul 8, 2013 at 6:47 PM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    I helped my brother move last night. around 8 or so. since it stopped raining.
    him and his girl broke up or are taking a brake so he got a apartment.
    had a 60” tv in the back seat. tv stand and a old trunk in the bed of the truck.
  6. Jul 8, 2013 at 7:42 PM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    LOL. My bachelor party included a stop at Oasis.
    There is a lot I miss about ATL and north GA.
  7. Jul 8, 2013 at 7:52 PM
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    Anyone in the Memphis or Jackson area have a stock stereo (2005+) just sitting around that I can have? One that reads MP3 discs.
    I've already looked at some aftermarket head units but I don't like the "steal me now" look of those.
  8. Jul 8, 2013 at 10:31 PM
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    How soon are you needing this? I am going to be headed that way in a few weeks to get my wheels I can bring it with. I will be in Jackson.
  9. Jul 8, 2013 at 10:42 PM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    Well I got a long day for yard work tomorrow! thanks to all this stupid rain..
    will be mowing and weed eating all day.
  10. Jul 8, 2013 at 10:43 PM
    Newlife
    Adam
    Knoxville TN
    2020 t4r orp
    You can mow mine until I get my mower repaired. Stupid diaphragm has collapsed.
    *** WOO HOO 100th post *** that is all
  11. Jul 8, 2013 at 10:58 PM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    lol. wish i had a trailer i could get our Kubota 60” deck, commercial Z turn / diesel engine. Our trailer is to high to get it on, the back part around engine hits the ground. need to get a lower trailer thats 6’ wide. If i did have a trailer i could get it on, i’d come mow it fro a price.
    I got to push mow some here tomorrow, weed eat. then go down by the UT campus and do a small business that i try and do on weekends. but it has not been done in 2 weeks now:eek: because of stupid rain. and me going to SC.
  12. Jul 9, 2013 at 6:02 AM
    sk8rjess
    Cody
    Nashville, TN
    02 4x4 sr5
  13. Jul 9, 2013 at 6:06 AM
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    Nice. No rush for me.
  14. Jul 9, 2013 at 6:37 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Cody ur toe is fucked. That's what ur tie rod adjusts. I would say u have a bent suspension part. Either the tie rod itself or something like ur spindle or lca. Caster has nothing to do with wearing tires unless your caster numbers are adversely affecting ur other alignments numbers causing those to be thrown off. Your camber is perfect. Your caster matches but is really low. How much lift do you have and do you have aftermarket ucas with added caster?
    Alignment adjustments go ...........
    Camber is, if you are looking at the truck from straight on, when the top of the tire is out away from the vehicle more then the bottom then u have positive camber. When the bottom of the tire is out farther away from the vehicle then the top then u have negative camber.
    Caster is, if you are looking at the truck from the side, the placement of the tire in the wheel well front to back. If the tire is closer to the cab then that's negative caster past the zero point. If the tire is closer to the front bumper then that's positive caster past the zero point.
    Toe is, if you are looking straight at the front of the truck, the direction each tire points coming forward. So if you have positive toe then the tire is pointing out away from the center of the vehicle. If you have negative toe then the tire is pointing in towards the center of the vehicle.
  15. Jul 9, 2013 at 7:19 AM
    sk8rjess
    Cody
    Nashville, TN
    02 4x4 sr5
    nothing is bent that i can see. stock UCA but i don't think that's the issue.
    i'm confused then, my tires wear from the outside in - like the camber is positive. Levi can vouch for that too, you can see it while driving in front of me.
  16. Jul 9, 2013 at 9:46 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Has it always been like that? I think you need some ucas because that caster is really low unless they can adjust more caster out of it. All those adjustments work together so when u change one thing, it changes everything else. I would adjust the caster higher then see if the toe can be corrected. The machine is showing the camber as perfect but since your toe is so off, and its way off, it may be giving u that illusion of your tires being cambered. But its def what's wearing ur tires
  17. Jul 9, 2013 at 10:55 AM
    sk8rjess
    Cody
    Nashville, TN
    02 4x4 sr5
    well frick. this is going to turn into a headache, i know it.
  18. Jul 9, 2013 at 12:43 PM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Do u trust your mechanic?
  19. Jul 9, 2013 at 12:56 PM
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    more than he should trust you!!!
    had to i hadnt started any shit with you in quite some time so you werent coming around starting shit with me....... i missed the shit starting.
  20. Jul 9, 2013 at 1:07 PM
    sk8rjess
    Cody
    Nashville, TN
    02 4x4 sr5
    uhhhhhh. i often look in the mirror and ask if i trust myself. i have yet to answer so i'm not really sure
