oh no....TSB-0171-16 Driveline vibration
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Murrayb4, Dec 7, 2016.
  1. Jan 30, 2018 at 3:41 PM
    #481
    rdjr17
    rdjr17 Well-Known Member
    Ron
    Nepa
    2019 voodoo blue Trd pro
    my trucks at dealer now got vibrations at all speeds, rear howl is loud , front driver side axel has play ad well , dealer got me rental (ram.1500) told me they have alot of work to do on my truck and showed me a stack of papers from toyota tsp and procedures to fix .. most likely getting new rear put in .. love my truck this is my 3rd tacoma and am shocked with the issues.
  2. Feb 1, 2018 at 6:37 AM
    #482
    khill007
    khill007 Active Member
    2018 Tacoma Double Cab SR, V6, Auto, 4x4
    Are these issues different from the clamshell bushing issue with vibrations? Have any of you swapped out for the ECGS bushing and still experienced the vibration?
    Just for reference I just picked up a 2018 Double Cab SR, 4x4, V6 (Build thread coming soon) and it is smooth as butter. Now that might all change as I have King 2.5 RR/Adjustable coilovers on the way?!? I did a little research on leaf spring part #'s and it seems the SR's are different than the other models. May explain why it looks a little lower in the rear than most?!? I'll keep everyone posted as to what happens with mine. Thought I was getting out of "LEAF SPRING HELL" when I traded in my 2018 Chevy ZR2 so I'm praying this doesn't turn into an issue (Long story, PM me if you thinking of buying a ZR2).
    FYI - My OCD with research has come up with two separate issues that cause driveline vibrations in these Tacoma's.
    1. Clamshell Bushing
    2. Driveshaft Pinion Angles (even on stock Tacomas)
    Feel free to add.
    Arrampico likes this.
  3. Feb 1, 2018 at 5:45 PM
    #483
    Arrampico
    Arrampico Well-Known Member
    Dan
    2018 4Runner SR5
    2017 SR5 Silver DCSB 4x4 V6 (RIP - Traded-in for T4R)
    Assuming it's the clamshell...I've had everything done to mine that should have fixed it, minus the clam. ...I don't think Toyota will fix it and it's not REALLY that bad, but like you, my OCD still still can detect it if I feel for it right at downshift at 20mph. Toyota gave me a free 100000 mile warranty, so I'm good for now. If you find out about the clamshell causing it it would prorbably be worthy of a sticky because so many have this problem. I saw a link with a video showing the clamshell problem and that very well may be what it is. I've spoken with many other tacoma owners of older models and this seems to be a common problem with tacomas
  4. Mar 8, 2018 at 8:09 AM
    #484
    JiminMaine
    JiminMaine Well-Known Member
    Jim
    Maine
    2017 TRD OR Access
    I know, I know!
    My vibration is particularly bad around 50mph! Taking it to a different dealer tomorrow. First dealer was very dismissive, "they all do that" I can't believe we have to put up with this. I've read most of the posts here, is the general consensus the removal and replacement of the bearing gets the best results? Has anyone tried to shim their driveline similar to the OME shim kit?
  5. Mar 8, 2018 at 8:42 AM
    #485
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    For what reason did they give you the warranty?
  6. Mar 16, 2018 at 6:03 PM
    #486
    Arrampico
    Dan
    2018 4Runner SR5
    To keep me happy? I've had multiple issues with the tranny to include the low fluid from the factory...
  7. Mar 27, 2018 at 7:47 AM
    #487
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
    So, am I likely to be able to get this fixed, even though I have an off-road and suspension kit? I've had the vibration since I got the truck.
  8. Apr 3, 2018 at 5:10 AM
    #488
    IamEric
    IamEric Member
    2016 Tacoma Limited
    Same for me. Its the worst at 53 mph and I can feel it when braking. Its really annoying because they have literally never attempted to fix it!
  9. Apr 3, 2018 at 8:46 AM
    #489
    Contra472
    Contra472 Well-Known Member
    2016 Tacoma DCSB 4X4 OR
    If you have aftermarket suspension, chances are they will not cover it, but wouldn't hurt to ask.
  10. Apr 3, 2018 at 7:12 PM
    #490
    KevC
    KevC Well-Known Member
    Is this tsb only for 4wd?
  11. Apr 3, 2018 at 8:43 PM
    #491
    chiefdustin
    chiefdustin Member
    I've got a 2017 Sport, about 6000 miles on it. Not all the time, but time to time when using a heavy break at lower speeds my steering wheel shakes and it feels like the front end is vibrating or almost like I have no control over steering.
    Do I need to call my dealer?
  12. Apr 9, 2018 at 8:17 AM
    #492
    SpeySquatch
    2016 TRD OR DCSB
    Calling all driveline PROS
    Hey Fellas. Got a driveline question. I have done all the work I think you will need to answer.
    I have been having this weird driveline vibe from 38-44MPH and I have a feeling my rear axle shims are not steep enough. The vibes are happening at about 1200rpms the most when cruising, more-so on deceleration even when foot isn't on the gas or break.
