Officially given up on the Rugged Trails - Sienna did better
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rmd0311, Dec 18, 2007.
  1. Dec 18, 2007 at 9:24 AM
    rmd0311
    rmd0311 [OP] Well-Known Member
    Dutchess County, NY
    2010 Mag Gray TRD Sport
    My driveway is a circular and slants upward so that water runs away from the house. The driveway is one big sheet of ice. I cleaned it real good Sunday, but that black ice is inevitable.
    My wife gets home and pulls in just fine into the garage. A little slipping but nothing that hangs her. Later on that night its my turn., I get stuck halfway up. I'm just spinning in the wind in a little sheet of ice. Of course I put on the 4WD and was able to get up just fine. But damn... If the Sienna can do it
    just fine. I was on the wing, listening to people that the Rugged Trails weren't that bad. To just deal with it till you need new tires. But forget it. Depending on the size of my bonus this year, I will buy now or sometime mid Jan. This is ridiculous.
    I know the 4wd corrects the tires faults. But I should not have to resort to 4wd in minimal situations. Am i wrong in this assumption?
  2. Dec 18, 2007 at 9:46 AM
    Don G
    Don G Old Goat
    Southern Tier New York
    "08" Tacoma Access Cab TRD Sport 4X4
    Perhaps your expectations are greater than your circumstances, The Sienna is front wheel drive and the Taco with the rear wheels pulling is no comparison:) Pickups with no load on bad roads are useless. If you could use just the front wheels on your Taco you could go a lot of places with ease like your wife! !
    Don G
  3. Dec 18, 2007 at 9:51 AM
    gcwaterski
    gcwaterski Well-Known Member
    LOL. Rugged trails suck for off-road.
    I dont know a lot about the sienna. But if it has LSD and your truck does not that may be the reason it can make it and you cant....in 2wd!
    My friend has a 2wd with a LSD and when i follow him, he can go up slippery terrain that I have to switch to 4wd. Little things like that make me want to do the "Gray wire Mod" or whatever the anytime locking rear diff. mod is called. It would be perfect for times like that where you just need a little push!
    $$ Go ahead and snatch up some BFG All-Terrains!$$
  4. Dec 18, 2007 at 10:03 AM
    Nitro_rc
    Nitro_rc Active Member
    07 DoubleCab TRD Sport 4X4
    Your Taco weight less at the rear and since you have it in rear wheel drive only, it will spin air. Try putting some weight in your bed and try again. I bet you it will go up fine.
  5. Dec 18, 2007 at 12:07 PM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    I think Don's right on this one, although i will say to go ahead and ditch those worthless rugged trails. I know i will after the new year, those tires are completely useless
  6. Dec 18, 2007 at 12:32 PM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    I'm gonna back Don G on this 100%
    I will not debate the quality of the Rugged Trails. Though I had them on my 04 Tacoma in plenty of rain and plenty of mud dirt and sand off road and never had a problem with them. (I dunno about them in snow or ice as I have never drivine my Tacoma's in the snow or ice as I don't want to give the other morrons a chance to hit them.) But on ICE, particularly balck ice like you are describing, in a rear wheel drive truck with an empty bed it is not going to matter in the least what tires you have as they all will spin on that ice with no weight in the bed, doesn't matter if they are $69.00 Pep-Boys tires or $300 baja claws. Ice is ice, and without weight or a locker or LSD you're done.
  7. Dec 18, 2007 at 12:44 PM
    rmd0311
    Dutchess County, NY
    I don't think I can go back on this now... Wifey was looking and she said you are right. Change em out. The truck is right now the primary fam vehicle with the Sienna seeing its last legs. I want to have the best tire possible for any and all conditions. I should have asked my neighbor to try the same on his f250 with the good BFG AT.. See what happened in that case.
  8. Dec 19, 2007 at 6:36 PM
    allrsdup
    allrsdup Well-Known Member
    Sahuarita AZ.
    2018 dcsb trd offroad 4x4 Inferno
    i dont want to be rude. but u are comparing now an f250 with a taco? the 250 is about 2000 lbs heavier. u slipped on the ice cause u are rwd pickup with no weight in the bed, and not in 4x4. the sienna is front wheel drive like everyone else said. u are searching for a problem that is of no fault of your truck or its tires.
  9. Dec 19, 2007 at 6:47 PM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    I can't get more than 3 feet up my driveway when it's icey (in 2wd). That is the nature of the beast.
  10. Dec 19, 2007 at 7:03 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    I can easily spin around if the roads are slick (w/ water). I blame it on a light rear end and my heavy foot. I say go with the cheap way first...unless you are trying to convince your wife that you "need" better tires. Throw in a couple bags of sand in the bed and you should be fine.
  11. Dec 19, 2007 at 7:52 PM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    I'd say at least 300lbs in the bed. I had 180 in mine with stock tires and it was like it wasn't even there. Still, sand is cheaper than tires and it'll help you get by until you can really afford new tires.
