Oil change 2nd gen
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Vinchez78, Nov 26, 2020.
  1. Nov 27, 2020 at 5:05 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    :angrygirl:
  2. Nov 27, 2020 at 5:05 AM
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    Napa Gold (WIX) & any spec'd oil.
    (in for the inevitable Friday oil thread, dumpster-fire/shit show...)
    Rick's 2012 and Plain Jane Taco like this.
  3. Nov 27, 2020 at 5:07 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    And for those who may he stressing at this point....all 4.0's came with conventional 5w-30 as factory fill....in the Tacoma anyway.
    Conventional oil is just fine and much cheaper if you choose that route. Sleep comfortably
  4. Nov 27, 2020 at 5:09 AM
    That one old guy
    Chuck
    Stockish
    Bill, don't cloud a good oil thread with facts..:boink:
  5. Nov 27, 2020 at 5:16 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    D7378D39-5497-4F06-BB33-A095F1FBE435.jpg Don’t make him angry. You wouldn’t like him when he’s angry
  6. Nov 27, 2020 at 5:20 AM
    Plain Jane Taco
    USA
  7. Nov 27, 2020 at 5:44 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    OP, please double and triple check to make sure you are removing the oil drain bolt (next to cross member) and not the transmission bolt. There are countless threads on TW on owners accidently draining the trans fluid. Once you remove the right one, celebrate by marking or painting that oil drain bolt or do like what some of us did, replace it with a fumoto oil drain valve. Welcome to TW.
    Clearwater Bill likes this.
  8. Nov 27, 2020 at 5:49 AM
    Vinchez78
    Vinchez78 [OP] Well-Known Member
    Alvin
    Black Taco TRD sport
    Yes absolutely, I've seen YouTube vids on this type of fail, Good lookin out , Dos Equis guy:thumbsup:
  9. Nov 27, 2020 at 5:54 AM
    Wattapunk
    Uncle K
    TX
    2005 DCLB 4WD
    You be surprised at how often it happens for even seasoned owners that have performed this same task numerous times. I put a gold "X" on the bolt until I recently went with a fumoto valve and skid plate. Drinking a beer after the correct bolt is removed versus before would be my next suggestion.
    whatstcp likes this.
  10. Nov 27, 2020 at 5:58 AM
    SoCal_Erik
    SoCal_Erik Tiki Taka, Tika Taka
    ‘23 Tundra SR5 Sport, ‘16 SR5 DCSB (sold), ‘15 SR5 DCSB (sold), ‘16 4Runner SR5, ‘15 OR DCSB (sold), ‘05 SC (sold)
    boogie3478 likes this.
  11. Nov 27, 2020 at 6:01 AM
    Plain Jane Taco
    USA
    :D
  12. Nov 27, 2020 at 6:59 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Generally speaking, some of the better brands of oil filters are WIX, ACDelco and Bosch. In truth, all filters will work. Some have poorer filtration characteristics.
    Oil is simple. Suggest a Full Synthetic. Viscosity (not weight :smack:) is marked on the oil fill cap and Owner's Manual. Any brand meeting the API specifications in the Owner's Manual are good enough. Dino squeezings can be used, although, you may want to think about a shorter change interval.
  13. Nov 27, 2020 at 7:10 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    Only the best for my taco
  14. Nov 27, 2020 at 10:11 AM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    I can't afford the true synthetic so I use a blend
  15. Nov 27, 2020 at 10:41 AM
    #35
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    I'm different
    Wix 51516XP
    Super Tech full synthetic 5w30 from Walmart.......
    Use a new gasket too
  16. Nov 27, 2020 at 10:47 AM
    #36
    Plain Jane Taco
    USA
    You're taco smells funny most of the time. Maybe that will help
