offset wheels?
Discussion in 'New Members' started by GTACOMA05, Nov 4, 2009.
  1. Nov 4, 2009 at 8:38 PM
    GTACOMA05
    GTACOMA05 [OP] New Member
    05 Tacoma rwd
    Hey guys.... I got a 2005 tacoma... regular cab ... 4 cylinder.. rear wheel drive...
    I would like to know what options can i do with my wheels... like how much offset of the wheel can I go without hitting anything... also what is the biggest wheel can i go also with the offset... ​
  2. Nov 5, 2009 at 7:18 AM
    98tacoma27
    Ben
    Not Beech Creek
    It's not the offset, it's the backspacing. You need 4.5" or less of backspacing.
  3. Nov 5, 2009 at 7:18 AM
    98tacoma27
    Ben
    Not Beech Creek
    Welcome to TW!!
  4. Nov 5, 2009 at 7:34 AM
    GTACOMA05
    05 Tacoma rwd
    I heard that back spacing will stress alot on the original studs or the hub assembly...
  5. Nov 5, 2009 at 7:43 AM
    98tacoma27
    Ben
    Not Beech Creek
  6. Nov 6, 2009 at 7:01 AM
    GTACOMA05
    05 Tacoma rwd
    They do make wheels that already got some offset... And i would like to know what is the best offset i can do without any issue with my stock suspension.....
  7. Nov 6, 2009 at 8:00 AM
    98tacoma27
    Ben
    Not Beech Creek
    Yes, they do make them with some offset but that is only because of the backspacing. I realize you are worried about stress on the suspension, but you are reading into it too much. There are members sporting wheel spacers up in the 1.25" range to keep the tire from rubbing the UCA's. This changes the backspacing (and the offset) to the negative and pushes the wheel out away from the frame/body.
    And for wheel fitment, it's not the offset you need to worry about. It's the backspacing. Look at it this way. You purchase an 8" wide rim that has 4" of backspacing. That makes the offset 0. Now you find another wheel that is 8" wide but has a backspacing of 4.5". That will give it an offset of +.5" (or 12mm). Now if the backspacing was 3.5", that would give it an offset of -.5" (or -12mm).
    Offset is just where the mounting surface sits in relation to the centerline of the rim.
    A lot of Tacoma rims end up with a 12mm offset. The offset will not effect your suspension.
  8. Nov 10, 2009 at 4:42 AM
    Nicky Lam
    Nicky Lam Dog Face Soldier
    Nick
    Somers Point/Mount Laurel, NJ
    2013 Blk DC Off Road
    NOV12: Front windows tinted to matched to rear windows 12NOV12: Fog light anytime mod DEC12: OME 885 w/ 25912 top plate spacers for full 3" lift OME Trim packer Dakar Rear 5 Leaf Packs Total Chaos Uniball Upper Control Arms 2.5° Degree Rear Axle Shims 18JAN13: 17x9 Fuel Kranks 17x9 4.5 BS -12mm Offset 285-70-17 Goodyear Duratracs 23JAN13: OME Carrier Bearing Drop Kit 05FEB13 TRD Aluminum Skid Plate 05FEB13 TRD Stainless Steel Cat Back Exhaust (2012 modified to fit 2013) Auto Mate 5304A (Viper 5704 Equivalent) 2-Way Alarm/Remote Start with Smart Start for iPhone De-Badged All Emblems 30JUL13 Go Rhino Stainless Steel Dominator II Side Steps *not yet installed: Stainless Steel Extended Rear Brake Lines
    so say you wanted the rims to stick out past the fenders.... you would want a back spacing of 3.5" or 4.0"?
  9. Nov 10, 2009 at 9:48 AM
    98tacoma27
    Ben
    Not Beech Creek
