Offset question
Discussion in 'Wheels & Tires' started by Thundjet, Jan 18, 2012.
  1. Jan 18, 2012 at 10:16 AM
    Thundjet
    Thundjet [OP] Well-Known Member
    2012, V6, Sport TRD, Auto, 4 wd
    Considering buying a set of Fuel Cranks for my 2012 Sport TRD. It is not lifted and have no plans to do so. Stock tires are 265x65x17 so when they need replacing might be replaced with 265x70x17.
    The Cranks are 17x9 and can be purchased with 0 or 30 +offset and the person I've been dealing with says the 0 offset would be best for the truck.
    Opinions?
  2. Jan 18, 2012 at 10:31 AM
    Large
    Large Red
    If those are the only 2 you can pick I'd say 0 also but more people will chime in.
  3. Jan 18, 2012 at 10:40 AM
    Bobbb
    Bobbb "Rumors of Bob, but never Bob. It is Bob, right?"
    Bob
    Bob
    Bob
    Tundra TRD/OR
    I have 17x9 AWC's with a 0 offset.
  4. Jan 18, 2012 at 11:11 AM
    lundy
    lundy Well-Known Member
    Justin
    Reno, NV
    2010 DBLC 4x4 Off Road
    They're offered with a -12, +0 or +20. Just a heads up
  5. Jan 18, 2012 at 11:14 AM
    Thundjet
    And the best choice for me would be the?????????
    Thanks!
  6. Jan 18, 2012 at 11:19 AM
    lundy
    Justin
    Reno, NV
    Well I've said +0 a few times already. Maybe somebody else can chime in and verify whether a 9 with a +20 will be to high of backspacing or not. It's 5.75" backspacing which seems like too much to me. I believe it's .25" more backspacing than stock.
  7. Jan 18, 2012 at 11:35 AM
    Thundjet
    Are you suggesting the Cranks have 5.75 back spacing and that is to much? Sorry, need to be very precise on the fitment since these are being mail ordered and freight each way is a killer if they don't fit properly.
  8. Jan 18, 2012 at 11:37 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    That is correct.
    OP, the 0 offset (5" backspacing on a 9" wide wheel) would be fine for your application. However, make sure the tires you buy are approved for 9" wide rims. Many 265's are not. You can check on the tire manufacturers website.
  9. Jan 18, 2012 at 11:55 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    This.
