Oil consumtion
Discussion in '2nd Gen. Tacomas (2005-2015)' started by vbibi, Aug 10, 2009.
  1. Aug 10, 2009 at 4:03 PM
    vbibi
    vbibi [OP] Well-Known Member
    san fransisco bay area
    2009 4door long bed
    Hi guys, Vbibi hire with my litle question,
    I had my truck for litle over 3 mo. now and I check the oil ever so often to check in the use of oil as the engine breaks down. Now I have 3200 milles
    and the oil is still 1/16" over the high mark. This engine does not use any oil? It is good or bad? I intend to change my first oil at 5000 as per Toyota recomendations. Her first oil change is gona be Mobil 1 syntetic.
    Please help>
    take care
    vbibi:confused:
  2. Aug 10, 2009 at 4:05 PM
    Brunes
    Brunes abides.
    Rotorhead
    It's a brand new/high tech engine- If it was using that much oil already I'd be worried...
    Mobil 1 seems to be a popular choice....Synthetic fluids for the drive line gears is a good idea too..
  3. Aug 10, 2009 at 6:06 PM
    Old Soul
    Old Soul Well-Known Member
    NC
    09 AC V6 SR5 2WD SWB
    not to many, love it the way it is
    I am hoping that using oil will not be an issue until way late into the vehicles life span and not even then actually. NO losing or using oil is a good thang
  4. Aug 10, 2009 at 6:32 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    75000 miles and still uses NO oil.use amsoil to.
  5. Aug 10, 2009 at 6:41 PM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    Pretty well built motors... I'm at 41k and haven't seen any indication of oil consumption.:)
  6. Aug 10, 2009 at 7:04 PM
    JKD
    JKD Well-Known Member
    No it isn't. If the engine does not consume any oil, it means it is not lubricating the rings. Any normal gasoline engine must consume some oil in the normal course of operations.
    Most people with engines that consume very little oil (but enough to lubricate the rings) just don't notice because either the level drop is so slight as to be insignificant between oil changes, or because the lost oil is being replaced by contaminants (fuel, water, etc.).
  7. Aug 10, 2009 at 7:09 PM
    Old Soul
    NC
    ^ very well then. I'll change that to... NO losing and very little using oil is a good thang :)
  8. Aug 10, 2009 at 7:31 PM
    THE TECHNICIAN
    THE TECHNICIAN Well-Known Member
    You should have changed the oil 2200 miles ago....
  9. Aug 10, 2009 at 7:56 PM
    carmellocafe
    KEVIN
    N. California
    holy smokes...:popcorn:
  10. Aug 10, 2009 at 7:58 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Actually, he SHOULD follow the owners manual. Just because you and I choose not to and do it early doesn't mean that's what he SHOULD do.
  11. Aug 10, 2009 at 8:01 PM
    carmellocafe
    KEVIN
    N. California
    Obviously, when an engine is "losing" oil it's either leaking it or burning it. Both = BAD THANG.:eek:
  12. Aug 10, 2009 at 8:59 PM
    Old Soul
    NC
    ^ + 1
    my girlfriends Honda is burning oil like crazy and I do not want that to happen to the taco. I was using synthetic in my other truck and changed every 10k miles and never had burning or losing issues, at least not enough to require topping off between changes
  13. Aug 10, 2009 at 9:06 PM
    yotarob2005
    yotarob2005 Kiss My IFS
    Rob
    Bryan , Tx
    05 D-cab trd sport long bed
    Front Bilstien 5100's Set @ 1.75", rear 5100's & TSB springs, Flowmaster, TRD seat covers, Toyota All weather floor mats, 265/70-17 Michelin LTX AT2's, some Debadgeding, BHLM, led bed lights, 886 back up lights, fog lights anytime mod, Extra d-rings, Toyota bed mat, sockmoney TRD decals, Kenwood 890DNX, Firestone ride-rite air bags, 2 car seats.
    I am sure that you are consuming an undetectable amount of oil, but if it is a noticable amount you should be worried. Good idea to go with Mobil 1, I have used it for years.
  14. Aug 10, 2009 at 9:12 PM
    otter
    otter Well-Known Member
    Rob
    MI
    09 4 cyl Reg Cab
    Wrong. See the above posts about why all engines consume some oil. It's completely normal for many engines to consume as much as a 1/2 qt every 5000 miles.
  15. Aug 11, 2009 at 10:47 AM
    vbibi
    2009 4door long bed
    Thanks guys, much apreciated all your inputs.
    God bless
    vbibi
  16. Aug 11, 2009 at 10:51 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Mine consumes no noticable amounts to me... pretty impressive as my G35 would burn an 1/8 quart after about 4k.
