Oil Change Mods
Discussion in '3rd Gen. Tacomas (2016-2023)' started by arthur106, Jul 29, 2021.
  1. Jul 29, 2021 at 7:33 AM
    arthur106
    arthur106 [OP] Well-Known Member
    Jacob
    Houston
    Black '10 SR5 4WD 5MT
    I'm getting ready to do my 15,000 mile oil change and would like to use the opportunity to do a few simple mods.
    1. F133 Fumoto Quick Oil Drain Valve
    2. Oil Filter Sandwich Adapter (still looking for the exact model looks best..) so I can eventually measure oil temp and pressure
    3. I was reading something about a modification to the oil filter housing?? I was reading about the Baxter adapter but I'm not really sure what the advantage is. Can someone perhaps shed some light on this? The original oil filter seemed just fine..
    Anything else I ought to do while I'm down there?
  2. Jul 29, 2021 at 7:35 AM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    If you take your truck off-road I wouldn’t do the valve.
    Junkhead, MJTH, DAS Taco and 2 others like this.
  3. Jul 29, 2021 at 7:35 AM
    arthur106
    Jacob
    Houston
    Even with the skid plate?
  4. Jul 29, 2021 at 7:36 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Any links for the sandwhich adapter?
    SR-71A likes this.
  5. Jul 29, 2021 at 7:38 AM
    mschein1
    mschein1 Well-Known Member
    Lincoln, NE
    2021 Tundra OR CM
    I've never understood the valve. I mean you have to get down there to open it, so I just always bring a 14mm socket and use the plug. I've bought them for other people but it's peace of mind knowing I have a plug.
  6. Jul 29, 2021 at 7:38 AM
    stevesnj
    if the skid covers it enough it should be fine. I seen a few ripped off on other trucks though that needed the oil pan replaced.
  7. Jul 29, 2021 at 7:39 AM
    arthur106
    Jacob
    Houston
    yikes :eek:
  8. Jul 29, 2021 at 7:40 AM
    MDFM31
    MDFM31 Well-Known Member
    Chester Co, PA
    16 DCSBOR
    You can get oil temp with an obd reader app. I use obdfusion. I've also never heard of a sandwich adapter that didn't leak.
    While you're in there, get the metal filter housing. It's a Toyota part, not after market, but not specifically for the Tacoma. A search will get you the part number.
    02Duck, Kev250R and SR-71A like this.
  9. Jul 29, 2021 at 7:40 AM
    CG256
    CG256 Well-Known Member
    '19 TRD OR
  10. Jul 29, 2021 at 7:41 AM
    arthur106
    Jacob
    Houston
    ConantTaco and Skydvrr[QUOTED] like this.
  11. Jul 29, 2021 at 7:43 AM
    arthur106
    Jacob
    Houston
    ConantTaco likes this.
  12. Jul 29, 2021 at 7:43 AM
    jbjones85
    jbjones85 Well-Known Member
    Josh
    Newburyport, MA
    I run the fumoto and did so on my 4runner and 2nd gen (7 years of use between the two) with no issues. Makes the oil change experience more enjoyable. If you get the short valve it is recessed behind the skid by a decent amount so I don't see how it would be an issue. I Ran RCI skids on my 4 runner and no issues there either.
  13. Jul 29, 2021 at 7:46 AM
    CG256
    '19 TRD OR
    Don't use that link. It's been awhile but I think the thread pitch is 1.25 not the 1.5 I linked.
  14. Jul 29, 2021 at 7:47 AM
    H6G
    H6G Well-Known Member
    Far from home...
    ‘18 Blk. Pro/ ‘17 GT350
    '22 Pro suspension/ Custom Deaver springs/ ECGS and...
    It got real...Baxter adapter, spin-on filter, oil change. | Tacoma World
  15. Jul 29, 2021 at 7:48 AM
    Vinci
    Vinci Well-Known Member
    Sarasota, FL
    '17 MGM Limited 4x4
  16. Jul 29, 2021 at 7:52 AM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Supposedly that's process data as there's no true oil temp sensor anywhere in the system
    SR-71A and arthur106[OP] like this.
  17. Jul 29, 2021 at 7:52 AM
    Skydvrr
    Nick
    YMH
    Black '17 OR
  18. Jul 29, 2021 at 7:55 AM
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    The baxter adapter is meh. I am fine with just using the stock stuff, never had a problem.
    If it's above the skid plate should be fine. If you bash the valve off road with a skid plate on there, you've got a lot more issues than just your drain plug.
    Easier control - can stick a hose on there and then open the valve, no oil spray. Some people don't do a lot of oil changes so the few that they DO end up doing DIY, end up being a mess.
    ^^^^^^^^^^^^ OBD reader for sure. Also allows you to reprogram TPMS serials as/if needed. The metal filter housing is meh too - I would definitely have a second in the garage as a backup, but doesn't need to be the metal one.
    Long of the short - don't overcomplicate something you only do every 10k/6 months. The drains are good, but beyond that, meh. It's just an oil change.
  19. Jul 29, 2021 at 8:03 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
  20. Jul 29, 2021 at 8:03 AM
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    As far and the Fumoto valve goes, I had one on my previous vehicle (Jeep Liberty CRD) for over 10 years and not a single issue. I even took it off road. the valve was well above the skid plate on it and I used the original style without an nipple. With that vehicle it had an aluminum oil pan with easy to damage treads so it was worth having.
    On the tacoma the oil pan is not like that. It does make the oil change a little easier I would be sure its above a skid plate.
    I'm still in the fence about putting one on my truck
