Oil Catch Can Install Guide
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CayucosTacoma, Jul 25, 2012.
  1. Dec 31, 2012 at 3:33 PM
    #321
    seric007
    seric007 Well-Known Member
    i think your going to have a hard time combating that problem it its freezing as is. :( if i was you, i'd consider putting on the factory plumbing until it warmed up outside... just my 0.02 however
  2. Dec 31, 2012 at 3:40 PM
    #322
    Bhwang
    Bhwang Well-Known Member
    Josh
    Canada
    Tacoma
    Working on it. Never Ending :)
    Yah that thought is in the back of my mind, I figure someone else has to use a catch can in the same weather and I wanted to see if they had any problems, Thought maybe I would try the steel wool first and if no fix, then back to stock for the winter.
  3. Dec 31, 2012 at 3:45 PM
    #323
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    if it's freezing now, steel wool won't help. you need to get heat over to the catch can or anti-freeze
  4. Dec 31, 2012 at 3:53 PM
    #324
    Bhwang
    Josh
    Canada
    Tacoma
    Thamks for the advice, I will probably just take out the catch can till the summer for now, but living in Canada it seems anytime unless its the middle of summer it can get cold (in the minuses), so probably best not to even run it eh haha
  5. Dec 31, 2012 at 3:56 PM
    #325
    ImpulseRed008
    Susan
    SC
    maybe wrap the hoses and catch can in some insulation :notsure:
  6. Dec 31, 2012 at 4:07 PM
    #326
    Bhwang
    Josh
    Canada
    Tacoma
    Thanks for the advice, but the truck will be fine with the normal hoses again i figure. Just burn off that oil sludge now.
  7. Dec 31, 2012 at 5:57 PM
    #327
    SkeeterBilt
    SkeeterBilt Zombie
    Skeeter
    Sierra Vista, AZ
    07 Prerunner DC LB TRD Zombie Response Team
    Black Satoshi Grill, Blacked Out Head Lights & Fog lights, Tint, Vent Visors, Shaved Emblems, Oil Catch Can, Ipod Hookup to Stock Head Unit, Sony Speakers, TRD Seat Covers, Xtra D-Rings and Other Small Things.... Lift and more to come
    well im emptied my can and im a lil worried. didnt have a lot of oil but it was white soooo im guess i got water in there. BUT im hopin it is condensation in the can mixing with the oil to cause that. if other guys are havin ice in theirs then that might explain mine. i have well over 1000+ miles on it and had my oil changed right before i did this mod...
    i have picture which ill upload later
  8. Dec 31, 2012 at 7:49 PM
    #328
    seric007
    small amount of "Water" entering the intake wont effect anything. Heck i know a lot of the larger turbo guys run water injection systems into the intakes to cool things off!
  9. Dec 31, 2012 at 7:59 PM
    #329
    SconnieHailer
    SconnieHailer PutterClutch
    Marc
    West Central Wisconsin
    2012 TRD Off Road Double Cab V6 6Speed
    I have never tried to empty mine after the engine has been stopped for long enough for the contents to freeze. It has been in the minuses (Fahrenheit) here for a while. I suppose what is in there is frozen but the last time I drove it around town and then opened the valve to empty it it drained like normal... Probably also depends on how far your can is from the engine block.
    ~M
  10. Dec 31, 2012 at 9:33 PM
    #330
    jgunccrugby
    jgunccrugby Well-Known Member
    Mount Holly, NC
    13 PreRunner SR5 DBL Cab
    Tacoma Seat Covers, Tacoma Kick Guards, Nerf Bars, Front window tint. To come: Bull Bar
    This is going on my to-do list for my truck and my golf cart. I can see this saving me a ton of time in my regular maintenance on the golf cart.
  11. Jan 1, 2013 at 8:56 AM
    #331
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    Sub'd plan on doing this now!
  12. Jan 1, 2013 at 12:47 PM
    #332
    ALBtacoma
    ALBtacoma Well-Known Member
    Pete
    Red deer AB, Canada
    07 trail limo trd sport
    Hey wang,
    I've been looking at doing this I plan on keeping the truck for long time. Do you think if you put antifreeze in there that it would stop it from freezing? Also if you went for a drive then drained it that should work also? Just want your feedback before I go ahead and order this.
  13. Jan 1, 2013 at 12:52 PM
    #333
    SkeeterBilt
    SkeeterBilt Zombie
    Skeeter
    Sierra Vista, AZ
    i pesonaly would deff not put antifreeze in the can and emptying it after every drive would just be a PITA
  14. Jan 1, 2013 at 1:30 PM
    #334
    ALBtacoma
    Pete
    Red deer AB, Canada
    I'm not saying emptying after every drive. But instead of draining it in the morning after its been sitting I'm thinking like when you got home from work the air from the engine should melt the water in the can so you can drain it. There has to be something to put in the can to stop it from freezing. It was -30 all last week maybe if you could tap in a block heater just like we do for our oil pans?
  15. Jan 1, 2013 at 3:35 PM
    #335
    TRDPrerunner
    TRDPrerunner Member
    Boaz, Alabama
    2008, Trd Sport Mall Crawler
    3" Revtek Spacer lift with rear Add-a-leaf, 285/70/17 Cooper Discoverer AT3's, Pioneer Touch Screen Head Unit, Memphis SR 6x9's in the front, Upgraded front tweeters, Rear Memphis SR 6x1/2's, 2 Rockford Fosgate P1 Subs in custom box behind the back seat, Memphis SR 1000 watt amp, BHLM, DRL Toggle Switch, Switchback LEDs (See csjumper2003! Coolest thing I've bought for the truck!), Black Tacoma badges, AVS Tail Light covers, "Roll Tide" 3rd Brake Light decal (See sockmonkey!), Secondary Air Filter Removed, and an Oil Catch Can to make the truck last longer than I do!
    I'm guessing you just run 2 small screws into the catch from one side of the bracket? And CayucosTacoma, what size line do you have, and would I just need to go to Summit Racing's website and search upgraded fuel line? Just don't want to mess anything up here :p
  16. Jan 1, 2013 at 4:30 PM
    #336
    SconnieHailer
    Marc
    ^ the fuel line that orielly carries has been excellent for me. Its the bio fuel compatable 250 psi stuff, roughly 4$ a foot... doesn't get squishy under heat and clamps well to the PCV and intake nips.
    ~M
  17. Jan 1, 2013 at 6:31 PM
    #337
    seric007
    4$ a foot :eek:
  18. Jan 1, 2013 at 7:04 PM
    #338
    SconnieHailer
    Marc
    IIRC it was $4 a foot, I needed something and orielly is the only store here in the middle of WY that had some tube up to the task... I only needed 3 feet. Cheaper than buying braided line!
    ~M
  19. Jan 1, 2013 at 8:10 PM
    #339
    Bhwang
    Josh
    Canada
    Tacoma
    I dont plan on putting antfreeze in there just sounds like a PITA. I think because the can is by the battery it does not get any heat from the engine. I drove for 2hours in the highway and tried to empty it after and the pic of ice on page 16 was what came out. It was ice all mixed with oil. I think it was all just build up.
  20. Jan 1, 2013 at 8:10 PM
    #340
    ALBtacoma
    Pete
    Red deer AB, Canada
