Oil change ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by evansr40c, Feb 2, 2018.
  1. Feb 2, 2018 at 5:57 PM
    evansr40c
    evansr40c [OP] Member
    Evan
    2014 tacoma trd sport prerunner
    Hankook dynapro atm 265/70/r17,And working on it lol
    What should I use my tacoma has 103,899mi. after the dealers oil changes this is my first one so not to sure what to put in this baby
  2. Feb 2, 2018 at 6:17 PM
    Pigpen
    Dan
    Northwest Montana
    Any oil will do. Many of us run Mobil 1 synthetic. I use the 0w-30.
    Falldownhard likes this.
  3. Feb 2, 2018 at 6:27 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    5w-30 synthetic Mobil 1, valveoline, amsoil, etc. They are all sufficient, heck you could probably use delo if you wanted to. Its all personable preference. I use amsoil with Toyota filters
    DignTRDoffRoadnbama likes this.
  4. Feb 2, 2018 at 7:26 PM
    ViperACR
    ViperACR Active Member
    Kansas City
    13 TRD Sport
    I have always used the Napa Gold filter with Mobil 1
    thewarriordinghy likes this.
  5. Feb 2, 2018 at 7:36 PM
    evansr40c
    Evan
    Ty all I have alwase used valovoline synthetic blend high miles befor but I really want to treat this baby right
    Rust T likes this.
  6. Feb 2, 2018 at 8:35 PM
    Tacosail
    Tacosail Well-Known Member
    Jerry
    Hermanville Heights, Ohio
    '13 white ACLB
    '17 wheels,int. Wipers , bed mat , relocate trailer plug , husky floor liners , Lund nerf bars, wet Okole seat covers- heat & lumbar.
    Might want to get a new crush washer for the oil plug, since you might not know how many times it's been reused.
  7. Feb 2, 2018 at 8:49 PM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    Use a quality oil that is rated for your engine....not sure about the 14s....but my 06 uses 5w-30....i use Castrol high mileage....its a synthetic blend with a really nice additive package. Use a good filter as well.
  8. Feb 2, 2018 at 8:53 PM
    Comatose
    Comatose You snuff it, we stuff it.
    Miguel
    San Diego, CA
    2008 TRD OR Indy Ink
    Missing Critical Hardware Edition
    5W-30 Valvoline High Mileage Syn Blend with factory filter(You can buy them cheap as hell in bulk.)
  9. Feb 2, 2018 at 11:54 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Toyota recommends 0W-20 synthetic if you have the 2.7, or 5W-30 dino for the 4.0 . If your drive train is still under warranty, I would stick to these recommendations.
    Outside the warranty period, many Taco owners switch to synthetic for the 4.0 and extend oil changes up to 10K. Since you put many miles on your truck, 0W-20 on the 4.0 will help out with gas mileage, but the thinner oil will tend to burn more between oil changes and may also leak past gaskets (valve cover primarily) as the mileage piles up. But, since you drive more than average, the drawbacks are minimized; so, I would try the 0W-20 for the 4.0 and see how it goes.
    https://www.toyota.com/t3Portal/document/omms-s/T-MMS-14Tacoma/pdf/2014_Toyota_Tacoma_WMG_lr.pdf
    https://www.toyota.com/t3Portal/document/om-s/OM35A38U/pdf/OM35A38U.pdf
  10. Feb 3, 2018 at 12:22 AM
    omegaman2
    omegaman2 Unknown Member
    2015 4WD DCSB
    do we consider 104k miles on a tacoma "high mileage"? i'm unsure...my '94 was still strong at 210k
    regardless, i would recommend using conventional oil rather than synthetic - as synthetic can cause older seals to leak.
    regular oil changes are more important than the oil type - & my recommendation is to use toyota oem oil filters based on my research.
  11. Feb 3, 2018 at 12:27 AM
    Comatose
    Miguel
    San Diego, CA
    It doesn't seem like it nowadays, but over 75k is considered high mileage. As long as you switch to syn and stay syn before 150k there is generally no problems. The people who go to jiffy lube are the ones who have the problems with inconsistent oil types. But yea, factory filters are the best for the buck.
  12. Feb 3, 2018 at 12:54 AM
    Chuy
    Lakeside, CA
    Silver Taco
    His seals are 4 years old. Besides, synthetic oil causing oil leaks is a myth.
    http://www.cenex.com/about/cenex-in...page/oil-and-lubricants/five-engine-oil-myths
    If you are going to use synthetic oil and extend your oil changes, buy a good quality synthetic filter. I use Mobil1 Full Synthetic 5W-30 and Purolator PL30001 filters (and add .5 qts extra oil). I've had my oil analyzed twice: 9700 miles on Valvoline MaxLife 5W-30 and 10K on Mobil 1 Extended Performance 5W-30. The lab results showed the Valvoline didn't have many miles left after 10K, but the Mobil 1 could had gone another 2-3K. Of course, your driving habits, load on vehicle (i.e. trailer hauling), and geographical location (cold & hot states) will affect your results - that's where lab testing comes in handy.
    https://www.tacomaworld.com/threads/used-oil-analysis-reports-2nd-generation-tacoma.182294/
    stvhwrd likes this.
  13. Feb 3, 2018 at 2:52 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    OEM filter and any brand of oil will be fine, just use the recommended weight the owner’s manual calls for.
  14. Feb 3, 2018 at 4:00 AM
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    By the way, don’t use a “high mileage” oil unless you are having some kind of leaking/burning issue. Don’t just blindly use it based on miles. Once you start down that road there is no going back.
  15. Feb 3, 2018 at 6:54 AM
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    5.5 qts of this stuff..........good filter.......Toyota OEM filter works well
    BillsSR5 likes this.
  16. Feb 3, 2018 at 6:55 AM
    Armed in Utah
    2003 Lexus LX 470
  17. Feb 3, 2018 at 6:56 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    hell yeah! best combo OCI
  18. Feb 3, 2018 at 6:58 AM
    Armed in Utah
    2003 Lexus LX 470
  19. Feb 3, 2018 at 7:08 AM
    bnv
    bnv Boy I say, use CRAWL to sneak up on that dawg!
    Bruce
    San Diego
    2016 Access Cab TRD Off Road 4X4 Quick Sand
    Kings adj, TC UCA, Zeon 10s, PB bumper, BD 30" light bar, BD cornering lights, Line-X Grill, Wheels, Tires Duratracs, tint, gate lettering, glove box lettering, ARB compressor
    85F519CC-C078-468F-B432-E87C6A2059C9.jpg Straight to 236447B1-DCEA-4744-963E-DE3BCF7C13A1.jpg
    Gas Engine Oil - Very exotic, it is reused and unfiltered/unmodified from retail petroleum transfer stations to a new container. Thereby, it has already proven to be reliable in most vehicles.
    This is a random multi weight blend of non synthetic 40 grit goodness that helps your vehicle on to the next oversized rings and pistons.
    It has a suspension of ground up dinosaur bone grit particilies that scrub clean your engines cyilinder walls with a continuous honing action.
    Has also been Tested by Labs.
    devkurf, igno1tus and b_r_o like this.
  20. Feb 3, 2018 at 7:38 AM
    b_bednarz
    b_bednarz Active Member
    Ben
    Phoenix, AZ
    2008 Super White DCLB Prerunner TRD Sport
    TBD
    After too much time cruising the forums for info on oil, I have been running Mobil1 with an OEM filter since 95k on my truck. Filter is cheap enough at the dealership, plus they throw in a crush washer for the drain plug.
