oh no....TSB-0171-16 Driveline vibration
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Murrayb4, Dec 7, 2016.
  1. Sep 22, 2021 at 2:01 PM
    #901
    2k2
    2k2 Flareless
    Zak
    Gen 3 SR 4x4 4cyl AC
    See Build Thread
    2020 SR 4x4. No vibration of any kind for first 18k. Drove like a sedan. Out of nowhere I started to feel like a rear wheel was out of balance after a 200 mile trip at 75-80 mph. Took it in for my final toyota care service had them balance all 4 wheels. Vibes still there. Torqued loose u bolts to 52 ft lb. Vibes still there. WTF. Went from driving like a luxury sedan to driving like my 02 in a matter of a day. Anyone get anywhere with solving this. I can live with it, but I dont want to.
    BTW: aside from SCS f5 wheels and SL wildpeak tires I'm bone stock on the SR. I've had wheels and tires since 1200 miles so I really dont think it's that but who knows. Evert AT tire I've ever had has eventually driven like garbage after 20k. So maybe it's the tires.
    One thing I do notice is that where the passenger side shock boot comes in contact with the shock body the paint is worn off... my drivers side shock foes not look worn at all?
  2. Oct 13, 2021 at 2:49 PM
    #902
    ItsGarand
    ItsGarand TEUFELSBERG
    South of Baltimore
    2021 Taco Access Cab SR5 4x4
    Added NERF Bars.
    I have the same issue with my 2021 SR5 Access Cab. I took it in to the dealer, they said yes to the repair. They put new leaf springs on but I'm not sure they did anything else. They are supposed to check the angle of the drive shaft and adjust according (which I hear is time consuming - so they probably didn't do it.)
    I went with a lead tech for a ride in it, it still vibrates when decelerating - his answer was it's engine braking....
    So, I have about 6k on it now and it still vibrates - annoying so - when slowing down particularly at around 1.2krpms at 20+ mphs. It's like driving over closely spaced shallow rumble strips.
  3. Oct 13, 2021 at 4:01 PM
    #903
    VB25
    VB25 Well-Known Member
    2018 TRD OR ACLB AT
    Exactly how mine feels, But since it's a TRD OR AC its not covered under the TSB. The dealer said its caused by corrosion in the drum brakes and wanted to charge me over 600 to fix. They completely ignored the fact that I said it happens without applying brakes, and that coasting to a stop in neutral is perfectly smooth. Too bad most Toyota dealers seem to suck... I'm not hard to get along with. I popped off the drums a few months after and there was no corrosion or irregular wear to be seen.
  4. Oct 20, 2021 at 9:31 AM
    #904
    N22WLZ
    N22WLZ Member
    2021 SR V6 AC
    I replaced my 08 Prerunner with a 2021 SR access cab V6 only because of driveline vibration that could never be resolved. The new 3rd gen has the same irritating driveshaft rumbles from 47-55 MPH since day one. I also had brake shake due to one of the drums being out but that was a cheap easy fix. Eventually a cv driveshaft should make it drive like a new $35,000 vehicle LOL
  5. Nov 10, 2021 at 7:48 AM
    #905
    TheBeerBladderMonster
    TheBeerBladderMonster Active Member
    2021 4x4 Toyota Tacoma SR Access Cab
    Tonneau Cover and Side Rails
    Same issue here. 2021 V6 Access Cab.
    First trip in was told I had warped drums, fixed it and seemed better.
    Then I had the issue where the truck would still shake in the steering wheel, gas pedal and seat when accelerating and coming to a stop with or without braking around 15- 30 MPH.
    My dealership took it in for 11 days before I was told my leaf springs needed to be replaced.
    It actually fixed the issue for the most part at low speeds. But it seemed to just push the vibrations into the 45-60 MPH range oddly enough. Not horrible but noticeable.
    I decided to trade it in and get a 4x4 SR access cab. No issues so far.
  6. Dec 3, 2021 at 12:35 PM
    #906
    sfr4dr
    sfr4dr Well-Known Member
    Truckee/Tahoe CA
    Currently trying to pick my next Toyota!
    So.....this issue is still present on the 2022s but the TSB doesn't cover them yet. Not that it would matter since there's plenty of proof on here that the TSB "fix" usually doesn't do anything. So what are people to do that have this and the dealer just says "normal"?!
    I know no one here will know this but I wonder what percentage of new Tacoma's have this vibration, including those that have it but the owners' are oblivious to it.
  7. Dec 3, 2021 at 12:46 PM
    #907
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    I do think that some amount of vibration IS normal. My 18 OR had the same amount of vibration my 19 pro does. Both became worst (noticeable) over 10,000 miles.
    The car care nut on his YouTube channel mentioned it was a thing on these trucks.
    I mostly only notice it at idle, as it’s subtle. Nothing I pay much attention to.
  8. Dec 3, 2021 at 2:51 PM
    #908
    sfr4dr
    Truckee/Tahoe CA
    I had a 2018 SR that didn't have any vibrations at all but the transmission shifting wasn't ideal. So are you saying your 18 and 19 only vibrated/vibrates while at idle at 0 MPH and not the 32-10 MPH this thread is talking about?
  9. Dec 4, 2021 at 7:12 PM
    #909
    ItsGarand
    South of Baltimore
    Added NERF Bars.
    I opened a national ticket with Toyota on the issue. After several phone calls and explanation of the issue, they had me bring the truck back to the dealer that did the TSB. They drove it and basically said yes, the vibration is still there. Toyota had them drive other Taco to see if the vibration was noticeable in another one. The dealer said yep, vibration in the other as well. Toyota then said that this was "normal" so....
    the ticket was closed. nice.
