Oil catch can
Discussion in 'Performance and Tuning' started by Detective_Dan, Jan 25, 2014.
  1. Mar 21, 2014 at 11:34 PM
    #101
    Oggy
    Oggy Well-Known Member
    David
    Phoenix, Az
    2010 TRD Off Road
    Throw it with the rest of your used oil or whatever container you have. Do not put it back in your truck what so ever.
  2. Mar 22, 2014 at 7:08 AM
    #102
    adriancast
    adriancast Well-Known Member
    Adrian
    Ontario, Ca
    2005 Tacoma 4x4 TRD Off-Road
    -2.5 Donahoe Coilovers -All Pro Standard Leaf Pack -All Pro U Bolt Flip Kit -Front/RearWheeler Super Bumps -Extended rear Bilstein 5100s -Flowmaster 40 Series -All Pro IFS Skid -All Pro Transmission Skid -Bruteforce Hybrid Bumper -30" Double Row LED bar -400 Watt Anytime -TRD Seat Covers -ABS Kill Switch -Locking Center Console Mod -Rear Differential Breather -BHLM -Anytime Fog Light Mod -Toyota Hilux Snorkel
    So for the oil you toss out, do you put new oil back in around the same amount?
  3. Mar 22, 2014 at 7:12 AM
    #103
    Detective_Dan
    Detective_Dan [OP] "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    Just keep an eye on your oil level and add if necessary. I have about 1/8th of a pint of oil it has caught in 1500miles. There shouldbe no reason to add oil I between service intervals
  4. Mar 22, 2014 at 7:16 AM
    #104
    adriancast
    Adrian
    Ontario, Ca
    Thanks.
  5. Mar 22, 2014 at 7:46 AM
    #105
    wannabetrd
    wannabetrd Well-Known Member
    Zach
    Michigan
    SR5
    3inch front 2inch rear lift with add a leaf and extended brake lines trd exhaust
    Where do you hook the rubber lines from the catch can to
  6. Mar 22, 2014 at 7:47 AM
    #106
    Detective_Dan
    Colorado Springs
    The pcv hose. It's about a 6 inch rubber hose running on the driver side behind a large bracket. It goes from the crankcase to the intake after the throttle body
  7. Mar 22, 2014 at 7:49 AM
    #107
    Detective_Dan
    Colorado Springs
  8. Mar 22, 2014 at 8:16 AM
    #108
    wannabetrd
    Zach
    Michigan
    SR5
    Thanks a lot for sure my next mod
  9. Mar 26, 2014 at 9:29 AM
    #109
    dispatch55126
    dispatch55126 Well-Known Member
    MN
    2004 Xtracab SR5
    Complete OME kit w/ 881's and dakars. All-Pro Sliders, CB, HAM Radio and various other minor stuff.
    Another question on this. Besides not burning this sludge, what are the other benefits? Are there performance gains? I'll probably put it on anyways since I do alot of highway driving which means high RPM's on a 4 cylinder but was wondering if I'd "feel" any differences.
  10. Mar 26, 2014 at 9:39 AM
    #110
    Detective_Dan
    Colorado Springs
    not gonna feel any difference. it will just help maintain engine cleanliness
  11. Mar 26, 2014 at 10:32 AM
    #111
    philvet
    philvet Member
    Phil
    2014, 4 x 4
    Window Shades, Running Boards, Bed Cover, Front Hitch
    I'm a newbie here, but after reading this post I could not keep my mouth shut. The oil you are catching in the can is normally put thru the intake and gets burned up in the combustion chamber it does not gum up any part of the internal parts of the engine. I would also be concerned that you are pulling that much oil out of the engine in only 100 miles
  12. Mar 26, 2014 at 10:54 AM
    #112
    GotExhaust
    GotExhaust Well-Known Member Vendor
    Nick
    If it hasn't been mentioned you can also use a "shower poof" (technical name?) inside the catch can. They're like .50 so I typically just toss them and replace with another one when cleaning out catch cans. You look a little fruity buying them, but deep down inside you know it's for something manly. :)
  13. Mar 26, 2014 at 10:59 AM
    #113
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    That's our entire point of catching it? So it doesn't go in the intake.
  14. Mar 26, 2014 at 11:02 AM
    #114
    GotExhaust
    Nick
    That's oil that would normally be sucked straight into your air intake tube, through the throttle body and into the intake manifold, and ingested in places where oil isn't necessarily supposed to go. The crankcase vent has a hose coming off it to expel gasses into the intake tube, but some of the oil in the valve train that's sloshing and spraying around will inevitably go along for the ride. The catch can isn't "pulling" oil out of the engine and any faster of a rate than before, it's simply "catching" it before it gets sucked into the air intake. It's not as important or drastic on naturally aspirated vehicles, but on supercharged engines the problem is exacerbated.
    When you allow an oily film to collect on the surfaces of your air intake components, all kinds of grime gets attracted to it and the oil its self begins to build up. Over time it can cause a buildup of sludge, rough idle, etc. It's not the end of the world, but it certainly doesn't hurt to install the catch can, especially if you drive your truck hard on or off-road.
  15. Mar 26, 2014 at 11:25 AM
    #115
    Detective_Dan
    Colorado Springs
    the pcv hose injects the oil/air mixture after the throttle body, directly into the intake manifold. not into the air intake tube before the throttle body
  16. Mar 26, 2014 at 11:28 AM
    #116
    Detective_Dan
    Colorado Springs
    and its really not that much oil. i have about 1/16th - 1/12th of a normal sized nestle water bottle filled up after 2k miles
  17. Mar 26, 2014 at 4:15 PM
    #117
    inesshell
    inesshell blah blah blah
    All stock Superwhite 10' AC
    just did this mod......thanks op. I forgot how expensive fuel line is by the foot.
  18. Mar 26, 2014 at 5:48 PM
    #118
    st101
    st101 Well-Known Member
    What do you recommend on this issue?
    Mine arrived today with the top-mount breather. To use or not to use, that is the question :cool:
  19. Mar 26, 2014 at 6:24 PM
    #119
    Detective_Dan
    Colorado Springs
    Either return it, or cap the intake side
  20. Mar 26, 2014 at 6:34 PM
    #120
    st101
    The one I got doesn't have the breather pre-installed -- it came out of the box with the top of the canister already capped. It looks just like the one in this photo:
    To add the breather I'd have to install it to the can. So there shouldn't be any issue, then, right?
