Oil Change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by timinco77, Jun 19, 2009.
  1. Jun 19, 2009 at 6:22 PM
    timinco77
    timinco77 [OP] Active Member
    Colorado Springs
    07 Tacoma Access Cab
    Rear TSB
    I ran out and picked up 8 qt.s of Royal Purple 75w90 gear oil. I want to change out rear/front diff, manual transmission and transfer case. Could someone just verify for me that it is okay to use 75w90 in the rear diff when the manual says 80w90. According to the manual 75w90 works everywhere even the 6speed tranny?
    Thanks
    v6 trd off road.
  2. Jun 19, 2009 at 6:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    the 75-90 will be fine
  3. Jun 20, 2009 at 9:00 AM
    dw77x
    dw77x Those are not my pants
    SE Wisconsin
    2009 Tacoma Sport LB
    5100's all 4 corners (front at 2.5"), rear tsb springs with 1.5" AAL, 265/70/17 General Grabber AT2's
    I have always prefered a GL-4 (not Gl-5) rated manual transmission oil. The Gl-4 rating has different additives and basicaly is less slippery. GL-5 (your standard differential oil) is desigened for a hypoid gear set and not really for a manual transmission. Your sincros will work properly with the correct oil. Personally I have always run Redline MT-90 with great results.
    **I know the manual says you can use either GL-4 or GL-5, I am just speaking from personal experience.
  4. Jun 20, 2009 at 10:17 AM
    mdbrjb
    mdbrjb Member
    Spartanburg, SC
    05 PreRunner SR5
    Cruise Control, Fog Lamps, Tonneau Cover, KYB Shocks, ScanGauge II, AFE ProDry, Prodigy Brake Controller
    X2 on the MT-90!!
  5. Jun 20, 2009 at 10:18 AM
    FL4x4Taco
    FL4x4Taco Well-Known Member
    X3 on the MT90!!! Hated M1 75-90 in my 4runner trans. Always grinded 2nd.
