oh no....TSB-0171-16 Driveline vibration
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Murrayb4, Dec 7, 2016.
  1. Jul 28, 2017 at 7:47 PM
    #421
    rsimi72
    rsimi72 Well-Known Member
    PNW
    2020 Tacoma SR5 Access Cab
    I have an appt in 6 days to take a tech on a drive to demo my washboard vibes at 25-20 mph on deceleration. I just looked under my truck and I do have a thin shim installed.
    ** Question - Is that shim confirmation that my 2017 OR has the updated leaf springs that the TSB would call for? Or is it still possible that more could be done? Thanks
  2. Aug 8, 2017 at 5:18 PM
    #422
    beverlytaco
    beverlytaco Well-Known Member
    2017 TRD off road double cab
    YES. 2017 DCOR. I get a constant vibration under firm acceleration in first gear only. Dealer says "normal characteristic" of truck.
  3. Aug 24, 2017 at 8:50 PM
    #423
    avitaco
    avitaco Well-Known Member
    A
    2017 DCSB 4x4
    My shit did that too.. I did a carrier barring drop and it helped
  4. Sep 3, 2017 at 11:13 AM
    #424
    psvines
    psvines Well-Known Member
    2016 SR5
    As I expected, the dealer was unable to reproduce the rumble strip sensation that is so clearly evident when I drive. They said is was raining so was difficult to hear it. This was after I explained the feeling was more feel than sound.
  5. Sep 7, 2017 at 8:28 PM
    #425
    NerdTaco
    NerdTaco Well-Known Member
    I get this vibration when braking at a stop sign or light.
    I first noticed it when I first test drive the truck, I thought it was because of the tread on the TRD-Off road tires.
    I wonder why the off road isn't included in this TSB.
  6. Sep 8, 2017 at 7:56 AM
    #426
    timmaayyy
    timmaayyy Well-Known Member
    Tim
    Raleigh, NC
    '16 TRD Sport DC
    According to the official document, this only applies to 2wd. I've got a 2016 Sport 2wd and I definitely have these symptoms. Anyone else with a 2wd experience this?
  7. Sep 25, 2017 at 3:38 PM
    #427
    hotrod45
    hotrod45 Well-Known Member
    paul
    sarasota fl
    16 sr 5 access cab
    ok, does anyone know why the rear end carrier nuts are coming loose causing the lube leak as stated in the recall. hmmm. maybe the vibration from the rumble strip effect?
  8. Sep 25, 2017 at 6:19 PM
    #428
    bulldog
    bulldog Well-Known Member
    SW MO
    2023 Pro
    Umm…it’s a Pro Retired 4/29/2023 Dobinsons MRR Dobinsons UCA Dobinsons C59-314 Front Springs Dobinsons I59-110 Rear Springs 4.88 Yukon Gears CMC MobTown Sliders Line-Xed RCI Aluminum Skid BAMF Recessed Grille WARFAB Rear tube bumper SSO Full Plate Hybrid (sitting in the garage still) TTD Carbon Fiber Steering Wheel Clazzio Dark Gray Seat Covers 35% Tint Vinyl Tailgate Letters Undercover Elite Tonneau Apex Stealth Cali LED 31.5" w/upgrade OPT 7 harness and MicTuning Switch V5 Gemtech Homelink 265/75 16 Mickey Thompson Baja Boss A/T Volk Gloss Black 16” 17' Pro Rigid Fog Lights 17' Pro Tail Lights Complete sound proofing
    I had my 16 OR 4x4 springs replaced w/new ones and a steering damper and it fixed the problem.
  9. Oct 7, 2017 at 12:32 PM
    #429
    mastro1
    mastro1 Well-Known Member
    2017 MGM DCSB TRD Sport
    My springs are on order with the steering damper!
  10. Oct 14, 2017 at 7:19 AM
    #430
    JoeRacer302
    JoeRacer302 Well-Known Member
    Joe
    Pasadena, CA
    2016 DCSB OR MT Inferno
    Front: 5100's @ 0.85 Rear: 1/2" spacers 265/75r16 on RAY10
    My lift made it better. It’s definitely a drivetrain angle problem on my truck.
