Oil changing nightmare. Now where The F is my oil??
Discussion in 'Technical Chat' started by surfmongrel, Apr 13, 2012.
  1. Apr 13, 2012 at 5:08 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    You have a 2001? Transmission should be fillable conventionally.
  2. Apr 13, 2012 at 5:09 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Tow it. Hopefully you haven't killed the engine or the tranny. The VVT-i runs off of oil pressure. Correct oil pressure. I won't even get into what running the tranny without any fluid in will do.
  3. Apr 13, 2012 at 5:10 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    Oh I thought he was telling us for the fun of it.:rolleyes:
  4. Apr 13, 2012 at 5:10 PM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
  5. Apr 13, 2012 at 5:10 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    oh chit..didnt see that earlier...all is not lost then..but still, how you do that since it's not a 05+ taco
  6. Apr 13, 2012 at 5:14 PM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    That doesnt sound good for the truck :eek:
  7. Apr 13, 2012 at 5:17 PM
    MonkeyProof
    SoCal- SGV
    Drain the mofor oil using the right drain plug..refill with normal correct amount, and add four quorts of the correct tranny fluid and maybe you should be good to go
  8. Apr 13, 2012 at 5:17 PM
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
    Dont start your truck again until you drain the oil out of the motor and refill with the proper amount, then refill the transmission or tow it to the dealer.
  9. Apr 13, 2012 at 5:17 PM
    Johns Taco
    Johns Taco I'm not 4x4, and have an open diff. So i'm 4x1
    Albuquerque, NM
    05 DSM Base SR5 Slug Taco
    Full custom stereo, onboard air compressor, train horns, spacer lift, 30" tires, optima yellow top, rear slider window & tailgate anti-theft mod, pop & lock, class 3 tow hitch, lights in bed, Ultra Gauge, Weather Tech mats, yellow fog lights, camper top, air lift rear airbags, rear diff breather mod, soon to be more...
  10. Apr 13, 2012 at 5:17 PM
    07 sport 4x4
    Blake
    Southeast
    2017 Duramax
    ^ beat me to it :(
  11. Apr 13, 2012 at 5:19 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Even on the 2001 automatics? I thought the sealed unit bs started with the 2nd gen. So back in 01 they didn't have a dip stick either?
    edit...just saw your above post Monkey (sorry about that...i type slow)
  12. Apr 13, 2012 at 5:23 PM
    MonkeyProof
    SoCal- SGV
    This was assuming he had a 05+ taco..at first there was no year listed but has been updafed since first posting
  13. Apr 13, 2012 at 5:26 PM
    4x4jeep
    4x4jeep Well-Known Member
    Kyle
    Destin FL.
  14. Apr 13, 2012 at 5:30 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
  15. Apr 13, 2012 at 5:31 PM
    #35
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    this is awesome! subd!:D
    OP, everyone makes mistakes and you still have a shot at fixing everything with no future problems . . . . . . . . . . but damn :facepalm:
  16. Apr 13, 2012 at 5:33 PM
    #36
    Sunner
    Sunner Well-Known Member
    Oh man. This'll be good.
  17. Apr 13, 2012 at 5:38 PM
    #37
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Been using the Fumoto or Fram Sure-Drain since 2000 and have never had a problem, and I used to off-road the fuck out of my Duramax.
    The nipple-less Fumoto rides about 2" higher than the frame crossmember that's about 4" in front of it. Nothing it going to smack that valve.
    Wife's Rav4 and my '03 Tundra got the Sure-Drain because the drains were on the bottom of the pan and not protected. Duramax was on the back of the pan and protected, Taco is protected.
  18. Apr 13, 2012 at 5:45 PM
    #38
    JasoTaco
    JasoTaco Well-Known Member
    Salt Lake City, Utah
    09 Tacoma TRD Off Road
    ToyTec Ultimate 3" Lift -TSB Rear springs - TRD Cold Air Intake - TRD Skid Plate - Total Chaos Upper Control Arms - 2 Hella Rallye 4000 lights (130W Bulbs) - Clear Bra - Under Coat - Bed extener - Toyota Bed Mat - Weathertech floor mats - Tailgate hose clamp & washer mod - PIAA Fog Lights - ScanGauge II - Beefed Sliders - Differential Breather Mod - Heated Seats - All-Pro Bumper - Warn M8000 Winch with wireless controls - Boztec Diff Skid - ATO skids
    :wave: Welcome to TW
  19. Apr 13, 2012 at 5:51 PM
    #39
    COMAtose HI
    COMAtose HI Well-Known Member
    2012 TRD SPORT 4x4
    6" Procomp Stage 1 Suspension Lift, Custom 6" Alcan Springs, N-Fab Side Steps, Husky Floor Liners, Wet Okole Seat Covers, Debadged, Weathertech Side Window Deflectors, 13" Antenna from AntennaX.com, 35% Tint for front windows, Procomp 7032 Series 18x9 wheels, 33x12.50 Nitto Mud Grappler tires
  20. Apr 13, 2012 at 6:10 PM
    #40
    Blueberry
    Blueberry Well-Known Member
    Nick
    Newton, KS
    T/X Pro named Blueberry by my daughter
    Custom Roofrack, Satoshi, Ammo-can in bed, Hi-lift, 2 HID Hella 700's, 4 Automatcentral 7" Offroad Lamps, 2 Hella Work/Bed Lamps, "Derp'd" Radio and Shifter Console, Anytime Fog-light mod, Anytime Rearview Camera mod, DTRL mod, Awesome TW sticker mod.
    Dang. I think your question has been answered. Good luck.
