oh no....TSB-0171-16 Driveline vibration
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Murrayb4, Dec 7, 2016.
  1. May 6, 2020 at 9:13 AM
    #821
    BLK_TRD
    BLK_TRD Well-Known Member
    Chad
    Pennsylvania
    2021 RAV4 XSE Hybrid. 2019 Black TRD OR DCSB *Sold
    I never did get this resolved by Toyota. But after putting on new eibach shocks and a steel rear bumper it mostly went away.
  2. May 6, 2020 at 10:01 AM
    #822
    Mitch65
    Mitch65 Well-Known Member
    The reason why is the weight of the steel bumper. Iv noticed that even if I put 50-60lbs at the rear of the bed I don’t get the vibes anymore.
    I’m having a bedrack put on here soon so I’m
    Hoping just having that back there will correct most of it
  3. May 6, 2020 at 10:53 AM
    #823
    BLK_TRD
    Chad
    Pennsylvania
    It might. I think the suspension really helped too!
  4. May 10, 2020 at 4:24 PM
    #824
    Amanhowzit taco
    Amanhowzit taco Well-Known Member
    Adam
    Hawaii
    2017 sr5 4wd Tacoma
    265/75/16 tires only everything else stock.
    I just installed a roof rack and now I have driveline vibrations when going between 48-54 mph. It goes away before and after those speeds. Stock on 265-75-16 only weight is the roof rack and a 60 pound camper. Plus humans and some cargo.
    Any ideas?
  5. May 10, 2020 at 11:09 PM
    #825
    Mitch65
    hmmm. What rack do you have? The rack itself would not cause a “driveline vibration” but could cause a vibration I suppose. I think wind is catching an off-angle on that rack and causing it to vibrate at that speed and your feeling that in the truck. I would make sure everything is tight and installed correctly. If you had no vibration before the roof rack then I’m 99% sure it’s how the wind is catching it at those speeds. The rack is vibrating and transferring that down where you can feel it.
  6. May 10, 2020 at 11:47 PM
    #826
    Amanhowzit taco
    Adam
    Hawaii
    2017 sr5 4wd Tacoma
    I have a up top bravo.
    It’s weird I can feel it all the way in my steering wheel, I checked to see if everything is tight and it is. I will double check again before I drive. It was super windy hitting the side of the truck. It definitely would go away then come back. It’s probably nothing I hope. I swear this site makes me more paranoid then I should be lol.
    I made sure I installed it correctly,
    but I wonder why it sits on metal to
    Metal. The spacers sit over the threaded holes to attach the rack to the roof. It has spacers without any rubber to give it some cushion. I don’t know just my 2 cents.
  7. May 11, 2020 at 8:48 PM
    #827
    dhectorg
    dhectorg Well-Known Member
    Don
    2020 Toyota Tacoma TRD OffRoad
    My DCLB OR has vibrated in that speed range from day one, as with MANY other owners on here, as well as at higher speeds in 70s and above, but it's definitely worst at around 50. Frankly, I doubt it has anything to do with your rack. A lot of Tacomas vibrate.
  8. May 11, 2020 at 10:47 PM
    #828
    Amanhowzit taco
    Adam
    Hawaii
    2017 sr5 4wd Tacoma
    Really? That’s lame mine has never done that and I’m 800 miles from 40 k
    I went to tighten the rack and a few screws needed tightening.. not sure if they got loose or I didn’t tighten all the way but I’ll report back after I take it for a drive tomorrow.
  9. May 11, 2020 at 11:23 PM
    #829
    dhectorg
    Don
    I'm surprised you never had any vibrations before. I hope you get lucky and figure it out, but after fighting with Toyota for weeks and wasting a whole lot of time at 2 different dealership I gave up in order to preserve my sanity. Toyota made it very clear that there's no problem as far as they're concerned.
  10. May 15, 2020 at 10:20 AM
    #830
    pescadoman66
    pescadoman66 Pescadoman66
    CJ
    Livermore, CA
    2017 TRD OR 4X4 Pro Wannabee Stormtrooper
    Tacoma Pro Front Grille Tailgate Letters Console Organizer Clazzio Seat Covers TRD front Grille Emblem Westin Drop Steps Front Widow Tint Tow Strap LED lights Sunshade Prinsu Rack BackFlip Cover rack accessories crutchfield speakers Front Tweeter speakers Tuffy box sound deadening mat Westin LED light bar Led switch Light bar bracket TRD Pro Tail lights TRD Pro Wheels BF Goodrich KO2 tires from America's Tire Old Man Emu Lift Coils - Coil Selection: 2887 Bilstein 5160 Rear Shock with Reservoir Bilstein 5100 Adjustable Front Struts HeadStrong 3 leaf progressive Add-a-leafs JBA UCA's Low Range OFF-Road 1.25" Cast aluminum blocks in the rear
    Same...
