Oil Change... is really a short question.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mvega1969, Oct 14, 2008.
  1. Oct 14, 2008 at 8:37 AM
    mvega1969
    mvega1969 [OP] Well-Known Member
    Laredo
    '17 Tacoma DC LB 4X4 TRD Off Road.
    I was searching... but I did not find it, I know it is somewhere, but here is my question. How can I avoid an oil drop mess when removing the oil filter?
    a.- Wait a long period of time prior to hand loosen the oil filter and after engine is off.
    b.- Is there any other way than waiting? Which one?
    Last time I remember that Janster answer that, but as I mentioned... I can not find it.
    Thanks.
  2. Oct 14, 2008 at 8:39 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    hook up a hose to the bottom of the oil filter pan and run it into the oil pan.
  3. Oct 14, 2008 at 8:45 AM
    lakewoodbilly
    lakewoodbilly Well-Known Member
    Bill
    Lakewood, CO
    White 08 DC V6 SR5 4WD TRD Sport
    Factory DRL's, Underhood Flood LED's, Underbody Multi-color LEDS, Red Line Tuning Elite Hood Struts, Anytime Fog Lights, PIAA 4100 Intense White, Luminics JDM Yellow H10 Fog Lights, OBX Sport Pedals, Sill Protectors, Bed Net, Front Bed Tie Downs, iPod and Aux Factory HU Interface, Sirius Sportster 5, Satellite Antenna through third brake light
    All I do is wedge an empty 20oz soda or water bottle under the oil filter spill collector and remove the rubber plug. I don't think you can avoid spillage by loosening and/or waiting.
    My oil and filter changes take 10 minutes total.
  4. Oct 14, 2008 at 9:21 AM
    linkfeeney
    linkfeeney Well-Known Member
    link the stink!
    Sewell, NJ Eh!
    09 Doublecab TRD Off-Road! Magnetic Grey!
    yeah i used a coke can to catch the oil from the filter.
  5. Oct 14, 2008 at 9:23 AM
    red06toy
    red06toy Well-Known Member
    Worcester MA
    Impulse red OR, 2.5 lift
    2.5 toytec, bilstein 5100 black grille, black lights, partially shaved decals remaning ones black, , trd fj wheels, sirius, Ipod interface, pre-filter delete
    1. take oil filter drain cap off
    2. put a sall container under it (I use a 20 oz gatorade with a metal coa hanger taped to it.)
    3. Unscrew oil filter.
    4. once filter is fully drained replace plug. Done and clean! be careful tho, its usually very hot by the plug if you just drove the truck.:eek:
  6. Oct 14, 2008 at 9:31 AM
    hate2work
    hate2work Well-Known Member
    Washington State
    06 standard cab
    What is an oil filter drain cap? I don't have one on my truck, is it only on the V-6 engines? My 4 cyl doesn't have one, and it makes quite a mess when removing the filter.
  7. Oct 14, 2008 at 9:45 AM
    A_Ninja_Racer
    A_Ninja_Racer Well-Known Member
    Tampa, FL
    08 PreRunner TRD Debadged
    On the 4.0 v6 the oil filter is mounted upside down at the top of the moter so when you start to unscrew it it emediately starts to poor. and if you didn't take the steps these guys are talking about you would have oil all down the front of the motor.
  8. Oct 14, 2008 at 9:59 AM
    mvega1969
    Laredo
    The good thing about the oil cap is that is not longer there, on my first oil change (this is my second) I installed a fumoto valve, this time (than oil in the pan) will be as easy as open a valve (prior I will insert a proper width hose), but I do remember the oil filter mess.
    Thanks to you all guys for typing your solutions to this experience.
    Regards.
    and we all still open to any new options...
  9. Oct 14, 2008 at 11:05 AM
    hate2work
    Washington State
    06 standard cab
    OK, thanks Ninja. That makes me feel better about where and how the filter is installed on my 2.7 !! :D
  10. Oct 14, 2008 at 11:53 AM
    spaghettiedy
    spaghettiedy Well-Known Member
    Pittsburgh
    09 DC LB Sport in Black 4x4
    Gray Weathertechs, LG Wet Okoles, Tacome OEM Bedmat
  11. Oct 14, 2008 at 1:27 PM
    mvega1969
    Laredo
    Thanks to Chris4x4 and to spaghettiedy for bringing this missing in action thread, more complete and detailed can not be.
    Thanks to both of you guys.
    Regards.
  12. Oct 14, 2008 at 1:31 PM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    2017 Tacoma 6MT TRD Pro
    Falken Wildpeak MT 285's
    I use a old 20 oz. water bottle, fits perfect underneath.
  13. Oct 15, 2008 at 7:18 AM
    spaghettiedy
    Pittsburgh
    Yeah, I was reading another oil related thread in which Chris pointed this out. It really should be a sticky! Hint, Hint to the webmaster.
  14. Oct 15, 2008 at 7:35 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
  15. Oct 15, 2008 at 7:40 AM
    mvega1969
    Laredo
    Thanks Isocoee!
  16. Oct 16, 2008 at 1:29 PM
    spaghettiedy
    Pittsburgh
    Thanks as well Isocoee
