oh no....TSB-0171-16 Driveline vibration
Discussion in '3rd Gen. Tacomas (2016+)' started by Murrayb4, Dec 7, 2016.
  1. Jun 12, 2019 at 7:28 PM
    #641
    camillethetoy
    camillethetoy Just a Minor Threat
    jeremy
    Leanderthal, TX
    10 FJ TT
    WoodsGhost likes this.
  2. Jun 12, 2019 at 7:29 PM
    #642
    camillethetoy
    jeremy
    Leanderthal, TX
    10 FJ TT
    Totally just put my whole response inside your quote, haha, my b
  3. Jun 12, 2019 at 8:07 PM
    #643
    Always Be Blazing
    Always Be Blazing Well-Known Member
    Florida
    2018 4x2 V6 SR5 DCSB BBP OMG
    I have a faint pulsing/rumbling when decelerating under certain conditions but I don't have any of the wheel/pedal shaking that some people report. To be honest, I barely notice it now. I'm not sure when it began but I've driven the truck about 7k miles now and it doesn't feel like it's gotten any worse.
    The only other issue that has ever stood out to me is the acceleration does feel anemic sometimes, but again, it's not something that has been a persistent problem with my truck. I can drive for days and not notice anything, then I'll have a random moment where it feels a bit sluggish and I'll just give it a little more gas and everything is fine.
    With all of that said, I mainly use my Taco to commute on flat Florida roads and occasionally haul a dog and other random crap in the bed, so it's not like I'm demanding a lot from it. I really enjoy driving it though and have no regrets about my purchase.
    WoodsGhost and camillethetoy like this.
  4. Jun 13, 2019 at 3:16 AM
    #644
    WoodsGhost
    WoodsGhost Well-Known Member
    PA
    2017 DCSB OR:2016 4Runner
    Thank u @camillethetoy and @Always Be Blazing for the response.
    I can totally agree about holding these trucks to a higher standard. I think thats why i have been a little extra disappointed a few times with my 12. Like having the 4wd issues, squeaky clutch, broken leaf spring,etc.
    Anyways thanks again.
  5. Jun 13, 2019 at 8:21 AM
    #645
    El_Taco_Blanco
    El_Taco_Blanco Well-Known Member
    New Mexico
    2018 TRD OR DCSB
    Having had two 3rd gen Tacos and more mechanic visits over the last 2 years than all the other vehicles I have owned COMBINED, I would not recommend buying one.
    camillethetoy and WoodsGhost like this.
  6. Jun 13, 2019 at 12:04 PM
    #646
    WoodsGhost
    PA
    Sorry to hear that. Issues with both?
  7. Jun 13, 2019 at 12:55 PM
    #647
    El_Taco_Blanco
    New Mexico
    2018 TRD OR DCSB
    Long story short, first tacoma (2017 SR5) had the same issues, 5 attempts to repair with no fix led to Toyota buying back under lemon law. 2nd truck (2018 TRD OR) has the same issues, has had 5 attempts at fixing, Toyota denied buy back stating that the issue was not wide spread so it must be driver error. My fear is that the issue of bad rear brakes and shaking/vibration will lead to a larger and costly problem down the road.
  8. Jun 13, 2019 at 2:00 PM
    #648
    WoodsGhost
    PA
    Hope things get better for ya. Im trying to wait as long as possible before i sell/trade mine
  9. Jul 14, 2019 at 12:30 PM
    #649
    DP1989
    DP1989 Member
    2019 TACOMA
    I’m having the same problem with my 2019 only has 154 miles on it I feel the vibration while stopping from about 30-10 mph, is this common for the in the 2019’s also? Can Toyota do anything?
  10. Jul 14, 2019 at 2:03 PM
    #650
    Mrtoad25
    Mrtoad25 Well-Known Member
    Reno NV.
    2016 TRDSport
    What if you guys replaced the rear stock shocks to Fox or Icon. Maybe it would help with shaking......
    Skull likes this.
  11. Jul 14, 2019 at 2:40 PM
    #651
    DP1989
    DP1989 Member
    2019 TACOMA
    I do replace them it’s the same it feels like it’s the transmission doing it
  12. Jul 15, 2019 at 1:27 PM
    #652
    Skull
    Skull Well-Known Member
    Karl
    NC
    2019 White TRDPro
    Nope
  13. Jul 15, 2019 at 1:27 PM
    #653
    Skull
    Karl
    NC
    2019 White TRDPro
    Nope
  14. Jul 15, 2019 at 2:41 PM
    #654
    Mrtoad25
    Reno NV.
    2016 TRDSport
    Hey scary clown. Turn that Nope upside down....
  15. Jul 16, 2019 at 4:01 PM
    #655
    Keelar
    Keelar New Member
    2018 Sr5 Tacoma double cab
    I took mine to 2 different dealers and left it at one of them for almost a month for them to just tell me the shake is normal operation. The worst part is I believe them after driving about 8 different Tacomas. Some are worse than mine and the only ones that seemed better were the TRD Sports I drove. I also have another guy at work with the same issue on his 2018 TRD Sport.
  16. Jul 16, 2019 at 11:10 PM
    #656
    c3nriqu3z
    c3nriqu3z Well-Known Member
    Chuck
    94544
    2017 Tacoma OR
    I’m having the same issue with mine. I have a 2017 OR with about 30k on it. Low speed vibration started happening right after I got my lift about a month ago. Hoping replacing the needle bearing will fix the issue. Will post an update once I get it done.
  17. Jul 19, 2019 at 4:57 AM
    #657
    El_Taco_Blanco
    New Mexico
    2018 TRD OR DCSB
    You need to shim your driveshaft. Vibrations noticed after lift are a result of the excessive wobble in the driveshaft joints.
  18. Jul 19, 2019 at 9:27 AM
    #658
    c3nriqu3z
    Chuck
    94544
    2017 Tacoma OR
    Thanks. Will be looking into this as well.
  19. Jul 20, 2019 at 9:35 AM
    #659
    T-Unit
    T-Unit Member
    Trent
    2019 SR5
    Stock
    I crawled under the truck and noticed the cup (piece of metal holding the drive shaft up) bearing was bolted on crooked. I loosened the bolts and eyeballed it and tightened the bolts. This helped a little with the vibration as if the drive shaft was misaligned. But still feel it a little....however more tolerable. BTW bone stock no lift
  20. Aug 1, 2019 at 8:37 AM
    #660
    BLK_TRD
    BLK_TRD Member
    2019 Black TRD D-Cab
    I have the bad vibes when braking. This is on my 2019 TRD OR with 2000 miles. Had it in once to have the dealer check it. They just did a brake inspection and said they wanted to wait until 5000 service to check it again and that's it. I opened a case with Toyota on July 31 and today they called back saying they have a new TSB, T-SB-0071-19 and want me to take it in to my dealer to diagnose if this TSB covers or fixes the issue I'm having. fingers crossed. This is the 6th Tacoma I have owned and none of them had this issue while braking except this one the newest and most expensive one.
    camillethetoy likes this.