    2021 Taco access cab, rumbles to a stop. As I said before - especially when coasting or coming to a stop. Smooth until it hits about 25mph and the RPMs drop then starts vibrating as it slows. I can hear it and I can feel it, especially in the steering wheel.
    sfr4dr likes this.
  10. Dec 15, 2021 at 7:38 PM
    #910
    Jerry311SD
    Jerry311SD Well-Known Member
    Jerry
    Ramona Ca SAN DIEGO
    2019 tacoma TRD Quicksand
    KDMaxx tune K&N drop in AFE catback Oil catch can Bill's 6112/5160 Dynomat whole inside of cab TRD skid plate
    2019 TRD off-road
    49k miles
    I have the same 20 mph shudder slowing down.
    All stock suspension.
    Only mods are intake,exhaust,KDMax tune.
    Kinda wondering if i should take it in or just live with it.
  11. Dec 20, 2021 at 11:11 AM
    #911
    sfr4dr
    Truckee/Tahoe CA
    Up to you. If you have the automatic, you could probably get the TSB done BUT it sounds like it often doesn't even fix it. Other options to test are shims, then on to the pricier things like new rear springs or a 1 piece drive shaft. Let us know which way you go, if any.
    Jerry311SD[QUOTED] likes this.
  12. Dec 20, 2021 at 11:42 AM
    #912
    Jerry311SD
    Jerry
    Ramona Ca SAN DIEGO
    I really dont want to take my truck in with a KDMaxx tune aftermarket Exhaust and Intake. And deleted PVC system just for something they might not fix/normal for Tacoma.
    I guess ill just live with it. For now.
  13. Dec 27, 2021 at 8:19 AM
    #913
    RCrumb
    RCrumb Dumb as Dirt
    CANADA
    2020 TRD OR Premium-Auto
    2020 TRD OF DC, 6k miles, no mods, all stock, vibration has been present for a while, so bad the dash shakes when decelerating from about 40mph. They replaced both rotors and drums, no improvement. Goes back tomorrow for some more look see. Fingers crossed.
    sfr4dr and Jerry311SD like this.
  14. Jan 3, 2022 at 1:36 PM
    #914
    sfr4dr
    Truckee/Tahoe CA
    Can anyone confirm in the TSB fix comes with axle shims of any kind that adjust the pinion angle? Some users say it does but it's not mentioned in the TSB.
  15. Jan 4, 2022 at 6:11 AM
    #915
    RCrumb
    RCrumb Dumb as Dirt
    CANADA
    Update. Replaced rear drums acct new were out of round, checked new to ensure no issues before installing. Problem solved. Smooth as silk.
  16. Jan 4, 2022 at 11:07 AM
    #916
    sfr4dr
    Truckee/Tahoe CA
    The TSB mentions standard springs and stiff springs, both from the OE factory build. Does anyone know how these two different OEM (pre-tsb fix) springs affect which trucks vibrate and which don't? I'm wondering if the trucks with the stiff springs tend to not have this issue and the soft spring trucks end up vibrating more often...
  17. Jan 29, 2022 at 5:15 AM
    #917
    TracknRoll
    TracknRoll Member
    Dan
    Tacoma Limited 2021
    I have the same vibration issue. I noticed it from day one on my 2021 limited 4x4 while I was driving home right from the dealer. I never had that issue with my 2015 TRD OR 4x2 that I drove since new and traded in for this one. Frankly I didn’t know what to make of this, so I googled it and eventually read about here at TW. Now that I know is a common thing, I tend to ignore it. I haven’t taken it for my first oil change yet since it only has 3,600 mile on it but when I do, I’ll bring it up with my service rep and see what he says.
    hope he doesn’t give me the runaround since I changed the suspension to the TRD OR and swap out the Michelins for KO2 tires. I just didn’t like the soft bouncy bounce of the combination of the Michelin stock tires and the SR5 stock shocks it comes with. Now I get the ride I was used to which is much more firm and planted. Well we’ll see what they say.
  18. Jan 29, 2022 at 6:38 AM
    #918
    RCrumb
    RCrumb Dumb as Dirt
    CANADA
    Suggest you get it into the stapler ASAP as brakes (if it's that) only carry a 12 month warranty. Good luck.
  19. Jan 29, 2022 at 8:32 AM
    #919
    TracknRoll
    TracknRoll Member
    Dan
    Tacoma Limited 2021
    I swapped out my stock standard suspension on my 2021 limited that comes with the regular SR or SR5 shocks and spring to the more robust TRD OR Blistein shocks and springs which are more stiff and I still feel the vibration.
    sfr4dr[QUOTED] likes this.
  20. Jan 30, 2022 at 8:34 PM
    #920
    WoodMan NH
    WoodMan NH Active Member
    Woody
    '17 Tacoma DC LB 4x4 Dark Gray
    Chrome Tubes, Chrome Exhst Tip (yeah, I like the chrome look), Mudguards, HomeLink AutoDim Mirror
    All - I just had my Taco in to fix rust on my inner door sills on a goodwill warranty (T-SB-0021-19 "Paint Blistering Due to Corrosion on Lower Door Sill" 2016 thru 2019) . . . it took a week, so dealer had it pre-aproved to give me a '21 Taco DCLB rental . . . the '21 Taco w/ 3,600 miles vibrated worse than my '17 w/ 29k miles, and the '21 had a brake pulsation to boot.
    Getting tired of this driveline vibration issue.
    I know likely a different string, but if you have any paint blistering / rusting on your lower door sills on your 3rd Gen, please bring to attention of your service manager re: above mentioned TSB to get it fixed (even though the vibration will still be there).
    sfr4dr likes this.
