Offroaders, I have a question for you.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by xxaarraa, Feb 22, 2011.
  1. Feb 22, 2011 at 10:38 AM
    xxaarraa
    xxaarraa [OP] Well-Known Member
    Hi Folks,
    I have been doing some regular off-pavement drives this winter and have had mixed success. I am looking for some feedback/tips from those that regularly offroad their 2nd gen.
    I have General Grabber AT2s (265x70x16), not studded. Rear TSB and front billies set to .85. Fully stock otherwise.
    Situation 1: Bayley-Hazen road in Northern VT. These are gravel roads that are un-maintained. In the winter, they are used as snowmobile trails, but still open for passenger vehicles. A couple of weeks ago, I got stuck there and needed to be towed out by a skitter. HEAVY snow (maybe 4-6 inches deep?) and hard-packed ice underneath. I got down a series of rolling hills but just couldn't get back up. I tried 4HI and 4LO and no success. Bailed, walked 4-6 miles and got a logger with a skitter to tow me out, but that's another story.
    Situation 2: Golden road in Northern Maine. Same story, unmaintained gravel roads, 2-4 inches of snow over hard packed ice. This time though, I was able to get out of it in 4 LO. It might have helped that I caught the shoulder of the trail where the snow was deeper, but I was fully expecting to need a tow and was pleasantly surprised when I made it up.
    So my question is this: What was different about the second situation compared to first? I can't figure out why I didn't get stuck the second time also. Are there any driving tips for offroading in icy/snowy conditions short of studs or snow chains?
  2. Feb 22, 2011 at 10:41 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Throw on some chains, or air down the tires a bit. Both help a lot in the snow. Remember if you air down, dont go too low if you have to run highway before airing back up.
  3. Feb 22, 2011 at 10:49 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Chains make a huge difference for winter off-road trails. And, as said before, airing down helps.
  4. Feb 22, 2011 at 10:50 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Depth is the other factor. If you "high center" on the snow, you stop.
  5. Feb 22, 2011 at 10:57 AM
    RelentlessFab
    Eric
    Sparks, NV
    And if you lose too much momentum(are coming to a stop), pull off the gas and back up to get a run into the snow to bring the momentum back into play. If you stay on the gas til completely stopped, chances are you've buried yourself to the frame, or dug the tires into 4 holes that arent easy to get out of. :cool:
  6. Feb 22, 2011 at 10:58 AM
    xxaarraa
    Thanks. I already have Spidertrax 1.25" in all 4 corners, sorry should have mentioned that in the original post.
    I am researching tire chains now. Anyone have any recommendations on brand/type that will clear both front and rear and can be installed/taken-off relatively easily while on a trip?
  7. Feb 22, 2011 at 11:10 AM
    trd09
    trd09 Well-Known Member
    Chuck
    NW Ark
    17 TRD Pro 6AT
    Air down, keep it in 4hi, and momentum is key
    My Taco turns into a snowmobile
  8. Feb 22, 2011 at 12:14 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Air down your tires
    Momentum
    Lockers
    Driver skill
    And - believe it or not - you can & will get stuck. Never assume these trucks are almighty and invinsible, because they can't tackle everything even if you're full prepared with all the traction devices available.
    Be prepared to GET STUCK via carrying the proper tools you need.
    and NEVER GO ALONE!!!
  9. Feb 22, 2011 at 12:19 PM
    tombiosis
    tombiosis Well-Known Member
    T
    Ottawa Canada
    2016 TRD offroad access
    2016 Tacoma Access Cab, Super White, TRD Off Road package,//OEM Running Boards//TriFold2.0 Tonneau Cover//FJ Cruiser TRD SE Black TrailTeams replca wheels!
    Interesting thread.
    So let's say you do go alone, what are some techniques for getting "un-stuck" when you are by yourself? AND you don't have one of those cool bumpers with a winch on it?
  10. Feb 22, 2011 at 12:26 PM
    trd09
    Chuck
    NW Ark
    17 TRD Pro 6AT
    Happened to me once.
    1. Don't floor the gas hoping to get out in frustration!!!
    2. Get out of the truck and assess the "stuck" situation
    3. clear some snow, hopefully with a shovel, but i used my foot
    4. Air down your tires. I usually go to 15 or so psi.
    5. Rock the truck, take frequent breaks to prevent tranny overheating.
  11. Feb 22, 2011 at 12:33 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    thats why i got all this....
    and a front hitch coming soon.....
  12. Feb 22, 2011 at 12:34 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    ^^ trd09 , good info above ^^
    Tires are the most important factor.
    In the OPs situations i would carry chains for just such a emergency
    and a shovel.
    Not all snow and ice are the same, so dont try and compare the two.
  13. Feb 22, 2011 at 12:38 PM
    trd09
    Chuck
    NW Ark
    17 TRD Pro 6AT
    My pic I posted and your avatar are surprisingly similar (as are our trucks, save for the DC and TRD) :thumbsup:
  14. Feb 22, 2011 at 12:38 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    airing down is key for me. but theres no snow in phoenix, az. but i know airing down helps in every situation
  15. Feb 22, 2011 at 12:38 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    note to that ^^^^
    the cooler its full o beer and peperoni and cheese toooo
    gotta have something to do in case of having to spend the night out there....
    and you will never see my beer without a cozie......
    and to the op ice sucks ...if theres ice under it your fucked......"without" studs
  16. Feb 22, 2011 at 1:26 PM
    Mandy3206
    Mandy3206 Well-Known Member
    San Juan PR
    Sand Pearl Black 06 6spd DC SB TRD OR Moded
    I guess that would be better than getting fucked with studs lol:p
  17. Feb 22, 2011 at 1:34 PM
    skistoy
    Western New York
    Why yes they are. Love the double cab
    already have had a reg cab, and a extra cab.
    SNOW on !!!!!
  18. Feb 22, 2011 at 1:43 PM
    hellrazor004
    hellrazor004 Well-Known Member
    Rob
    09 DCSB
    A bunch of people mention they use 4HI and I'm curious why.
    Besides the obvious reason on non-TRDs with no A-TRAC option(unless you do the yellow wire mod for TRAC in 4LO), why use 4HI?
  19. Feb 22, 2011 at 2:08 PM
    river rat 69
    river rat 69 Well-Known Member
    Jim
    Orlando, Fla., Green side of the grass
    007, trd, sr5, fmf.
    NO Chrome,3" NFab's steps,TRD skid,Wet okie's.011 grill, k&n,5100's,All this comes right off when the old lady says let's go get a NEW ONE!!!
    Move to Fla.
  20. Feb 22, 2011 at 2:29 PM
    trd09
    Chuck
    NW Ark
    17 TRD Pro 6AT
    High torque of 4lo would dig in more making it tougher to gain momentum. Like sand or loose mud, wheel speed in deep snow is good thing once momentum is had.
