Used Oil Analysis Reports - 2nd Generation Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fink, Oct 12, 2011.
  1. Oct 12, 2011 at 9:29 PM
    Fink
    Fink [OP] Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    Alright guys, I did some looking around and I didn't see a section/thread for this already...
    I'm a nerd and find reading Used Oil Analysis Reports really interesting. I've seen hundreds of posts, mainly on BITOG (www.bobistheoilguy.com), where this information has uncovered hidden issues with the engine, and allowed the vehicle owner to correct the issue before it was too late.
    If there's enough interest in this, maybe at some point the Mods can make a Sticky for these, so we can put them all together and compare our results and see what kind of trends we're getting. It would probably be best to break them down by generation, so it's easier to compare them.
    If nothing else, this will give you a chance to poke fun at those of us that are into this sort of thing.
    I would try and title your posts as follows: Vehicle Year/Model/Engine, Oil Brand/Weight/Type, Mileage On Sample
    Example: 2011 Tacoma 1GR-FE, Mobil Super 5W-30 Conventional, 4,900mi.
    As far as posting the actual reports. It'd be best to actually embed them into the post, versus attaching them - but either way will get the job done.
    Please do not turn this into a "Which oil is the best for..." thread. There are plenty of them, take your pick.
    If this has already been done, or if it is too similar to what other dedicated forums do (BITOG, for example), then please feel free to axe this.
    I'll start us off...
    Fink
  2. Oct 12, 2011 at 9:31 PM
    Fink
    Orlando, FL
    Fink
    Rambo54 likes this.
  3. Oct 13, 2011 at 1:12 AM
    808hiker
    808hiker Taco addict
    Justin
    Big Island, Hawaii
    lynyrd3 and Yurizx6r like this.
  4. Oct 13, 2011 at 2:27 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    OK so how much does this cost?
  5. Oct 13, 2011 at 2:59 AM
    LGE RAW
    LGE RAW Well-Known Member
    Rob
    Dothan
    2020 TRD Off Road DCSB 6AT Magnetic Gray Metallic
    New Mods in the works.
    HillJackJDS likes this.
  6. Oct 13, 2011 at 3:01 AM
    4Wheelin4Banger
    Randy
  7. Oct 13, 2011 at 4:54 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    :popcorn:
    I'm gonna have to get on this!
  8. Oct 13, 2011 at 5:12 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    I finally got the Fumoto installed last oil change so I can get a sample much easier. Already have the sample kit, just need to wait for my next change so I can see how mine does.
  9. Oct 13, 2011 at 5:29 AM
    Hiemsnox
    Hiemsnox Well-Known Member
    Dan
    Beavercreek, OH
    06 DCSB TRD Offroad Indigo Ink
    this is a really cool idea, i would like to try it seeing as my engine is over 100K
  10. Oct 13, 2011 at 7:08 AM
    Fink
    Orlando, FL
    It's great to see some interest in this!
    Once we get a good collection of them going, we can see if Bob or Mods would mind making a Sticky for the reports themselves, or maybe a Sub-Section somewhere.
    Also, it is only an extra $10 to have them run a TBN test - it measures the amount of additive left in your oil. This is mainly used for those of you that want to extend your OCI's - but I did it just because I think it's interesting and $35 is nothing for knowing exactly what is going on in your engine.
    Keep the reports coming, guys!
    Fink
  11. Oct 13, 2011 at 7:42 AM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    I've had several done as you can see below. They indicated a problem with the exhaust air switching valve before I ever had a CEL. I finally found the problem after getting a CEL and fixed it. It's about time for me to do another one to see how the oil is performing so I can establish a baseline for the oil change interval under normal conditions.
    Here are the ones I've done.
    This sample is a few thousand miles into an oil change after having fixed the air switching valve.
    Taco 422, Cr47524 and Rambo54 like this.
  12. Oct 13, 2011 at 7:45 AM
    afd23a
    The Dynamo of Dixie
    Here's a virgin analysis of AMSoil 5w-30
  13. Oct 13, 2011 at 7:54 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    ^^^^^^^what kind of oil and filter are you running^^^^^^^^^^ *****edit i see its Amsoil 5w30 synth. do you change the filter every 5k? or just run the same filter?
    I understand that you want to make sure the oil is doing its job but at $25-35 a test, wouldnt it just make more sense to change it every 5k and not worry about running it 10k+ miles and testing it rather than just change it?
  14. Oct 13, 2011 at 8:00 AM
    Fink
    Orlando, FL
    Try to keep these questions out of here, if you can. You have valid questions, but there are a ton of other threads to put them in.
    The more bantering we get, the harder it will be to compare the reports.
    Thanks!
    Fink
  15. Oct 13, 2011 at 8:01 AM
    Fink
    Orlando, FL
    afd23,
    Would you mind posting the vehicle information for the first set in the Post Title? It will be easier to find that way.
    Thanks!
    Fink
  16. Oct 13, 2011 at 8:04 AM
    98tacoma27
    Ben
    Not Beech Creek
    :devil: You guys are going to poo when you see mine. :drevil:
    That is if you don't mind it coming from the 4.7L tundy motor
  17. Oct 13, 2011 at 8:12 AM
    pudge151
    Sean
    Connecticut
    gunna tell the MOD what you told me, lol:D
  18. Oct 13, 2011 at 8:13 AM
    Fink
    Orlando, FL
    That'd be awesome!
    What are your thoughts on creating a Sub-Section for them, or something? Then you could break them down by models, engines, whatever...
    Just a thought, I know that's a lot of work for what would appear to be a minimal gain...but there at least appears to be some interest in it.
    Can't wait to see some more of these!
    Fink
  19. Oct 13, 2011 at 8:13 AM
    afd23a
    The Dynamo of Dixie
    Done
  20. Oct 13, 2011 at 8:14 AM
    Fink
    Orlando, FL
    REPORTED! :p
    No - his question was specific to posting reports. ;)
    Fink
