oh no....TSB-0171-16 Driveline vibration
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Murrayb4, Dec 7, 2016.
  1. Dec 18, 2016 at 8:20 PM
    #101
    RBfastback
    RBfastback It's Got Electrolytes
    mike
    FL
    16 mgm TRD off road
    is there an aftermarker steering stabilizer or steering dampener available?
  2. Dec 18, 2016 at 10:19 PM
    #102
    PEAKIT
    PEAKIT Well-Known Member
    UT
    24 Off Road long bed Premium Taco.
    OME 888 nitro front, SPC upper arms,B110 rear shocks, Timberen bump stops, extended brake hoses, U bolt flip, sway bar delete, Dakar HD leaf pack with extra leaf, Snug top HD shell, MobTown Skid plate, cooper Maxx 255-85-16 4:88 Nitro gears,Spider trax 1.5 spacers, AirBedz, debadge, Pro grill.
    Can you use the St George Toyota? It never looks busy when I'm down there.
  3. Dec 19, 2016 at 2:08 AM
    #103
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    So... has anyone that has had the leafs replaced STILL feel the vibe?
    I do
  4. Dec 19, 2016 at 11:37 AM
    #104
    mykafone
    mykafone Member
    Micah
    2016 Taco
    I have 16 Sport Manual.. Never felt the vibe. but, I added 5100s, and an AAL in the rear and now i feel it.. Bummer!!!!!
  5. Dec 19, 2016 at 7:39 PM
    #105
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    I took my truck in right before this TSB came out. They authorized my dealer to check the angles and were going to authorize this same fix if mine met the requirement.
    Do you guys know if that BS angle requirement still exists? Somehow I'm within their spec (or was a couple months ago).
  6. Dec 20, 2016 at 1:23 AM
    #106
    BlkTaco47
    BlkTaco47 Unhinged
    Picking mine back up....again...today
  7. Dec 20, 2016 at 4:45 AM
    #107
    moliTacoma
    moliTacoma New Member
    2016 TRD Sport
    Yes, I do as well. It's better, but still feel the rumble strip ever-so-slightly...and still have vibrations at 50 mph.
  8. Dec 20, 2016 at 4:48 AM
    #108
    Scooby24
    Scooby24 Well-Known Member
    Greg
    2017 DCSB OR 4X4
    Your vibrations go away in 4h?
  9. Dec 20, 2016 at 5:08 AM
    #109
    moliTacoma
    2016 TRD Sport
    Pre-tsb, I tried that and it didn't take away the vibes. Haven't tried since getting the tsb done last week. Will try soon.
    Update: Just tried 4H last night, no difference. Here's something interesting though...prior to this tsb and the new leafpacks, I would get the rumblestrip around 20 mph, and vibes when driving at 35 mph and 50 mph. Now, the rumblestrip is pretty much gone (not completely, but I can live with it) and the vibrations have shifted to 40 mph and 55 mph and are a little less bad. Does that make sense to anyone? Thinking that the change in angle with the tsb shims helped, but perhaps I still need more of an angle adjustment?
  10. Dec 20, 2016 at 5:24 AM
    #110
    BlkTaco47
    BlkTaco47 Unhinged
    Fixed!!!!!!! 14 months of bitching to them and dealing with shaking and shitty
    driving and it finally drives like a new vehicle!
    Work done....
    Steering wheel dampener
    Both leaf packs
    Both brake drums
    Adjustment to drive line angle
    ELTACO13 and Arrampico like this.
  11. Dec 20, 2016 at 5:26 AM
    #111
    Koitz
    Koitz Well-Known Member
    2016 TRD sport 4x4 DCSB 2" lift 285/65/18 and loaded
    2" lift,18"rims, 32" tires,pro shifknob, black emblems etc
    Did your pedal vibrated before the tsb?
  12. Dec 20, 2016 at 5:29 AM
    #112
    BlkTaco47
    BlkTaco47 Unhinged
    The floor on the left always has. It is very minimal now, I gave up on that
    fix - it's most likely the engine mounts. I have the Husky WB Mats so I glued some
    foam under the left side and for the most part it's gone, if I feel it at all I'll just
    crank up the ported sub box. :D
    Koitz[QUOTED] likes this.
  13. Dec 20, 2016 at 5:30 AM
    #113
    Koitz
    Haha
    Thanks
  14. Dec 20, 2016 at 5:35 AM
    #114
    BlkTaco47
    BlkTaco47 Unhinged
    lol. I asked about it on both of my service visits and they said we can
    replace all the mounts at YOUR cost, said not a fukin chance. Pay to fix a
    toyota issue on my NEW truck!?! Lololol
    jclay and Koitz[QUOTED] like this.
  15. Dec 20, 2016 at 2:36 PM
    #115
    WebFoots
    WebFoots Active Member
    2016 Silver Double CabTacoma SR V6 4x4
    So I made an appt for 5k miles service and mentioned this tsb as well as the trans. Rep kept telling me there were no recalls. I agreed and tried to tell here they were service bulletins.
    I will show up with them printed out.
    Question:
    The tsb states it is for all 2016 tacomas not OR, then there is a section with VINs listed. Mine ends in 42xxx, and the list shows 39xxx. Will it still apply to my truck? It does exibit a slight vibration as described.
  16. Dec 20, 2016 at 3:31 PM
    #116
    Contra472
    Contra472 Well-Known Member
    2016 Tacoma DCSB 4X4 OR
    At the dealer now. They will not perform TSB on my truck , cause it's an Off Road.
    Only one dealer in my city. Game over.
  17. Dec 20, 2016 at 3:41 PM
    #117
    goose443
    goose443 Well-Known Member
    Austin
    Texas
    2016 Tacoma TRD Off Road 4x4
    Same thing happened to me. I am currently arguing with corporate
    sakibomb likes this.
  18. Dec 20, 2016 at 3:43 PM
    #118
    Koitz
    Good luck with that ! Lol
  19. Dec 20, 2016 at 3:52 PM
    #119
    Contra472
    I've tried the corporate route . Case numbers...Case managers....field techs......
    In the end, they will all say the same damn thing
    "Vibration is a normal characteristic "
    However, MAKE SURE you get a free 7-8 year platinum warranty from corporate when you complain. They will give it to you fairly easily to try to appease you. A little reassurance in case our trucks vibrate themselves apart after the 36K warranty is over.
    goose443[QUOTED] and Koitz like this.
  20. Dec 20, 2016 at 3:59 PM
    #120
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    This is not Toyota QUALITY but they try to pass that off as a fix and solution .....