    Truck Details:
    • 2016 4Dr TRD OR
    • 2" OME Lift Medium weight
    • 3/8" carrier bearing spacer (OME)
    • Full rear dakar pack (no leaf removal)
    • ECGS BUSHING INSTALLED!
    • Drives amazing except for 38-44mph
    • Driveline has been professionally inspected and balanced
    • Shims on correct way with skinny tapered end forward
    • I have the latest TSB
    Please let me know if I need steeper shims or what? I have gone all the way from 1/16" spacer to 1/2" spacer in the CB with no luck.
    I used Spicer parts calculator to figure this out. I measured the angles with a phone app and used same side of phone to measure angles without phone buttons interfering.
    http://spicerparts.com/calculators/driveline-operating-angle-calculator
    Someone please give me some insight because I cannot figure this out for the life of me.
  13. Apr 10, 2018 at 9:35 AM
    #493
    Sone Taco
    Sone Taco Tacoma rules!!!
    Sone
    Rochester, NY
    2017 Barcelona red TRD OFF ROAD DCSB, 2005 Red AC 2.7 MT 190k mil, 1995 Maroon Reg cab 2.7 MT w/ 360k
    slowly but surely...
    I felt vibration on my 2017 TRD OR from day 1. Vibration is constantly there at any given speed. It felt more on gas paddle. Engineer from Toyota is looking at it at dealership (now). Love my Tacoma (have owned all three gens plus pre-tacoma) but hated the issues 3rd gens are having. It's just not living up to its name.
    Hopefully Toyota boys won't tell that "normal operation" crab. I called to Toyota center as well as post on Toyota USA FB page where they actually look at it and respond. Hope everyone experiencing vibration issue to call and report... hoping for recall or something....
    JiminMaine likes this.
  14. Apr 18, 2018 at 2:39 PM
    #494
    IamEric
    IamEric Member
    2016 Tacoma Limited
    That's what I want to know. I showed the tsb to my dealer and they said it was only for 4wd. I'm wondering if anyone with the 2wd has had any luck getting this.
  15. Apr 20, 2018 at 11:33 AM
    #495
    jcroberts1972
    jcroberts1972 Active Member
    Jeff
    Arlington, VA
    2017 4X4 SR5
    Just to add, I have a 2017 SR5 4x4 and had the TSB applied and my OCD still picks up vibration at exactly 20mph. It's better but it's still there.. After driving a 2001 for 10 years I never even looked into potential issues with Tacoma's? I think it's just going to be a bitter sweet relationship with the 2017... it's a Tacoma but she just ain't right. Sucks, but I really don't want any other truck so I guess I'm stuck with her!
    IamEric likes this.
  16. Apr 20, 2018 at 11:38 AM
    #496
    jcroberts1972
    Jeff
    Arlington, VA
    2017 4X4 SR5
    How did you confirm you had low tranny fluid? I feel like I can't trust the dealership. I had mine checked at the 15K service and they said it was a bit low but I still don't trust them. The truck drives ok, but at low speeds in traffic it seems to be a bit shifty and lurches from time to time? Just wondering if it's characteristic of how they operate or is there a potential issue with the trans fluid level?
  17. Apr 20, 2018 at 12:09 PM
    #497
    TXTaco13
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    I feel the exact same way
    jcroberts1972[QUOTED] likes this.
  18. Apr 30, 2018 at 4:01 AM
    #498
    hotrod45
    hotrod45 Well-Known Member
    paul
    sarasota fl
    16 sr 5 access cab
    does anyone have a 2 wd 3.5 auto which demonstrates the exact behavior outlined in the t s b? mine does. i can hear it, fell it in the brake pedal and steering wheel. i suspect, to one degree or another, it involves a lot more trucks than they want to admit to.
    trackdaybro likes this.
  19. Apr 30, 2018 at 6:57 AM
    #499
    JoeRacer302
    JoeRacer302 Well-Known Member
    Joe
    Pasadena, CA
    2016 DCSB OR MT Inferno
    Front: 5100's @ 0.85 Rear: 1/2" spacers 265/75r16 on RAY10
    Feeling it in the brake pedal and steering wheel may be a different problem. This vibration in the tsb is the entire vehicle. Mine would vibrate like driving over a rumble strip, the dash rattled, it is not limited to just the brake pedal and steering wheel at all.
  20. May 11, 2018 at 10:20 PM
    #500
    hhouse5
    hhouse5 Member
    2016 DCLB TRD Off Road
    I have had these vibrations since I bought my truck in January(used). I chalked it up to just being part of the way the truck drives. I thought it was just me but then my wife drove it and noticed it. After endless researching on this I was hesitant to take it to the dealer because I figured I would just get the run around. I finally made an appointment. My dealer was super cool about all of it. They acknowledged the problem and ordered new rear leaf packs even though my trucks vin wasn’t technically under the TSB. Installed new leaf packs under warranty. I can finally say I really love my truck after being bothered by this since I bought it. My truck drives like butter now and has made 100% difference. Super happy and finally feel like my truck is right!
    Norsemanvike likes this.