  11. May 18, 2020 at 4:14 PM
    #831
    bizjettech
    bizjettech Well-Known Member
    Sunny Florida
    I've got a 2020 SR5 Double cab 4x2 with the ever complained about vibration while decelerating, mostly in the 30 mph and 20 mph deceleration area.
    It has nothing to do with the brakes. It's noticeable - I see a lot of replies from Toyota tech's that this is "normal" - well I think that is BS - Has
    anyone had ANY sucess it rectifying this?? If I cant get it resolved I'm going to push for a "Buyback" - Has anyone actually had a buyback performed ??
  12. May 18, 2020 at 4:38 PM
    #832
    4x4spiegel
    4x4spiegel Well-Known Member
    think they are too few and far between , need to lawyer UP^
  13. May 18, 2020 at 5:27 PM
    #833
    dhectorg
    Don
    You'll never get a buyback for this issue. Toyota absolutely refuses to acknowledge that it's a problem, even though it obviously is. I opened a case with Toyota for severe vibrations at various speeds and while decelerating. I did so within a few days of buying my 2020 DCLB OR. I had the truck checked by 2 different Toyota field techs at different dealers. They told me what they tell everyone who complains about vibration... everything is to spec, so no action will be taken. At that point, you can either sue them and lose...and be out the cost of a lawyer or just deal with the vibration. I chose the latter even though I love to fight with corporations. I know when I'm beaten.
    All you have to do is read the many discussions on this forum and others to know that vibration is a widespread issue with Tacomas, both 2nd and 3rd gens. It doesn't help our case that there are a lot of fanboys on these forums carrying Toyota's water on this issue. If everyone who has these issues opened a complaint instead of pretending their trucks are perfect, we might be able to draw enough attention to get some resolution.
  14. May 19, 2020 at 8:03 AM
    #834
    Mitch65
    I believe this issue it’s much to common to force a buy back from it. I’m willing to bet 2/3rds of all Tacoma’s do it some degree. My buddy’s truck has it and he put 20k miles on it and didn’t even realize it until I pointed it out to him.
    the only real way to fix it is shims in the rear. There is a thread somewhere on here showing how to measure driveline angles and shims
  15. May 27, 2020 at 9:06 AM
    #835
    zx10_afm
    zx10_afm Well-Known Member
    West Coast (Best Coast)
    2006 Lexus GX470
    Nope. I experimented with shims and it didn't do anything.
    I measured with a protractor and the angles were already within spec before I made changes.
  16. May 27, 2020 at 9:26 AM
    #836
    Mitch65
    Hmmmm. Iv seen a few posts of people saying the addressed it with shims but I have no first hand experience with it. Iv decided with my truck it’s not going to go away so I’m just going to live with it. IMO it’s not that bad
  17. May 31, 2020 at 11:05 PM
    #837
    Rexy
    Rexy New Member
    2020 Tacoma SR5 Double Cab
    New 2020 Tacoma SR5 just purchased. Mine also has a mild steering wheel vibration when accelerating at low speeds only. Has 150 km on it now, so gonna drive it a little more and hope it settles before taking it back in.
  18. Jun 2, 2020 at 9:52 AM
    #838
    Greg.Brakes.Tacos
    Greg.Brakes.Tacos Don't Feed the Animals
    Greg
    Between Richmond and Virginia Beach
    2017 Taco DCSB TRD off road
    wanna be mods
    Do you have a link or those angle specs handy?
  19. Jun 4, 2020 at 5:05 PM
    #839
    abhamber
    abhamber Well-Known Member
    Aman
    Alberta, Canada
    2018 BBP Tacoma TRD Sport DCLB
    I'm sad to report back, but after having new axles, bearing and seals installed, the vibrations have returned about 8000 miles later.
    I'm honestly at a loss on how to continue with this issue. The last thing I want to do is waste time at a dealership and watch them replace parts that won't address the root cause.
    Could worn shocks or warped rear drums possibly play a role?
  20. Jun 4, 2020 at 11:36 PM
    #840
    Mitch65
    after chasing this problem for the last 6 months on my truck I have accepted that this is just how a lot of these trucks are. When my truck only had 600 miles I took it in for this and after not being able to solve the problem I test drove 2 brand new ones and they both did the same thing.
    your going to have to accept it like I did or trade the truck in because you will never be happy.
    I’m also happy to report my buddies 2016 just passed 120k miles and his has this Small rumble vibration from day one and it has not caused him any issues in the long run.
