Oil Change Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JTaco386, May 23, 2010.
  1. May 23, 2010 at 8:35 PM
    JTaco386
    JTaco386 [OP] Well-Known Member
    JT
    Fort Rucker, AL/ Home: Port Orange, FL
    13 DCSB TRD Sport 4x4
    I have an upcoming deployment in mid-June and my truck will be stored for the year that I'm gone and will only be started a couple times a week.
    I have been using full synthetic and have about 3,000 miles on the current oil. Should I change it before leaving? Or wait unil I come back from deployment? I should be getting R&R leave sometime, but I'm not sure when.
    Thanks for your time!
  2. May 23, 2010 at 8:37 PM
    wlmuncy
    wlmuncy Well-Known Member
    William
    Knoxville, TN
    2007 Double Cab Manual 4*4
    Do it before you store it. It will be happy when it's cleaner. Use some inexpensive oil (synthetic) and change once you get back as well.
  3. May 23, 2010 at 8:41 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Oil - change to extended
    Not sure when and if you had made a change but brake fluid, atf in tranny and power steering should probably be changed as they will be sucking moisture from the air.
  4. May 23, 2010 at 9:00 PM
    JTaco386
    JT
    The truck only has 36,800 miles right now. I know the brake fluid hasn't been changed along with the atf in tranny and power steering. The truck will be stored inside a garage if that will help with the moisture related issues. BTW, doesn't the atf in the tranny get changed at 100,000 miles or is that b/s that I've heard?
  5. May 23, 2010 at 9:22 PM
    BlueT
    NorthEast
    Your truck is 05 right ? If thats it then your brake fluid is probably at the point that needs changing anyway. its not only the mileage it is also the age.
    100k for tranny is what manual specifies but nobody really believes that anymore. You are in Florida so unless truck is stored in location that has dry storage area I would rather have new fluids. remember any moisture and things will rust internally despite being submerged in fluid.
    I mean I am crazy about maintenance :D but I know that even not used fluids do expire so having them fresh is probably good thing to have.
  6. May 24, 2010 at 1:37 AM
    JTaco386
    JT
    Yeah, it's an 05'
    I'm stationed in Fort Sill Oklahoma and it's pretty dry here..I think, but I'm going to call the stealership and schedule to get those fluids changed out to be on the safe side. Hopefully they don't try to kill me on the price to do all of this. Are they always the best place to go to for these types of services?
    I appreciate your help!
  7. May 24, 2010 at 1:43 AM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    i completely parked my s-10 before i left for 6 months and it stayed in a storage facility w/o being cranked at all. i removed the battery terminals, put in a fuel stabilizer, and changed the oil before sitting. when i got back i put on the terminals and it cranked back up like i never left
  8. May 24, 2010 at 3:17 AM
    Barnone
    Barnone Guest
    Same with my 2002 Taco. Cranked right up after sitting.
  9. May 24, 2010 at 8:35 AM
    Collins
    Collins Well-Known Member
    North Carolina
    09' Tacoma, 2.7L, 5spd, 4x4
    Def. on the fuel stabilizer and try to make sure the truck
    is moved some so the tires don't flatspot too bad.
    good luck on the deployment!
  10. May 24, 2010 at 8:53 AM
    BBY2KS2K
    BBY2KS2K Jon Stewart / Stephen Colbert 2016
    Lake Stevens, WA
    2005 PreRunner DC
    16x7.5 TRD Bronze "beadlock" wheels without the beadlocks w/ 265 70 16 Bridgestone Revo II tires (non-winter) 16x8 KMC Enduro w/ 265 70 16 Bridgestone Blizzak DMV-1 tires (winter) McGard Spline Drive lugs and locks, Satoshi Grill, BLHM, blacked out badges, Aries side steps, Smittybilt light bar with PIAA 540 plasma ion fogs, Aero-Turbine muffler
    If it's started a couple times a week, is it possible to have it driven a couple times a week. At least long enough to get things up to operating temp?
  11. May 24, 2010 at 8:56 AM
    JTaco386
    JT
    I will pick up some of that today and add it when I change the oil. I got the fuel stabalizer already. Thanks for te tips
  12. May 24, 2010 at 9:31 AM
    JTaco386
    JT
    Yeah, it's supposed to be driven around the facility, but I'm not sure how often and how long. It's paid for by the army so I don't expect to much.
  13. May 24, 2010 at 10:50 AM
    BlueT
    NorthEast
    If you put new fluids its going to be fine for few years.:) No worry
    See if you can fill up tank with pure gasoline 93/91 octan.
  14. May 24, 2010 at 12:06 PM
    JTaco386
    JT
    yeah, I'm gonna put new fluids and I have a gas station down the street that sells 100% gasoline. So I will fill it up and add the stabilizer to it and hopefully she will be good to go.
  15. May 24, 2010 at 2:57 PM
    BBY2KS2K
    Lake Stevens, WA
    2005 PreRunner DC
    Yeah, I wouldn't expect much either.
    Is it going to be stored indoors or outside? If it's outside, definetly put a couple good coats of wax on.
    I did two 6 month deployments while in the Navy. The MWR (Morale, Welfare and Recreation - not sure if that's what the Army calls it) offered deployment car storage in an old airplane hanger on Ford Island in Pearl Harbor, Hawaii. I forgot how much it was, but it was worth it. Otherwise your car had to sit outside on an abandoned airplane tarmac.
  16. May 24, 2010 at 8:22 PM
    JTaco386
    JT
    It will be stored indoors and it's free. It's in Dallas at a big warehouse that is climate controlled. I'm going to fully detail my truck to include clay bar and a nice thick coat of wax. We call it MWR as well and they hook us up while deployed...usually.
  17. May 24, 2010 at 8:44 PM
    j1999t
    j1999t Well-Known Member
    Justin
    Northern Colorado
    traded it in
    dont forget to put it up on blocks so u dont get flat spots on the tires
  18. May 25, 2010 at 3:33 AM
    JONNY TACO
    JONNY TACO Well-Known Member
    PA.
    DARK METALLIC GRAY -DOUBLE CAB SHORT BED
    ADVANTAGE TONNEAU COVER,TOYOTA BED LINER, POP&LOCK TAILGATE LOCK, SIDE TUBES, WIFE IN PASSENGER SEAT
    Makes me wonder what happens to vehicles sitting on a sales lot for that period of time; if not longer ???:confused:
  19. May 25, 2010 at 8:49 PM
    Hootbro
    Hootbro Omnipotent
    Delaware
    2009 Tacoma Regualr Cab 4x4 2.7L
    A new vehicle is not going to sit on a lot in one spot for a year.
