Oil Dip Stick
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pster, Aug 18, 2011.
  1. Aug 18, 2011 at 4:26 PM
    Pster
    Pster [OP] Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    Is anyone else having trouble getting a good reading on the oil dip stick? I've scored mine to try to get the oil to show on the stick without much success. Frustrating! I'm about to dump 6 oz of FOOD COLORING into the damn thing so I can read the oil level....ARRRGHHHH!!!! Seems like no matter how careful I am, the oil is smeared all over the damn dipshit.
  2. Aug 18, 2011 at 4:28 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Did you sand the end good?
  3. Aug 18, 2011 at 4:29 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Yes, I did. I rubbed it with a metal file across the grain...still doesn't show.
  4. Aug 18, 2011 at 4:36 PM
    TacoDawgfan
    TacoDawgfan Hunker Down You Hairy Dawg!
    Georgia
    2011 Silver 4x4 TRD Sport w/JBL
    5100's at 1.75, Rear leaf TSB, Moto Metal 951 16x8, BFG TKO2 265/75/16, AFe Stage 2 CAI w/pro dry filter, Kenwood DDX374BT installed with Idatalink Maestro kit, Access Loredo tonneau cover, N-Fab steps, Tinted windows, EGR in channel vent visors, UGA drink coasters in the front cup holders, and a Graco car seat in the back seat
    Yep, just had my first change and cant tell if it's full or what. Sat over night and still the same thing.
  5. Aug 18, 2011 at 4:38 PM
    kieth
    kieth Well-Known Member
    British Columbia, Canada
    06 trd
    Full OME lift with Dakars, 886s and LR UCA's, Firestone air bags w\ onboard compressor, 2 kicker CVT 10" subs , MB Quart 1000w amp ,Alpine media player
    ya especially after an oil change with synthetic when its super clean i find it the hardest to see, the best is in the mornin to check it after its been sittin for like 12 hours and pull it up gently
  6. Aug 18, 2011 at 4:40 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Yep. I used Mobil 5w3 Full Synthetic.....wish they put some dye in the stuff!!!!
  7. Aug 18, 2011 at 4:54 PM
    Tacoma Mike
    Southern Maine
    HEHEHEHE I know your Pain.
    We deal with this all the time. Between 3 and 10 sticks is about average.
    Swearing at it doesn't help either.
  8. Aug 18, 2011 at 5:06 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren bump stops, Crown braided/extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch,
    I've had trouble getting a good reading with mobile one synthetic too. Scoring the end with a file helped. I still seem to get a high reading with 5.5 quarts (shows a bit over the top dot.) Next oil change I'm just putting 5.25 quarts in. Anyone else getting a high reading with 5.5 quarts?
  9. Aug 18, 2011 at 5:13 PM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    I now just put in ~5 qts and forget about it. Why can't toyota engineers do a dipshit that works? Is it that hard? Do I have to put epoxy hash marks on it? Dye in the oil? Why is this so &@T#*&@T@ hard!!!!!! Friends, it's easier to make a loan for $100MM than it is to get a reading on these dipshits.
  10. Aug 19, 2011 at 6:44 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Royal Purple is your answer :)
  11. Aug 19, 2011 at 6:49 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    What is Royal Purple? I checked the dipshit this morning after the truck sat overnight......slightly better reading, but not much.
  12. Aug 19, 2011 at 6:49 AM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    2017 Tacoma 6MT TRD Pro
    Falken Wildpeak MT 285's
    Just put 5.5 quarts in and forget about it, because I can't tell where its at on the dipstick either with Mobil 1.
  13. Aug 19, 2011 at 6:50 AM
    Captarm
    Captarm Well-Known Member
    Armand
    Maine and Rhode Island
    2010 SR5 Silver/Black, Tinted windows
    Leather Arm Rest Firestone Ride-rite K&N oil air Filter Wet Okole Black/Gray w heated seats Alpine CDE-123 receiver w Blue tooth,MP3,USB port AP Rock-sliders Viper Auto starter, should have gotten with alarm Anytime Fogs NOKYA7626 yellow lights Muth Heated, Signal Mirror Leer Cap Silver stream line top Differential Breather Mod
    Ya man, Royal Purple is the way to go
  14. Aug 19, 2011 at 6:50 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    It's easier to read? This is such a stupid problem, I'm glad to hear I'm not the only one. I've also resorted to just putting in the specified amount and walking away. I check to make sure it's generally up the dipstick to about the right amount but that's as far as I can get.
  15. Aug 19, 2011 at 6:55 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    When I do that.....it always reads way over the Maximum fill line on the dipshit! I let my oil drain for hours when it's hot so I get it all......I run the engine to circulate the oil into the filter.....then let it sit for hours before I check it again. I've done hundreds of oil changes.....this dipshit is just that......shitty.
  16. Aug 19, 2011 at 9:44 AM
    06SR5canada
    06SR5canada Well-Known Member
    Saskatchewan
    06 dblcab SR5
    2ndary air filter removed, flowmaster 40
    run your thumb nail down the dipstick and watch for it to start really building up and you know you hit the top.
    thats what i did anyway....stupid design
  17. Aug 19, 2011 at 9:49 AM
    The1youluv2hate
    The1youluv2hate Well-Known Member
    Peps
    SAnta Paula CA
    18 TRD sPort 4x4 (11mgmsport)
    oem pro grill 17” pro rep wheels Fox dsc shocks
    Toyota will probably get rid of it like the trans dip stick
  18. Aug 19, 2011 at 11:58 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    I hate to be defeated....so I just sprayed the end of the dipshit with flat black paint and it helped......:)
  19. Aug 19, 2011 at 12:47 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    One thing that can help is, Drill small (1/32") holes in a line going up the dipshit. Ive done this a few times...
    MSN88longbed likes this.
  20. Aug 19, 2011 at 12:49 PM
    Pugga
    Massachusetts
    Good idea! I'm going to do this over the weekend, once again Mr. 4x4 comes through :thumbsup: See, that's why you make the big bucks around here...
