oh no....TSB-0171-16 Driveline vibration
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Murrayb4, Dec 7, 2016.
  1. May 12, 2018 at 1:37 PM
    #501
    TRD_Taco_4x4_
    TRD_Taco_4x4_ Member
    I had this same issue around 2000-5000 miles and Toyota fixed it. Now at 29,900 I'm getting another vibration (either new or the same issue) around 25mph under deceleration or coasting. I've done a ton of reading and it might be the wheel bearing which makes sense because there is tactile feedback in the steering wheel. I guess that's what I get for a lot of hard wheeling off-road.
  2. May 13, 2018 at 9:07 AM
    #502
    jcroberts1972
    jcroberts1972 Active Member
    Jeff
    Arlington, VA
    2017 4X4 SR5
    I'm glad it worked out for you. Mine is still messed up, better but still not right. Hopefully it works out someday?
  3. May 22, 2018 at 10:53 AM
    #503
    Zoop
    Zoop Well-Known Member
    Dealer is installing new leafs and some cab mount dampeners, I didn't qualify for the driveline vibration TSB but I did for the diff howl TSB, looks like the leaf packs have different part numbers but hopefully it will resolve both issues!
    jcroberts1972 likes this.
  4. May 24, 2018 at 5:12 AM
    #504
    jcroberts1972
    Jeff
    Arlington, VA
    2017 4X4 SR5
    Well, I would like to know how it works out when you get it back! Why did you not qualify for the Driveline TSB?
  5. May 24, 2018 at 5:21 AM
    #505
    Zoop
    It looks like the driveline TSB specifically states not for "Off Road" models, also my VIN was not included, the leaf spring part numbers were different between that TSB and the diff howl leaf springs TSB. I assume they may be slightly different, my hope is that the diff-howl one will correct the rumble strip effect since they both involve changing the angle through the leafs.
  6. May 24, 2018 at 5:27 AM
    #506
    jcroberts1972
    Jeff
    Arlington, VA
    2017 4X4 SR5
    What is the diff-howl, because mine is still not fixed after the TSB..?
  7. May 24, 2018 at 5:41 AM
    #507
    Zoop
    The TSB is T-SB-0013-18, includes new leaf springs and "dynamic dampeners" on some of the rear cab mounts. The driveline fix is T-SB-0171-16
  8. May 30, 2018 at 10:41 AM
    #508
    Zoop
    Got the new leafs and dampeners installed, haven't heard a howl yet and it it's there, it's very faint.
  9. May 30, 2018 at 7:49 PM
    #509
    adambianchessi
    adambianchessi New Member
    2016 Tacoma TRD Sport 4x4
    K&N cold air intake Icon stage 1 suspension with 3in. lift
    Hello, I recently got a icon stage 1 suspension kit for my 2016 TRD Sport. I had the mechanic bring it up to 2.5in. I noticed a "pulsing" vibration from 10-40mph now. Is this the same kind of problem the people in this thread are having?
  10. May 31, 2018 at 6:50 AM
    #510
    Zoop
    Nope.
  11. Jul 7, 2018 at 5:55 PM
    #511
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    list is growing fast
    looks like you didn't get an answer? You likely have the needle bearing failure that is common with your lift. https://www.tacomaworld.com/threads/front-diff-vibes-ecgs-bushing-fix.464941/#post-13883949
  12. Jul 7, 2018 at 6:13 PM
    #512
    adambianchessi
    Thanks a lot! That thread has the exact kind of problem I'm having!
    RangerComa likes this.
  13. Jul 7, 2018 at 6:29 PM
    #513
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
  14. Oct 15, 2018 at 4:55 AM
    #514
    Keelar
    Keelar Member
    2018 Sr5 Tacoma double cab
    Good morning. I have a 2018 double cab sr5 2wd v6 auto with 3600 miles and it is showing the rumble strip condition from 30 to 10mph when decelerating. Are any 2018s covered in this tsb?
  15. Oct 15, 2018 at 6:56 AM
    #515
    RangerComa
    RangerComa 58008
    Adam
    Marin, CA
    17 DCLB
    I've got rumble strip feeling at lower speeds but I'm pretty sure it's my tires.
  16. Oct 17, 2018 at 2:24 PM
    #516
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    Rotate your tars and see if it goes away
  17. Oct 23, 2018 at 3:05 PM
    #517
    dozer711
    dozer711 Well-Known Member
    Upstate, NY
    '19 SSM Limited, '09 DCSB MGM OR
    I have it on my 2019 also, it's done it since I got it a couple weeks ago. Toyota rep said it's the transmission and there working on it
    Evlkarl likes this.
  18. Oct 25, 2018 at 9:37 AM
    #518
    jcroberts1972
    Jeff
    Arlington, VA
    2017 4X4 SR5
    Sorry I just saw this.. Not to sure, but I would head to the dealer and have them check?
  19. Oct 25, 2018 at 9:39 AM
    #519
    jcroberts1972
    Jeff
    Arlington, VA
    2017 4X4 SR5
    I bought the Shiftsense pro V2.. look it up on youtube.
  20. Oct 25, 2018 at 9:40 AM
    #520
    jcroberts1972
    Jeff
    Arlington, VA
    2017 4X4 SR5
    It's not that easy... I've had the truck through 3 tire rotations, new brakes and 2 TSB's... I wish I was just that stupid!