  11. Oct 14, 2017 at 3:55 PM
    #431
    PEAKIT
    PEAKIT Well-Known Member
    UT
    24 Off Road long bed Premium Taco.
    OME 888 nitro front, SPC upper arms,B110 rear shocks, Timberen bump stops, extended brake hoses, U bolt flip, sway bar delete, Dakar HD leaf pack with extra leaf, Snug top HD shell, MobTown Skid plate, cooper Maxx 255-85-16 4:88 Nitro gears,Spider trax 1.5 spacers, AirBedz, debadge, Pro grill.
    I took my 2016 OR in for this issue a year before the TSB (that doesn’t include it anyway) and they said it was “Normal operation , can’t duplicate” I put the Dakar leaf packs In and it quit. It felt like axle wrap like the diff was flopping up and down. On accel and decelerating.
    jclay likes this.
  12. Oct 15, 2017 at 6:54 AM
    #432
    mastro1
    Had the springs installed yesterday, vibration just about all gone, still there a little, but driving home noticed the steering wheel off to the left, brought it back and supposedly aligned it.. still off a bit. gonna have to align it myself 2 maro after work, also greasy hand prints all over the interior and door.. shame.
  13. Oct 21, 2017 at 4:58 PM
    #433
    EdgeCrusher
    EdgeCrusher Well-Known Member
    Chicagoland
    '16 OR DCSB Fully Loaded
    Arrampico likes this.
  14. Oct 22, 2017 at 7:29 AM
    #434
    flynnr
    flynnr Well-Known Member
    2016 TRD ORDC
    Awesome
  15. Oct 30, 2017 at 10:04 AM
    #435
    Arrampico
    Arrampico Well-Known Member
    Dan
    2018 4Runner SR5
    2017 SR5 Silver DCSB 4x4 V6 (RIP - Traded-in for T4R)
    Only 300 miles so far and already feeling a slight shudder when decelerating/braking ~20mph. At the stealer today to see if my pinion flange angle is correct per the TSB thats out...also having them check my tranny fluid per advice on this site. Will post with updates.
    -Update-welp at the dealer...tranny fluid was low from the factory! Thanks to this forum...they are filling now then will check pinion flange.
  16. Oct 31, 2017 at 12:15 PM
    #436
    Age315
    Age315 Well-Known Member
    AJ
    Castle Rock, CO
    2016 BBP Yeti Mobile
    TRD Baja Kit with JBA UCA's 1/2 inch spacer on top, Medium Dakars with BAMF hangars and super bumps all around. 285/75/16 Cooper Discoverer AT3 XLT's on graphite TRD faux beadlock wheels. Pro skid powder coated black with Pelfreybilt aluminum mid skid and aluminum gas tank skid.
    Had my 20k service done at the dealer where my friend works and he looked up TSB for my OR. This one came up and I told him I this since day one and the dealer I bought it from said it was normal. It got better when I torqued the ubolts to spec but he said it's covered under warranty and my vin was part of it so he ordered the new springs. They are supposed to be here today so hopefully he can install them this weekend. It's crazy how some dealerships don't want to do any work.
  17. Nov 10, 2017 at 3:57 PM
    #437
    Spiker
    Spiker Well-Known Member
    Don
    2016 Tacoma OffRoad Double Cab Inferno
    Brought my '16TRDOR in today for it's 30k work. Told them about my documented 10-30 MPH vibe, and was tired of having bags of mulch in the bed to mask it. Last year when I complained, my truck wasn't on the TSB. Anyways, the leaf packs and steering wheel damper parts are on order. Hopefully this will fix it. Man, my truck drove like ass to and from the dealer without the mulch in it......
  18. Nov 12, 2017 at 2:39 PM
    #438
    mastro1
    Quick note to those who had their rear leaf springs replaced... when I got mine done the squid tech didn't preload the springs!! the truck MUST be on the ground when torquing the bolts NOT on a lift!! other wise there is undo stress on the bushings and will have premature bushing failure and the wrong ride height!! FYI
  19. Nov 13, 2017 at 12:45 PM
    #439
    Spiker
    Don
    Welp, just picked her up and drove home after the dealer installed the kit. Good to go, no issues. Rides like it should now!
  20. Nov 13, 2017 at 4:41 PM
    #440
    EdgeCrusher
    Chicagoland
    Is this vibe what I feel at exactly 30 mph and again at 20 mph that feel like a downshift/engine brake upon deceleration/light braking? its not bad and i cant decide if its worth going through the tsb for.
