Oil Catch Can Install Guide
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CayucosTacoma, Jul 25, 2012.
  1. Jan 22, 2016 at 11:15 AM
    #661
    Konvict KROG
    Konvict KROG Live Free or Die Trying
    Louisiana
    Old Toyota's, Power Wagon, and a Tacoma
    Traded the 2015 TRD Pro 6spd Supercharged on a PowerWagon and could not be happier. My 2011 Tacoma with the TX Baja package (Added by me) is still treating me great. My 1985 Toyota never skips a beat.
    I don't even remember when i ordered it, its been that long. BUT MY CATCH CAN IS HERE!20160122_140948.jpg
    Biscuits likes this.
  2. Jan 22, 2016 at 11:18 AM
    #662
    Konvict KROG
    Louisiana
    This thing is quality! It is every bit as nice as it was claimed to be!
    I can't wait to see how it performs.
    Torspd and Biscuits like this.
  3. Jan 22, 2016 at 11:20 AM
    #663
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    Dat der looks nice.
  4. Jan 22, 2016 at 11:27 AM
    #664
    Btnewman
    Btnewman Benjamin Newman
    Benjamin
    Grand Junction co
    Uh. It's beat to he//. But it's only 1 owner.
    Custom body work/damage ARB rear locker Bumpers Shocks Other parts Tires and Rims Air tank fully plumbed into truck "Golf ball mod"
  5. Jan 22, 2016 at 11:47 AM
    #665
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Works better installed. ;)
  6. Jan 22, 2016 at 12:03 PM
    #666
    Biscuits
    :bananadead:
  7. Jan 25, 2016 at 11:02 PM
    #667
    SonnyBones
    SonnyBones I VOID WARRANTIES
    Jeffery
    2015 TACOMA ACCESS CAB
    Thought I'd share my setup on my 2015.
  8. Jan 26, 2016 at 3:20 AM
    #668
    ThomasMore66
    Dallas/Fort Worth & Durango
    Nice. Without the SC coolant reservoir you have room to work.
    Pavlik1988 likes this.
  9. Jan 26, 2016 at 4:44 AM
    #669
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Good job man! :thumbsup: Quality AN hose and fittings. I am a huge fan of the Earl's line, as well.
  10. Jan 26, 2016 at 2:23 PM
    #670
    SonnyBones
    Jeffery
    @Torspd Thank you. I know the setup could be done for way cheaper, but I see it as an investment. Eventually id like to change out PCV valve to a male AN fitting that I recall seeing on your setup, just not ready to dig into all that stuff just yet. :)
    Yeah for sure, always gone with Earl's lines and fittings. Never have they failed me yet.
  11. Jan 26, 2016 at 2:24 PM
    #671
    SonnyBones
    Jeffery
    @ThomasMore66 Thanks. But I'd rather have a SC lol
  12. Jan 26, 2016 at 2:58 PM
    #672
    Konvict KROG
    Louisiana
    This was my thought. But it looks great!
  13. Jan 26, 2016 at 7:27 PM
    #673
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Tap the valve cover to 3/8" NPT. Your line looks like a -6AN. So then a 3/8" NPT to -6AN fitting. When you're ready. ;)
    Lord Helmet likes this.
  14. Jan 26, 2016 at 8:34 PM
    #674
    sblea
    sblea Member
    Denver, CO
    Double Cab Longbed
    If you tap your valve cover, do you guys have to remove it completely? How much room do you have to work since its plastic (assume you grind off the OEM nipple)? Just curios how much to go into the plastic piece. Also how would you prevent plastic shards going into the intake cover?
  15. Jan 26, 2016 at 8:58 PM
    #675
    SonnyBones
    Jeffery
    Nope got a -8an line going. I think I should've gone with -6 though, seem's overkill for vacuum lines. Any suggestion on how to convert the plastic nipple on the intake side to AN? It not like I'm going to do it anytime soon though lol
    Most likely remove. There's not much room to work in there as it is. I figure I do the conversion when I have to actually change valve cover gaskets or something lol
    Torspd[QUOTED] likes this.
  16. May 1, 2016 at 12:37 PM
    #676
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    Anywhere to find the ADD w1 can anymore?
  17. May 1, 2016 at 1:21 PM
    #677
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
    Sub'd!!!
  18. May 1, 2016 at 1:57 PM
    #678
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    https://www.tacomaworld.com/threads/help-oil-on-spark-plugs.430016/
    This guy may be opening up his top end... is this where the oil/ water mixture is captured from? Maybe if he does we can see this buildup that occurs.. anyone else have pics w engine opened up? I want to see a high mileage trucks insides w this lacquer buildup this supposedly prevents..
  19. May 1, 2016 at 2:32 PM
    #679
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Look in my build thread. Gigabytes of pics
    Biscuits and CayucosTacoma[OP] like this.
  20. May 1, 2016 at 2:35 PM
    #680
    IronPeak
    AuggieX
    Back to Back
    Whoa 231 pages.... can you direct us to the pages/posts that show this gunk buildup? I saw a few youtube vid of 10yo tacos opened up and they looked pretty darn clean.. OK so I see in post 100 some burned on stuff is that what is going on?
