OFFICIAL XB LED HEADLIGHTS THREAD 16+
Discussion in 'Lighting' started by eledobleu, Feb 20, 2019.
  1. Sep 10, 2022 at 8:59 PM
    #2841
    Jericho76
    Jericho76 Member
    Jericho
    2021 SR Pre-Runner
    Yes, my fuse tap is currently plugged into the INJ fuse. But DRLs still turn on every few hours even when the car is off.
    Thanks, I like yours too
  2. Sep 10, 2022 at 9:20 PM
    #2842
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Some relevant detail:
    https://www.tacomaworld.com/threads/efi-3-vs-inj-fuses.602078/#post-20250177
    There are other ignition sources in the main engine fuse box with a T harness, @Puppypunter had his "from the stalk" SR OEM LED harness using that approach, but it's a bunch more work for something that ideally might be simple.
    I dunno what to say really, except that I do wish SR/SR5 had ECU DRL in an accessible connector in the engine bay somewhere, and I totally wish we had a nice clean ignition source for all of us, that would be fantastic. I think ignition is just a lot easier to tap in the cab and send through the firewall.
    I am in the same basic boat with my 2005 SR, as I need to identify an ignition source for gentex, drl, fog, etc. I'll most likely use POUETLET1 and a new stalk but that's a bunch of work. Short term I'm likely going to either do two add-a-fuses for the gentex or a T off the radio 10 pin which has all the goodies and is pretty easy to access.
  3. Sep 11, 2022 at 9:04 PM
    #2843
    Jericho76
    Jericho76 Member
    Jericho
    2021 SR Pre-Runner
    do you have a pic on where the AC fuse is? I need to try that out since I've tried tapping into the EFI and INJ fuse but my DRLs still turn on even if my car is off
  4. Sep 18, 2022 at 4:14 PM
    #2844
    Integerdy
    Integerdy Aspiring "SR5 Pro"
    Eric
    So-Lame, Oregon
    21 SR5 Silver Sky DCSB
    Did you pay extra for it? Pretty sure it's an additional charge when you order it.
    The harness that comes with it is for L shaped white drl on halogen headlights iirc.
  5. Sep 18, 2022 at 4:29 PM
    #2845
    Integerdy
    Eric
    So-Lame, Oregon
    My instructions did not have info on oem Led installs
  6. Sep 18, 2022 at 8:32 PM
    #2846
    Integerdy
    Eric
    So-Lame, Oregon
    Ya that checks out. Hope you get them installed soon, they are dope headlights.
  7. Oct 2, 2022 at 8:30 AM
    #2847
    tAc0LunA
    tAc0LunA Member
    I recently got the XB gen 2s. I was wondering if anyone have sa same fitment on the driver side with a gap.
  8. Oct 2, 2022 at 8:40 AM
    #2848
    Integerdy
    Eric
    So-Lame, Oregon
    It's just how they are
  9. Nov 3, 2022 at 10:39 AM
    #2849
    Kaharoa7
    Kaharoa7 Member
    Kevin
    2020 TRD Sport
    So I installed the gen 2 XBs into my 2020 trd sport with halogens.
    I noticed without the fuse tap that the startup sequence only occured when taking off park like others have said.
    Adding the fuse tap (10A INJ Fuse) makes the sequence happen at the proper time when starting .
    However with or without the fuse tap installed I have bright DRLs when it's just the DRL. As soon as the low beams or marking lights come on the DRL dims. Is this normal? I thought the fuse tap allows for constant bright drl?
  10. Nov 3, 2022 at 10:55 AM
    #2850
    Integerdy
    Eric
    So-Lame, Oregon
    Drls always dim when lowbeams turn on. It's the same with oems iirc. It's a safety thing.
    Fuse tap is for start up sequence, and if you have an SR5 like me, it gives white drls when stalk is set to off. So basically always have drls on when using tap on an SR5.
  11. Nov 3, 2022 at 11:07 AM
    #2851
    Kaharoa7
    Kaharoa7 Member
    Kevin
    2020 TRD Sport
    Okay thanks! Sounds like I have everything hooked up correctly then. It's a shame the instructions they come with are completely bassackwards
  12. Nov 3, 2022 at 11:27 AM
    #2852
    Integerdy
    Eric
    So-Lame, Oregon
    The instructions were awful lol. I didn't use the recommended efi fuse tap spot because your headlights will turn on randomly when it runs systems in the middle of the night. So I used the inj fuse tap above it.
  13. Nov 28, 2022 at 7:38 AM
    #2853
    OhNoItsMe
    OhNoItsMe Well-Known Member
    NM
    2022 TRD OR
    Help!
    I bought a pair of “open box, never installed” XB Gen 2’s with amber DRL. My stock headlights are halogen with an LED DRL.
    I took my truck apart and tried installing my passenger side headlight and realized that some of the connectors didn’t have matches, so I assumed I needed an adapter harness and put the truck back together.
    Later when I looked at my driver side headlight I saw that it had this harness attached to it.
    The passenger side does not have this harness and is just the wires coming out of the headlight.
    so I went to Extreme Terrain and purchased 2 of these harnesses..
    I know the image isn’t the same as the one that I believe I’m needing, but it says the product may be different than the image, and they also use the same image for the OEM LED conversion adapters.. so did I buy the right harness? Was this harness supposed to come with the headlights? If not, where could I find this harness?
    Sorry for the long post and thanks for the help. I’m beyond confused.
    there are no markings or numbers on the harness
  14. Nov 28, 2022 at 8:18 AM
    #2854
    Integerdy
    Eric
    So-Lame, Oregon
    From my understanding, the one from extreme terrain is to convert full oem led headlights to morimoto xbs (5+plugs into 1 plug). This is probably not the one you need, so you should return them
    The final picture you posted looks like the one that came with my morimoto xb headlights. See this post for pictures I took from my harness provided by morimoto.
    https://www.tacomaworld.com/threads...ights-thread-16.594520/page-140#post-27437193
    I don't know where you would find another, reach out to morimoto or try some Google searches.
    I didn't have to use that harness because I drive an SR5, but I'm holding onto mine incase I ever decided to part my truck out and sell
  15. Nov 28, 2022 at 8:31 AM
    #2855
    daveeasa
    David
    PNW
    This
  16. Nov 28, 2022 at 8:35 AM
    #2856
    Integerdy
    Eric
    So-Lame, Oregon
  17. Nov 28, 2022 at 8:59 AM
    #2857
    OhNoItsMe
    NM
    2022 TRD OR
    Done. Thanks fellas :cool:
    Integerdy likes this.
  18. Nov 28, 2022 at 9:10 AM
    #2858
    OhNoItsMe
    NM
    2022 TRD OR
    If any SR guys would like to part ways with their unneeded harnesses.. please let me know while I wait on Morimoto to get back to me :D
  19. Dec 5, 2022 at 4:57 PM
    #2859
    hodo_taco
    hodo_taco Well-Known Member
    Colorado Springs, CO
    '16 SW Tacoma DCSBTRDOR
    Lot's o' plastidip.
    Just installed some XB gen2's on my 2016 Tacoma Off-Road.
    Does anyone know what would cause intermittent fast blinking for the turn signals? I searched this thread but couldn't find anyone with the same issue.
  20. Dec 5, 2022 at 6:39 PM
    #2860
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    Are all other turn signals OEM?
