Discussion in 'Wheels & Tires' started by Lane Cypert, Mar 24, 2009.
  1. Mar 24, 2009 at 6:42 PM
    Lane Cypert
    Lane Cypert [OP] Well-Known Member
    Apr 6, 2008
    Lewisville, Texas
    2008 silver prerunner double cab TRD
    I found this useful info on Discount Tire's website and thought it may help some one understand wheel offset.
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] The offset of a wheel is what locates the tire and wheel assembly in relation to the suspension. More specifically, it is the measured distance between the hub mounting surface and the center line of the rim. Below is an explanation of the various types of offsets which are pictured in the above graphic. Positive Offset
    A positive offset occurs when the hub mounting surface is on the street side (the side you see) of the center line of the rim. Most factory rims will have this type of offset.
    Zero Offset
    When the hub mounting surface is centered within the rim, it is known as a zero offset.
    Negative Offset
    If the hub mounting surface is on the brake side of the center line of the rim, it is considered a negative offset or "deep dish".
    [​IMG] [​IMG]
